Old 06-20-2011, 03:40 PM
EL Kapitan EL Kapitan is offline
Mein Auto: X5 diesel
Smell from A/C
What could this be? It smell when I turn it on or if it has sat for a while then turn it on, it smells like mildew and then goes away. What could it be?
Old 06-20-2011, 04:19 PM
Penguin Penguin is offline
Mein Auto: Z4 and X5 Diesel
Do a google on auto air conditioning smell. It is a quite common phenomenon with auto air conditioners, due to moisture left in the system when it shuts down. It is particularly common when the humidity is high, and is not specific to BMW A/C systems.
One way to avoid it is to leave the fan on, but shut the A/C off a minute or so to dry the system out before parking the vehicle for an extended time.
There are ways to sanitize the system once you have the odor that the google search will reveal.
Old 06-20-2011, 08:09 PM
335i 335i is offline
Sup3rman
Mein Auto: '11 E90 AW M3/ '11 AW X5d
[OB]ne way to avoid it is to leave the fan on, but shut the A/C off a minute or so to dry the system out before parking the vehicle for an extended time.[/B]
+1
I had my 335i system cleaned once under warranty, but I was informed that BMW would only do it once under warranty, and the remedy to the situation was what Penguin described: turn the AC off and turn the fan up high to dry the system out before you shut the car off. I do this every time I run the AC to prevent the "dirty sock" smell.
2011 ///M3 Sedan Alpine White/Bamboo Beige/Piano Black ED 9/16/2011
2011 X5d Alpine White/Cinnamon/Bamboo PCD 6/21/2010
2007 335i Coupe - 6MT Alpine White/Saddle Brown ED 5/23/2007 (retired)
ED Trip Report W/ Pics (And Engagement Story/Pics)
Old 09-06-2011, 09:23 AM
bmw_jeff_325i bmw_jeff_325i is offline
Mein Auto: 2003 525i
Evaporator
Im thinking of trying the Einzett Klima-Clean for my smell issue. However, if you pop out the center vents in a E70 you can actually see that the ductwork closes shut when the HVAC is in the off position. This of course prevents the insertion of the tube down into the the area where the evaporator is. Anyone else have any suggestions on how to access the evaporator to spray the Klima-Cean on a E70?
Current Vehicles:
2003 E39 525i
2008 E70 X5
Past BMWs:
2001 E46 325i
2001 E46 330ci
Old 04-29-2012, 05:53 PM
wyb's Avatar
wyb wyb is offline
Mein Auto: A car
I haven't read the thread, but here is a Klima-Klean how-to...
http://www.bimmerfest.com/forums/sho....php?p=5089015
535i XDrive | Alpine White w/Black+Natural Leather Interior
It's ALL perspective - get some. No - I am NOT addressing YOU!
Old 04-29-2012, 05:59 PM
wyb's Avatar
wyb wyb is offline
Mein Auto: A car
actually - it just appears to be an ad for the product from a board sponsor - no, how-to element... sorry.
But I did find this on another board where some 5'er owners shared experiences and thoughts on Klima-Clean application...
http://forums.5series.net/topic/9803...klima-cleaner/
Old 04-29-2012, 06:06 PM
wyb's Avatar
wyb wyb is offline
Mein Auto: A car
I did find that Amazon has Klima-Cleaner - it's free delivery with Prime membership at $15.00 - or save 15% on a subscription - I'm thinking of putting it on an annual order... one for the Mrs, one for my car....
Old 04-30-2012, 06:10 AM
KULEGOS PL KULEGOS PL is offline
Mein Auto: 08 X5 3.0
You shold change cabin air filter
Old 07-05-2012, 09:32 AM
E70
No one has the E70 TIS sheet available on how to clean the evaporator coil?
Current Vehicles:
2003 E39 525i
2008 E70 X5
Past BMWs:
2001 E46 325i
2001 E46 330ci
Old 07-13-2012, 05:49 AM
grilodan grilodan is offline
Mein Auto: E70 X5 35i Sport Activity
Quick easy DIY that works 90% of the time:
1) start A/c and hit max. Let it run for about 30 seconds.
2) switch to full heat, highest temperature you can. Let it run for 1 minute.
3) switch back to cool, run for 30 seconds
4) finally switch back to hot and let it run for 30 seconds
This kills the bacteria or mildew that might be sitting there in your a/c
- 2013 X5 35i Sport Activity (Born 08/12) - Titanium Silver /Oyster Nevada /Dark Bamboo - ZCV /ZCW /ZPS /Sport Package /Adaptive Drive /Soft-Close Doors/Running Boards /HUD /Shift Paddles /Comfort Seats /6NR /6NF
- 2011 535i (Born 08/10) - Titanium Silver /Black Dakota /Anthracite - ZCV /ZCW /ZPP /ZP2 /6FL /6NF (Sold 08/12)
- 2010 335i (Born 02/10) - Titanium Silver /Black Dakota - ZCW /ZPP /6FL (Sold 09/10)
- 2007 328i (Born 07/07) - Jet Black /Black Dakota - ZSP /ZPP /6FL (Sold 04/10)
Old 07-13-2012, 08:33 AM
chiefneil chiefneil is offline
Mein Auto: X5
I only get the smell when I switch back and forth between fresh air and recirc. I just leave the system in recirc all the time with no problems.
Old 07-16-2012, 07:37 AM
BR328 BR328 is offline
Mein Auto: 335d & X5 35d
Just an FYI, I had a bandaid smell coming from the AC at startup. I took it in to the dealer, and it was a freon leak. The interesting part was the AC seemed to be cooling fine. Anyhow after the work was done, the smell is now gone.
Old 07-16-2012, 10:48 AM
ard ard is offline
Resident Curmudgeon
There is a condensate drain for the AC- make sure this is not blocked...
Just FYI
A
