Old 07-08-2012, 06:07 AM
540iver 540iver is offline
Mein Auto: bmw 540i
anti freeze leak
I've got small antifreeze leak coming from under motor! Any answers where it could be coming from? Just had radiator/expansion tank replaced. Haven't replaced water pump/thermostat yet getting to that next.
Old 07-08-2012, 06:19 AM
MurrayP MurrayP is offline
Mein Auto: 98 540i
If the small leak is at the back of the engine and dripping out of the bell housing, it is likely the valley pan gasket. Here's how to fix it!
Replace the water pump/thermostat and CCV on the back of the intake manifold while you are at it.
1998 540i M62 completely stock with $25K of maintenance to keep it that way!
Old 07-08-2012, 07:04 AM
If it's the VPG, then these will help:
- How to fix poorly designed V8 valley pan gaskets that leak coolant (1) (2) (3) (4) (5)
If not, check out this thread for where else you can leak coolant:
- Pictorial look at typical E39 cooling system failure modes (1)
Old 07-08-2012, 11:01 AM
JimLev JimLev is offline
It could be from 10 different locations. Do you have an automatic of a manual?
What year is the car.
Drop the lower engine cover and take a look, that will be quicker than reading tons of post that are pointing to every leak these cars have ever had.
Old 07-08-2012, 04:36 PM
Mein Auto: bmw 540i
Yeah its a automatic! 97 model! I'll play it smart and take your advice JimLev, drop the lower engine cover and take a look.
