E30 (1982 - 1993)
Old 07-27-2012, 02:26 PM
alpinewhiteE30 alpinewhiteE30 is offline
Mein Auto: 1987 BMW 325e
Exclamation Obc question??????
question about the obc 6 button display.. i have an 87 325e, which came stock with a 6 buttons, but the l.e.d light board is broken and doesnt light up.. if i purchased a 13 button one off ebay will it work for my car if the car came stock with a 6 button one.. how does that work?? im havin a hard time findin the 6 button one to replace the broken one in my car. so i thought about buying a 13 button one.. is there a difference between the two if i put in a 13 button one????
Old 07-27-2012, 03:22 PM
Terrains's Avatar
Terrains Terrains is offline
Well the 6 button OBC was only wired up for reading the temperature.. the 13 button OBC had a lot more functions than the 6. So unless you wanted to buy all the wiring and sensors and hook everything up and stuff like that, I wouldn't recommend a 13 button. At least that's how I think it works..
Edit: And you could just make a light bar for your current OBC. There's tons of articles on how to make one from stuff from Radio Shack. All you do is pull out the old light bar and put in the new one
Old 07-27-2012, 04:03 PM
kool thanx for the info.. ill definatly take a look at fixin the light board ... most of the lights n stuff inside the car doesnt work either like the si board and all the digital stuff....
Old 07-27-2012, 05:09 PM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
yep its not plug and play, unless you fit the whole loom etc too, which means taking out the dash if you want to do it properly.
Later BMWs it all just plugs in all the wiring is there from the factory. sady E30s were before those days
E30 above Sold
Last updated 2nd January 2014
