Z3 Roadster (E36/7) Brake pads - Bimmerfest - BMW Forums
Old 07-17-2012, 07:55 PM
Lucas1215 Lucas1215 is offline
Mein Auto: 2000 bmw z3 roadster 2.3
Brake pads
Hello, i have a 2000 bmw z3 roadster,planning to change my brake pads, is it okay to use autozones pads? Do i also need a new sensor? Please advice me..im a newbie... thanks
Old 07-18-2012, 06:32 AM
BeemerMikeTX's Avatar
BeemerMikeTX BeemerMikeTX is offline
Mein Auto: Z3 3.0i Roadster, K1300S
If you have not yet worn through the brake pad wear sensor so that the light on the dash has come one, then you should be able to reuse your existing sensors. However, the sensors are fairly cheap, so why not install new ones to eliminate this as a potential source for a false alarm during the life of your new brake pads?
As for Autozone brake pads, they will probably work, but again, brake pads are relatively cheap so why not use use quality brake pads on your BMW? BMW/OEM pads are a little pricey, not to mention dusty, but there are plenty of excellent aftermarket pads out there. I personally installed Axxis/PBR Metal Masters (semi-metallic) on my 3.0 Roadster, and have been very happy with them . . . excellent performance and no dust.
Also, if your brake pads pads are worn out, check your brake rotors also to see if they are near their wear limit. The general consensus seems to be to replace BMW/OEM rotors at the same time as you replace brake pads because BMW/OEM rotors seem to be softer and will not last through two sets of brake pads.
Mike White
"That's right, you're not from Texas, but Texas wants you anyway." -LL
2001 Z3 3.0i Roadster (Topaz Blue Metallic, 5-speed manual, Sport Package, CD radio, heated seats and mirrors, non-power top via special order)
"Beemer" is for my BMW motorcycles - '13 K1300S, '95 R1100RS, '88 K75S, '75 R90S (gone, but not forgotten).
Old 07-18-2012, 01:07 PM
Pinecone's Avatar
Pinecone Pinecone is offline
M Mad
Mein Auto: M Roadster/M3
Actually only BMW recommends new rotors everytime you change pads. Most people have found that you can wait every other set of pads.
Or others, just don't worry about the rotors for a good number of miles.
WRT the sensors, if the brake light is not on for worn pads, the sensor is fine. It is a one shot sensor, it is fine or it used. No need to change if it is not indicating worn brakes.
Terry Carraway
'95 Alpine M3 LTW
'00 Dakar M Roadster
'02 Topaz M3
Old 07-18-2012, 06:54 PM
ronpolley ronpolley is offline
car poor all my life
Mein Auto: 2001 Z3 3.0i Auto
I have auto zones best pads on my Z3 and they seem as good as what was on it,I also changed the front sensor as it was spent.
Old 07-18-2012, 10:35 PM
IgotBMW's Avatar
IgotBMW IgotBMW is offline
BE IRIE
Mein Auto: 98 540i, 03 X5
If you want to reuse the sensors, be careful taking them off. Mine broke off (was trying to reuse) so I had to replace them. They are fairly inexpensive so change them anyways.
Check rotor wear. If it's still over the minimum then don't need to replace them.
Old 07-20-2012, 07:13 AM
Pinecone's Avatar
M Mad
I taped my sensors back against the wire. I have the wheels off enough and check the brakes, so sensor it not needed.
Terry Carraway
'95 Alpine M3 LTW
'02 Topaz M3
