Old 07-28-2012, 07:36 AM
Pocalin Pocalin is offline
Mein Auto: 1999 Z3 Roadster
Windscreen washer problem
The windscreen washer has stopped working, a few drops of water emerge for a couple pf second but then stop. Pump runs ok and pipes do not semm to be blocked.
I dont know what the electrical wiring does that enters the rear of the piddler pipe units, could this be the source of the problem, an electrical failure. All relevant fuses are OK !
Old 07-28-2012, 01:38 PM
alcofribas's Avatar
alcofribas alcofribas is offline
ZSCCA Asheville volunteer
Mein Auto: 2001 Z3 2.5i
Solution to Windshield Washer problem
The same happened to my 2001 Z3. The washer system was producing nothing when I bought the car. My mechanic listened to the pump and determined it was working. He pulled the pump up from the reservoir and pulled off the completely gummed-up filter. A quick wash and it worked perfectly. One of the nozzles didn't work, so he removed the filter at the nozzle and reconnected the water tube directly. Perfect washer system now. Might work in your case as well. Good luck!
