E46 (1999 - 2006)
The fourth generation 3 Series (E46 chassis) was introduced in 1999 and set the standard for engineering and performance during it's years of production including being named to Car & Driver's 10 best list every one of those years! ! -- View the E46 Wiki |
#151
But i though it was free of charge, why is the 100-200 bucks? can you explain
#152
![]() While many warranty and "good policy" services are (relatively) free...... we have to remember the dealership is there for one reason and one reason only..... to make money. So...... if they can convince you that you should be paying for something, they will. And let's face it, they know more than we do and unless we are fully up to speed on the exact nature of repairs and services being offered by BMW North America, we are at their mercy......and usually end-up paying for something......one way or the other. ![]() This and many other reasons I prefer to establish a long term relationship and patronize my local private BMW shop that stays on-top of what's happening in the BMW auto service world. Many times I've gone to them with a problem and they give me a copy of the BMW recall or service bulletin so I can understand the situation and be intelligent when I take my BMW to the dealership for specific work.......and not get fooled into paying for anything that I shouldn't. |
#153
Other factors: So much cost-cutting! Let's compare our beloved E46 to our 2011 E90's (we have two as we didn't want to see how bad the F30 was going to get): No trunk tie downs Almost no way to get 12-volt power for GPS/Valentine 1 (they removed the ashtray/lighter) Almost all the tools gone Stunningly thin and cheap carpet No underhood sound insulation pad No flashlight Glovebox so small that the owner's manual doesn't really fit No spare tire (and the RFT's, frankly, suck) And now the F30 has a so-so review in Car and Driver (EPAS, plus the loss of the beautiful aluminum parts in the suspension)?!? Geesh BMW, get back to being honest and responsible, and start making The Ultimate Driving Machine again, please! |
#154
Saved me 200$ thanks!!
#155
My rt tail ground melted too, fixed it, bypassed plug
#156
New to Forum - Recall and Bunch of Questions
Hi, just saw this, but I have a 2002 330ci. Do I assume correctly that this body style is not affected? Some other questions, if I may about the "Service Engine Soon" light.
Mechanic went to reset code due to oil change and I was told my mass air sensor needs replacement. Before that, the codes indicated a module controlling heating/cooling needed replacement. And I have replaced the alternator. Since I am new the the BMW brand, are these codes reliable? The car has only 56,000 miles and am skeptical that I may be replacing stuff unnessessarily. Also any opinions on re-manufactured (with original BMW housing) mass air sensor? Geez, I am asking a lot, so my apologies as a first timer! |
#157
Hello All,
I took my car through the car wash today and about 5-7 minutes after I left, I hear this loud rumbling in the back of my car sounding like a helicopter. I actually cut my radio off to make sure and indeed the sound was coming from the trunk area. Can someone tell me what that could be??? Thanks in advance, Milkyway1977
#158
http://test.resource.bmwusa.com/Pdf_...54021519c.arox For your other questions, you're probably better off starting another thread...it might get more attention.
2003 325i / Gray Green / Beige Leatherette / 4 Dr / 5-spd / Base car with moonroof / 210K+ Miles |
#159
Would this recall have anything to do with affecting my lights flashing when I "lock" or "unlock" my doors remotely.
I do NOT hear a beep or see flashes like in any BMW's Ive owned. 2004 BMW 525i 5-spd. Thanks |
#160
Does your car have an alarm?
#161
I see a red flashing light on my radio. and my rear view has a red globe (light) under it, however i dont think that one is flashing. |
#162
If you have not received a recall notice by now, chances are that your car is not covered. If you believe you car is, or should be covered, call your dealer or BMW NA. This thread is about cars covered in the current recall.
Black Sapphire Met., Black Dakota Lthr., PP, Moonroof, convenient electronic "dip stick," Steptronic. ------------------------------------------------------------------------ E90 328i E92 335i 6MT E46 M3 6MT E39 528i 5MT MBz W140 S320 MBz W124 300E (slammed) (unmentionables in between) '71 AMC Javelin (4-Spd Stick on the floor) '67 Pontiac Firebird 'cabrio' (1st car - "the leaker") ------------------------------------------------------------------------ Member: BMW CCA |
#163
Anyway, you're on your own. Since your car is an E60, you can post to that forum and ask the question...people there might be able to respond. This is a long thread on the recall (and that too for E46 sedan only), so most people aren't even bothering to read it.
#164
I just bought the car maybe 2 months ago... could i just walk into a BMW dealer and asked them to check or is this a longer process?
#165
I think you can just walk into the dealer and ask. BTW, your profile say you have a 325i, but your first post here says 525i. This recall is for 3 series, so I guess your first post was a typo.
#166
http://www-odi.nhtsa.dot.gov/recalls...intVersion=YES
#167
I fixed this issue the first week I bought my bimmer!
![]() I can deal with the ses light being on, but that giant orange car with a red butt-light had to go! |
#168
The fastest way to do it is to open your trunk, turn the black asterisk looking handle to the left all the way, then pull your rear housing off. unhook the harness and look at the grounding pins where the black wire goes in. If they're melting or burning, you should have and indicator on your instrument cluster telling you the bulbs are burnt out, even if they're not. If that's the case, and the black wire isn't tapped with an alternate grounding wire, you need to either take it in for a recall, or just fix it like most everyone else already has.
#169
2) They look fine but ill walk in and see whats up next time im there, Ive been there allot trying to get the 540i running. |
#170
I just called BMW Canada Customer Service........and after giving them the full VIN of my 2004 325i, was told my car did not fall within the manufacturing date range of the affected product.
I asked "What IS the date range of the affected cars?" She didn't know........and that was the way she ended the conversation. I'm assuming MY car and any of the "American" cars (discussed and pictured, above) were all manufactured in the same factory...and I was also of the impression that ALL 2004 325i's supplied to North America were affected. Am I wrong on both counts? Any follow-up, especially from anyone with a TSB number or experience with performing this fix in Canada, greatly appreciated! Michael |
#171
I aleady did the DIY repair but figured they may as well go in there and replace the parts. It's free and the car will be in there anyways. Whoever you spoke to is blowing smoke!!
"It is little use listening to other people as they will either be agreeing with you or saying stupid stuff" - Dogbert I'm not a pessimist. At some point the world sh!ts on everybody. Pretending it ain't sh!t makes you an idiot, not an optimist. 2004 325i - Sport package - 5MT- clears - CDV mod - M3 gauge faces w/silver gauge rings & red needles - SS exhaust tips - strut tower brace - Hotchkis anti-sway bars -50% tint - shadow grills - roof spoiler - silver CF trim |
#172
Wow I am glad I joined. Just purchased my 2003 325i and was getting pissed cause I had to keep taking my tail light out and jiggle the wires then 5 minutes later had to do the same thing. Definetly have a black melted looking mark on the harness...calling that number tomorrow hopefully they still honor it!
#173
Mines an 01 325xi. Looks like I'm sol.. gonna be calling my ex-husband to see if he can fix it. Why doesn't BMW just include all the years in the e46 series? Its obviously an issue with models outside the recall?
#174
too late?
Is it too late to get this done?
#175
I doubt it...it's a recall, so as long as your car is covered by it, they will do the work.
