Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > The Detail Department
Detailing tips, tricks to keep your bimmer in showroom condition.
Old 07-08-2012, 08:48 AM
phil@detailersdomain.com's Avatar
phil@detailersdomain.com phil@detailersdomain.com is offline
Mein Auto: FJ/911tt/RS6
Detailer's Domain: 2013 Audi S4 - New Car Prep and Opti Coat Applied
Subject: 2013 Audi S4
Requirements: New Car Prep with Opti Coat 2
Customer dropped me an email about a month or 2 ago about his 2013 Audi S4. He asked me about or new car prep services and opti coat. The customer called me 12 hours of delivery of his new car to make sure it was properly prepped and protected before he starts to put the miles on it. I love it when a customer wants to start his new car care the right way.
Exterior
- Wheels were prepped with Sonax Wheel Cleaner and cleaned up with various brushes
- Tires were spritzed down with Adam’s All Purpose Cleaner and washed down
- Wheel wells were cleaned up
- Washed with Adam's Car Wash
- Aquartz Iron Cut
- Wash down and rinsed
- Door jambs were cleaned up
- Nano Scrub AutoScrub
- Dried
- Tires dressed
- Masking
- Paint Measurement
- Menzerna SF4000 with Uber Green Pad - Griots Orbital
- Opti Coat 2
- Inspection with Fenix, 3m Sun Gun, Infratech, and natural sunlight
- Wheel wells were cleaned and dressed
- Rubber and Plastics Treated
- Exterior windows and mirrors cleaned and sealed
- Exhaust tips cleaned
- Windows were autoscrubed, cleaned, and sealed
Interior
- Interior Vac
- Leather Cleaned/Conditioned
- Plastic - wiped down and protected
Products used
Links to products used -
Adam's Car Wash
Aquartz Iron Cut
Sonax Full Effect Wheel Cleaner
NanoSkin AutoScrub System
Menzerna SF4000
Opti Coat 2
Adam's Super VRT
Optimum Metal Polish
1Z einszett Cockpit
Sonax Leather Foam
Tools used
Uber Wool Wash Mitt
Uber No Name MF Towels
Griot's 6 inch Random Orbital Polisher
Uber Buffing Pads
Defelsko Paint Meter
Fenix TK35
Brinkmann
Kranzle Pressure Washer
Cam Spray Foam Canon
2 Grit Guard Buckets with Caddies
Uber Firehose Nozzle
Metro Air Force Blaster
Before shots
Prep - Wash, Decon, AutoScrub, Wheels, and Tires
Wash shots
Wheels were hit first
Sonax Full Effect Wheel Cleaner going to work (some brushing required)
Rinse
Pre soak - bug and tar
Philip Yiu
Detailer's Domain
E-mail: phil@detailersdomain.com
Tel: 201-233-0003
Member's receive 10% off using "BMW" as a promo code at checkout (Swissvax excluded)
www.detailersdomain.com
Foam shots
Iron Cut in action
Rinse
Drying the car with an Uber Super Drying Towel
Blowing out the car to ensure all the water is off
Removing all the dealer installed tire dressing with Stoner's Tarminator
Polishing a known trouble spot on the Audi
Before
After
Prepping the wheels and paint for opti coat - after polishing we used some IPA to ensure a clean surface
Opti Coat 2 applied on paint, glass, and wheels
Buffing off Opti Coat
Afters
Philip Yiu
Detailer's Domain
Tel: 201-233-0003
Old 07-08-2012, 01:31 PM
Ilovemycar Ilovemycar is offline
wooohooo
Mein Auto: '08 335i coupe 6MT sport
Hi Phil, good work as per usual.
The idea of Opti Coat on my wheels is tempting me, and so I had a curious question about it. Once it is open, how long do I have to use its contents? I think I've read that one bottle/syringe can be enough for a number of cars, but haven't seen anything about a time limit (I imagine I would have tons left over if I only used it on 4 wheels). FWIW, I just very recently emptied a mini fridge in the garage in order that it be 100% dedicated to detailing products, even if my dumb guess is that it would probably not help with this product.
Another curious question, even if of less interest to me than the above, is what was the process for the "polishing the known trouble spot"? (Menz SF4000, with the Griot's machine, with particular pads at particular speeds?) Not a biggie here, and I do wonder how different this stuff is from BMW's shadowline trim.
Thanks for your time.
Old 07-08-2012, 01:47 PM
I typically 2 small cars out of the syringe including wheels and glass.
you can even squeeze 2 S4's out of it.
I have kept the opti coat around the shop when not in use in up to 30-45 days with no issues.
You won't need to store it in a fridge.
yup you got it you can go at it with the SF4000 and uber green pad if you need more cut go for it.
Philip Yiu
Detailer's Domain
Tel: 201-233-0003
Old 07-08-2012, 01:54 PM
wooohooo
Thanks Phil! You're fast!
Old 07-08-2012, 02:14 PM
sure thing no problem.
Philip Yiu
Detailer's Domain
Tel: 201-233-0003
Old 07-10-2012, 02:36 PM
thekurgan's Avatar
thekurgan thekurgan is offline
Bad Lieutenant
Mein Auto: S65B40 Powered
Phil, I noticed the Iron cut doing a LoT of work around the wells and rear. Is this from rail shipping or the iron from the brake rotors? I'm just wondering if this will need to be done pretty often, considering it's a new vehicle. Ibis white is sweet when it's done right by your crew!
