Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > Tire Rack's Tires, Wheels, Brakes & Suspension
Discuss everything about wheels, tires, suspension and brakes for your BMW.
Sponsored by The Tirerack. Moderated by Gary@Tirerack.com
Old 07-08-2012, 12:48 PM
johntube johntube is offline
Mein Auto: 2011 335d w/MSport
Comfort and Performance
Finally need to replace the OEM RFT on my 2011 335D (w/MSport )
Rears are currently 255/35/18 and Fronts are 225/40/18 (RFT).
Been reading about the plusses and minuses of going to:
1.) OEM rear size of 255/35/18 and fronts of 225/40/18 (Non-RFT)
or
2.) Rears of 265/35/18 and Fronts of 235/40/18 (Non RFT)
or
3.) Rears of 255/40/18 and Fronts of 225/45/18 (Non-RFT)
My main goal is to obtain substantially more rim protection and comfort while not losing too much road-handling ability. Whatever the decision, I will not consider purchasing RFTs. For option 2 & 3, I also understand the speedo readings will change.
Gary,
Is it possible to use combination 2 & 3 on my vehicle without rubbing or unforeseen handling problems? (I was leaning toward option 3)
Driving something fast....and efficient
2011 335d w/MSport | Alpine White | Black Dakota Leather | Glacier Silver Alum Trim | Premium Package | Cold Weather Package | Paddle Shifters | Steptronic | 193M style wheels!
Old 07-09-2012, 05:32 AM
Gary@Tirerack's Avatar
Gary@Tirerack Gary@Tirerack is offline
Moderator
Mein Auto: 1995 BMW M3
Acceptable front sizes are 225/40R18 or 235/40R18 on the stock front wheels. The rear wheels are only 18X8.5", so technically the widest that will work well on that size wheel is 255/35R18.
We've had a handful of reports of rubbing with the taller sizes you listed in #3 so I cannot recommend those sizes (although I have heard of some forum guys running them successfully).
Tires http://www.tirerack.com/a.jsp?a=AB2&...ires/index.jsp
Refer to 'Gary/Bimmerfest' as your previous contact when you order online. Credit Bimmerfest.com by ordering through the sig link.
Gary@Tirerack.com
Old 07-10-2012, 04:23 AM
Thanks Gary on the prompt and clear explanation.
