E34 (1989 - 1995)
Old 07-22-2012, 03:27 PM
bddcustoms bddcustoms is offline
Bimmer Dave
Mein Auto: 1997 528i
E34 Engine HELP!! Or, "Shouldn't this cable be connected to something?"
Hey,
I just joined Bimmer nation recently. I was cleaning the engine compartment and noticed a throttle-like, or actuator cable dangling. Don't know what it is, don't know if I knocked it loose while cleaning. I haven't and won't try starting the engine until I decipher it.
It runs just under the the throttle body, I think. See pix and tell me what you think.
  • One pic is from below the tube;
  • one is from the drivers side, the others from the pass
  • The attachable end of the cable is just behind and above the fan (NOTE: THE FAN SHROUD HAS BEEN REMOVED IN THIS PIX):
Thx!
Dave
Old 07-22-2012, 04:34 PM
supertech777's Avatar
supertech777 supertech777 is offline
Mein Auto: 1995 525i
Is it the cruise control cable . Does you cruise control work ?
Sent from my Desire HD using Bimmer App
Old 07-22-2012, 04:37 PM
paperplane94 paperplane94 is offline
Mein Auto: 1989 525i M20B25
Probably Not working then...
There are two cables: one for the Cruise control and one for the accelerator pedal.
If you can still accelerate then the cruise control cable is at fault.
Use RealOEM.com to find the plastic bushing needed for the repair.
Old 07-22-2012, 04:38 PM
Also but I'm not sure about the model u have , wondering if that is also a kick down cable
Old 07-22-2012, 04:39 PM
P.S. Is that a broken fan blade I see? You better replace that before it throws off your waterpump bearing. Should be 3 hex head screws on the front of the fan clutch. You may have to remove the shroud as well.
Old 07-22-2012, 06:35 PM
BMR_LVR's Avatar
BMR_LVR BMR_LVR is offline
Humble E34 lover
Mein Auto: 1992 525i
He said in the original post that he had removed the fan shroud for the last pic .... just sayin'
Couldn't help it paperplane. Just kidding with ya'. We're even now right ?
And to Dave, Paperplane is right. You need to replace the fan. As an FYI, I have heard bad things about aftermarket fans coming apart and doing massive amounts of damage. I would recommend OEM only for the fan blade.
Steve
Calypso Red 1992 525i with 170K miles
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 07-22-2012, 08:30 PM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
plus one
as for that cable, i cant tell from the picture, what engine do you have? in anycase, it will be either the throttle, cruise control or maybe kickdown. which ever it is, it is safe to start the car. start her up and press the accelorator pedal, if nothing happens then theres your answer
Old 07-22-2012, 09:52 PM
He has the M60, so its electronic kickdown.
@BMR LVR
lulz.....just sayin
Old 07-22-2012, 11:21 PM
M540FELLA's Avatar
M540FELLA M540FELLA is offline
Josh
Mein Auto: 95 540i m sport
Yeah my guess as well is the cruise control, the po of my car had a problem with the throttle sticking a little after using the cruise control and the idiot cut the damn thing b/c his wife was driving it and it scared her
Old 07-22-2012, 11:43 PM
luckydog's Avatar
luckydog luckydog is offline
Lucky to drive a BMW
Mein Auto: 2006 M5///
If the gas petal throttle works i would say cruise control secondary throttle cable. I would get a Bentleys Manual for that BMW for best results.
Old 07-23-2012, 08:22 PM
Bimmer Dave
Could it be the cruise control actuator?
see this parts like and let me know what you think.
http://data.bmrparts.com/bmwparts/BM...711378315.html
Old 07-24-2012, 03:28 AM
goosefoot33's Avatar
goosefoot33 goosefoot33 is offline
Manualaholic
Mein Auto: 01 330Ci/94 530i
Yes, that's the cruise control cable. There is supposed to be a plastic bracket that sets in the hole below the intake. I took some pictures of mine the other day (see below). Definitely get that part on order!
Sent from my Droid Incredible
ID:	334010   Click image for larger version
ID:	334011   Click image for larger version
Full 1995 530i Part-out! http://www.bimmerfest.com/forums/sho...d.php?t=568506
BMWCCA Member# 451235
(Summer) 2001 330Ci - ZSP
(Winter) 1994 530i "Greenie" - LOADED
Old 07-24-2012, 03:43 PM
Bimmer Dave
Now that you mention it...
Hey Pape (may I call you Pape?),
Now that the mystery of the mysterious cable has been solved the broken-fan-blade-throwing-off-the-waterpump-bearing thing has me nervous. I just bought the car and the blade was part of the whole "as-is" deal. Would I feel a vibration or something if the bearing was blown? Would there be any collateral damage if this was the case, or would I simple be replacing the waterpump along with fan?
Feel free to scare the crap outta my wallet as you let me know that what's what.
'preciate it.
DTT
Old 07-24-2012, 04:59 PM
BMR_LVR's Avatar
Humble E34 lover
'preciate it.
DTT
Grab the fan and see if it wiggles back and forth. If it does, then the water pump will need to be replaced. If no wiggle, then just replace the fan. That fan being off balance can grenade and take out the radiator and hoses and can dent the hood from the inside as well
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 07-24-2012, 10:31 PM
Yup, the plastic fan is much easier to replace than the waterpump. You will probably extend the life of the WP by doing so.
Just follow what I said above to replace the fan without removing the clutch. Use allen keys and a screwdriver handle.
Old 07-24-2012, 10:56 PM
Grab the fanclutch and see if it wiggles back and forth. If it does, then the water pump will need to be replaced. If no wiggle, then just replace the fan. That fan being off balance can grenade and take out the radiator and hoses and can dent the hood from the inside as well
edited for clarity.
with a fan like that with so many blades, i really doubt it will mess up the waterpump. a 5 or 6-blade fan maybe
Old 07-24-2012, 11:06 PM
air_cooled air_cooled is offline
Mein Auto: E39 528i / E34 540i
Not the cruise control cable. That cable comes from your ASC actuator.
You will note you now have a yellow triangle with ! when you start the car. This is because the actuator has no "feedback/tension" on startup self test. Hard to tell from your picture but there should be a threaded plastic sleeve that passes through the notched holed bracket.
If you cannot reconnect then secure cable away from fan. Car is safe to drive you just have no traction control.
Old 07-25-2012, 03:51 AM
Bimmer Dave
Think of found it:
E34 530i SECONDARY THROTTLE HOUSING TUBE ASC
Bowden cable Ads 2
part no. 17 - PN 35411163163
http://www.realoem.com/bmw/showparts...51&hg=13&fg=15
Bimmer Dave
Remember Boys, once you've grown-up, Santa delivers his joy year-round... on a flatbed!
1994 E34/530i manual, Oxford Green Metallic on Tan - totaled (not my fault... honest!)
1997 E39/528i manual, Arctic Silver Metallic on Black
Old 07-25-2012, 03:47 PM
Bimmer Dave
I'm going to start a new thread to continue this conversation....
http://www.bimmerfest.com/forums/sho...70#post6971970
join me, won't you?
Bimmer Dave
Old 07-25-2012, 09:27 PM
Ah, overlooked the ASC system for the newer models. Glad that is settled.
Old 10-05-2012, 04:21 PM
ncyankee23 ncyankee23 is offline
Mein Auto: 94 530i
Ok, question pertaining to this cable. My car runs like crap when it is in it's plastic holder. But when I take the cable out of the plastic holder and it rests against the manifold, it runs like a champ. Any ideas?
I believe the cable controls the intake flap. So it seems that the car runs better when the flap is more closed. Does this mean the computer is running a bad air/fuel mixture causing it to bog down, quite noticeably? Would this then indicate a bad MAF sensor?
Any ideas would be appreciated.
Old 10-06-2012, 08:19 PM
BMWFatherFigure's Avatar
Old School
Mein Auto: E23;E30;E38;R50;R55
Cable should not hold flap partly closed. Now you know why it was discnected. I guess it (the cable) has not been correctlt fitted.
Current:
Previous:
Old 10-13-2012, 11:05 PM
Should be adjustable. Keep looking for an adjuster nut somewhere.
