xx 740i - Am I mssing something - Bimmerfest - BMW Forums
Old 07-21-2012, 06:17 AM
First740i First740i is offline
Mein Auto: 740i
Pulled out my fuel pump. Put it back in and wont start?? Is there a rest some where?
Old 07-21-2012, 06:31 AM
Mein Auto: 740i
And still blowing fuse in the trunk for fuel pump!!
Old 07-21-2012, 07:36 AM
kimokk kimokk is offline
**Bimmer DIYer**
Mein Auto: 00 740iL, 97 M3, 06 X3
Sounds like you have a short somewhere. Did you replace the pump or just remove and reinstall the same one?
BMW '00 740il w/230,xxx miles, DIY timing chain guides complete! M60 Manifold, BDC Throttle Body, Performance gearing 3.46 LSD, Magnaflow Mufflers
BMW '97 ///M3/2/5 w/105,xxx miles
BMW '06 X3 w/130,XXX
Old 07-21-2012, 11:37 AM
Mein Auto: 740i
Same pump. It started for like 10 seconds today then died! And now it wont start again!
Old 07-21-2012, 07:24 PM
joyism5's Avatar
joyism5 joyism5 is offline
Mein Auto: '99 740IL, K75RT
With a multimeter : do you get a voltage at the pump? Do you have continuity between the fuel pump wires? If not fuel pump might be burned(open circuit).
JOY = BMW
Old 07-25-2012, 09:57 PM
PETER NEWMAN's Avatar
PETER NEWMAN PETER NEWMAN is offline
Mein Auto: BMW 635 CSi BMW 730i E38
Check the fuel pump relay which is in the small relay box under the hood, If I remember it is green.
Old 07-26-2012, 07:22 AM
Mein Auto: 740i
Thank you for the help! It was the fuel pump.
