Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series & 8 Series > 7 Series DIY
7 Series DIY
Do It Yourself forum dedicated for 7 Series BMW Owners
Old 02-07-2012, 11:45 PM
PAPER's Avatar
PAPER PAPER is offline
CRISP & CLEAN
Mein Auto: Ford Pinto
Info on recoding a used key & remote inside's
I decided to open up a used key I bought .
I will post pics to show you a common
problem with some of your buttons
not working . I will also point out the chip
you need to change so you can have the
key / remote Re-Coded for your car .
1st pic - button that broke loose from sauder .
2nd pic - spot button belongs
3rd & 4th pic - housing
5th pic - chip you need to replace so you can have a used key Re-Coded
Sent from my GT-I9100 using Bimmer App
ID:	311491   Click image for larger version
ID:	311492   Click image for larger version
ID:	311493   Click image for larger version
ID:	311494   Click image for larger version
Old 02-07-2012, 11:55 PM
PAPER's Avatar
CRISP & CLEAN
I'll post the chip # in the morning when I check my notes
Old 02-08-2012, 04:00 AM
mortyx10 mortyx10 is offline
Mein Auto: 745i
I opened mine couple months ago to change the battery...just wanted to mention that no initialization is required after changing the battery....worked straight away.
Old 02-08-2012, 06:45 AM
HerbP HerbP is online now
I was not aware that this could be done? This should be added to the DIY!
Old 02-08-2012, 06:53 AM
Blackbox760 Blackbox760 is offline
Mein Auto: 2003 E66 760Li
wow very good find, how are you going to program the key? and will you be able to program it as key #1 again?
Old 02-08-2012, 01:27 PM
PAPER's Avatar
CRISP & CLEAN
HERE IS A LINK TO A NEW BLANK CHIP .
http://www.ebay.com/itm/Philips-PCF7...item4ab317907c
Old 02-08-2012, 01:33 PM
PAPER's Avatar
CRISP & CLEAN
i DON'T HAVE THE PROGRAM OR HARDWARE NEEDED , SO I WON'T BE PROGRAMMING IT .
BUT IF YOU KNOW SOME 1 THAT HAS THE GT1 UNIT I WAS TOLD IT COMES WITH
THE HARDWARE ( KEY HOLDER ) NEEDED . I HAVE ALREADY TALK TO SOME 1 HERE IN L.A.
THAT CAN PROGRAM THE KEYS .& HE SAID HE THINKS HE CAN ADD IT AS KEY 1 .
HERE IS ANOTHER LINK TO A COMPLETE KEY NEW FOR $74.99
http://originalkeyless.com/2005-BMW-...5.qscstrfrnt04
Old 02-08-2012, 01:58 PM
thanx
Old 02-09-2012, 10:48 AM
Kause187 Kause187 is offline
Mein Auto: 2004 745Li
Im in the LA area as well, let me know if he can program the key for you, also- Do i need to buy the key transponder as well, or the second link to the bmw key itself is good enough ?
Old 02-09-2012, 03:12 PM
PAPER's Avatar
CRISP & CLEAN
Originally Posted by kause187 View Post
im in the la area as well, let me know if he can program the key for you, also- do i need to buy the key transponder as well, or the second link to the bmw key itself is good enough ?
you can just buy the key in the second link .
I am not getting any key's made , i was just
looking into the possibilities of re-coding
a used key . The guy who i have talked to
has done several new key's for a friend .
So im sure he can still do a key for you .
Old 03-12-2012, 08:33 PM
PAPER's Avatar
CRISP & CLEAN
Bump for those PM'ing me !!!
Old 03-13-2012, 07:35 AM
PAPER's Avatar
CRISP & CLEAN
BUMP !!!
Old 05-12-2012, 10:46 PM
PAPER's Avatar
CRISP & CLEAN
Old 05-13-2012, 03:52 AM
***CCCP***'s Avatar
***CCCP*** ***CCCP*** is offline
Major
Mein Auto: 745 li
Thank god i have 3 sets of key fobs
Old 05-13-2012, 09:55 PM
optirobk optirobk is offline
Rob
Mein Auto: 2003 745Li
I need a spare key made and have my original key fixed. The unlock button does not work. It feels like a broken piece underneath the actual unlock button. Can you send me the contact information for your buddy who could/would make a replacement? Thanks for your help!
Old 07-21-2012, 11:15 PM
PAPER's Avatar
CRISP & CLEAN
Old 07-22-2012, 12:05 AM
Rookie2008's Avatar
Rookie2008 Rookie2008 is offline
Mein Auto: BMW 328GT/740LI/750LI
Great Find Paper!
13 740LI W/Msport package. Executive Package
DRIVER ASSISTANCE PKG, HUD,
OYSTER; NAPPA LEATHER SEAT TRIM,
Lane departure, blind spot detection,
Collision Mitigation,
Side & Top View Cameras
Aftermarket Rear entertainment
Old 07-22-2012, 12:20 AM
PAPER's Avatar
CRISP & CLEAN
Originally Posted by rookie2008 View Post
great find paper!
this isn't something i found !!!
I figured it out myself & took
apart a used key i have .
I did the same for a friend & he went
& had it coded to his car .
Old 07-22-2012, 12:21 AM
Rookie2008's Avatar
My fault. Great Fix bro!
Old 07-22-2012, 08:09 AM
sirstopher's Avatar
sirstopher sirstopher is offline
bimmerfest Supporting Member
Mein Auto: POS Honda
Do you want me to move this to the DIY section.
97 740i e38 - SOLD
02 745i e65
03 Montero Limited
Old 07-22-2012, 09:32 AM
PAPER's Avatar
CRISP & CLEAN
Yes , thank you
Sent from my GT-N7000 using Bimmer App
Old 09-14-2012, 05:10 PM
PAPER's Avatar
CRISP & CLEAN
Bump for that person who for some reason
couldn't find the topic in the DIY section & pm'ed me !!!
Old 07-08-2013, 03:40 PM
PAPER's Avatar
CRISP & CLEAN
bump
Old 10-20-2013, 03:42 PM
Djdave92Parents Djdave92Parents is offline
Mein Auto: BMW 745i
Thx paper for all the great feedback you provide on this forum...
Would you happen to have the contact information for the person who might program the bmw keys I am in need of programming a key or two
Old 06-11-2014, 05:57 AM
darsh darsh is offline
Mein Auto: bmw e65 735i
Wink hey hello
Hey i am driving bmw 735i 2002. need to get maps and aux in it can anyone help.
HTML code is Off
