Old 07-16-2012, 09:33 AM
PAULIN540I PAULIN540I is offline
540i stept bld date 6-02
Mein Auto: 2012SRX--2002 540i Steptr
Charcoal cannister 540- 2002
Searched but could not find the answer to the location of the charcoal cannister.
Also, I just replace the Purge Valve and there are two hoses connected to it. Is there also a
hose from the cannister or are they metal lines ? The one line from the purge valve hooks
up to a metal line which I assume runs all the way to the cannister but not sure if there is a
hose on the other end
I am trying to replace ALL the lines.
Thanks Paul
2002 540I SPORT/STEPTRONIC
TITANIUM SILVER/BLACK 6-2002
Old 07-17-2012, 03:46 AM
Topaz540i's Avatar
Topaz540i Topaz540i is offline
Agnostic Priest
Mein Auto: 2001 540i/6
The metal line is prob a fuel line from the filter or gas tank.
ESS Tuning m60 version software
m60 intake manifold
a.f.e. c.a.i.
3" obx catback
full powerflex urethane setup
545 ssk
cdv delete
m5 rear sway bar
M5 chassis rods
M5 3.15 lsd
Bc-r coilovers w/ swift springs
Akebono=suck
ss braided brake lines
coming soon:
Jb lwfw
Old 07-17-2012, 03:48 AM
Topaz540i's Avatar
Agnostic Priest
Prob here under ventilation
http://realoem.com/bmw/partgrp.do?mo...id=47588&hg=16
m60 intake manifold
a.f.e. c.a.i.
3" obx catback
545 ssk
cdv delete
m5 rear sway bar
M5 chassis rods
M5 3.15 lsd
Akebono=suck
coming soon:
Jb lwfw
Old 07-17-2012, 05:04 AM
JimLev JimLev is offline
Mein Auto: 540/6, '16 Highlander XLE
Paul, just answered your PM and sent you 3 pics.
The evap purge assy is above/behind the left rear wheel liner.
Topaz, I sent you a PM yesterday, did you get the part?
2000 540/6 Slightly tweeked...everywhere
Old 07-17-2012, 06:09 AM
Jim
I did get it and thanks for the pics. I emailed you back to confirm that the rear wheel
LINER must be removed to access the cannister etc
Thanks for the help
Old 07-17-2012, 06:39 AM
Another question!!
The purge valve is part number 13901433603--
When looking at realoem---they show a part number 16136754733 which they call a "leak
diagnosis pump" but when I google this part number It comes up as a DUST COVER.
On the realoem diagram--the 161 part looks like my Purge valve which is in the engine bay.
I won't have access to a lift for a day or two---so can't look at the stuff by the charcoal cannister
Old 07-17-2012, 07:31 AM
cn90 cn90 is offline
This REAR Shock DIY for a 528i has some pics on the Fuel Evaporator,
Not sure if it applies to your 540i but worth a look:
http://www.beisansystems.com/procedu..._procedure.htm
Old 07-17-2012, 08:10 AM
Originally Posted by PAULIN540I View Post
Searched but could not find the answer to the location of the charcoal cannisterl
Do you have P0455 and P0422 codes perchance?
Anyway, I typed "/charcoal canister" in the bestlinks for you to find these:
- How to replace the LDP leak detection pump charcoal canister (1) (2) & does spilled gasoline go into the charcoal canister (1)
The 'where does spilled gas go' thread has juicy information from JimLev on location.
However, it seems we could beef up our knowledge of the location of the charcoal canister & a DIY to test & replace it on both the V8 & I6 (if it's different).
For my part, I'll cross reference to this thread from there.
