Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > F10 / F11 (2011 - Current)
The new chapter in the highly successful story of the BMW 5 Series Sedan (F10) and wagon (F11)
Old 05-01-2011, 06:26 PM
cynerjist cynerjist is offline
Mein Auto: 2011 550xi
Drive Moderately -- Malfunction Fuel System
Hello, I need some help.
I purchased a 4/10 build 550i (USA) a couple weeks ago. Everything fine for a week, then I get the "Fuel System Error" Drive moderately full engine power not available.
Car seems okay if I don't go over 2000 rpm, but geez who wants to do that? My car has sport and adaptive drive. There is still power, but I don't know the car well enough to know if is what it really should be or not.
The battery was low when I bought it and I have not hooked it to a charger, but I have not received any battery warnings since. I use premium fuel. (trying to eliminate potential things)
The light/warning message comes and goes as I drive and resets between drives after the ignition is switched on and off.
I searched around and saw a few similar issues, but not exactly mine. Does anyone know what is going on? It is headed in for service, and I would like to be aware because sometimes service is no so coherent or striaght-up regarding such things. Basically, I don't want to hear it's because of the way a drive or something like that.
I don't push the car hard now that the light is on. Before, I pushed it a little, but nothing an oridinary person that just got there hands on it would not do. The light first appeared when I was decelerating to a stop sign to drop my mother off after Easter Brunch. Not exactly spirited driving led up to it.
Any help much appreciated. Thanks.
Old 05-02-2011, 05:57 AM
BobRBob's Avatar
BobRBob BobRBob is offline
Mein Auto: 2011 528i
Fuel pump maybe? Really no point in guessing.
Your car has a problem and I'm sure BMW Service will deal with it. Get it in there as soon as possible.
Current BMW
2011 BMW 528i
Cashmere Silver/Black Dakota
Ash wood trim
Sport Package
Premium Package
Nav
Premium Sound/Sirius
Comfort Seats
Prior BMWs
2001 530i Sport (deceased)
Cosmos Black
Other
2005 Subaru Outback 2.5XT
1977 Corvette 383 Stroker
Old 05-02-2011, 12:50 PM
Okay, I'm at dealership now. I thought there might be other F10 owners that have seen this issue before and have some insight. I will follow up with my findings. Agree fuel pump seems likely. But have not heard much about fuel pump N63 issues.
Old 05-02-2011, 03:52 PM
Diagnostic performed. Car is being kept at dealer overnight to update software on control modules and then take it for a road test. Will follow up with results.
Old 05-03-2011, 10:45 AM
Problem solved!
Here are notes from repair slip:
Software error. Hooked to ISID.
Faults 481B02-control
Current fuel pump control too high
1F0201-DME Internal Fault
No service bulletins. Test plan results show to reprogram/code EKPS Control Module
Programmed complete vehicle with software version 41.2.0.1
Initialized TPMS and sunroof. Test drove and rechecked. Fault has not returned.
GWCODE: 70222219
DIAGCODE: D1330 EKPS0000 90 211
Old 05-03-2011, 11:21 AM
que syrah syrah que syrah syrah is offline
Drink More Wine!
Mein Auto: 2011 550iX M Sport
Glad it's finally fixed and hopefully never comes back!
Old 05-03-2011, 11:28 AM
dunccfp dunccfp is offline
Mein Auto: F10
I had "reduced power, call will not start if you shut it off" on the Jersey Turpike 190 miles from home. I called the dealer and had them put a loaner car out for me. Car started after I shut it off (at the dealer) but did not start for the dealer the next morning. They reprogrammed and I have not had a problem since....
Old 05-04-2011, 06:40 PM
Glock 32 Glock 32 is offline
Mein Auto: F10 550i
Crap, just got the same warning. Turn off, get out, set alarm, got back in and started it... Cleared.
Here is to hoping it does not come back... (fingers crossed).
Thanks for sharing the resolution in your situation (should help if it does come back). Too often the OP never reports back and/or there is no closure.
Old 05-04-2011, 07:08 PM
Steamer's Avatar
Steamer Steamer is offline
Mein Auto: 2011 550i, 00 M Roadster
Thanks for the info, glad to hear you have your car back and working correctly
Old 05-10-2012, 05:35 AM
tovj829 tovj829 is offline
Mein Auto: 2011 550i xDrive
Thanks for posting this. I had this message occur on two different occasions when the car exceeded 4,000 rpms. Other than the message, there wasn't any noticeable difference in the way the engine performed, but still something that I need to get checked out..... Yet another issue to add to the list of problems with this car (recurring bubbles in tires, battery drain issues, fuel sensor malfunction, and now this).
Old 05-10-2012, 03:37 PM
hextall14 hextall14 is offline
Mein Auto: 2009 335xi Msport
I had same problem. It then progressed to 4x4 malfunction. I was driving and the car suddenly lost all power and I had to pull over quickly
As momentum was decaying rapidly!
Turned off and started again and had check engine light on. Had car towed and was at dealer for 4 days.
Fuel pump and sensor both failed and were replaced along with reprogramming. Will find out tomorrow.
Old 05-15-2012, 09:17 AM
2001S15 2001S15 is offline
Mein Auto: Infiniti M45
I had this same problem... see my thread of a similar title.
They replaced both the fuel pumps.
I got the car back, drove it for two days, error came back!
It's going in again later this week. Sigh.
I'm getting pretty tired of the problems with this car. It's a sorry indictment when I enjoy the crappy 328i loaner more than the car being fixed :-P
Current: 2011 550i Imperial Blue/Oyster
Current: 2009 Honda S2000 Laguna Blue Pearl/Black
Current: 2011 328i Sport Wagon Tasman Green/Oyster
Retired (2011): 2006 Infiniti M45 Sport Diamond Graphite/Stone
Retired (2006): 2004 Infiniti G35 Coupe Caribbean Blue/Graphite
Retired (2003): 2001 Nissan S15 200SX/Silvia Lighting Yellow/Black
Old 05-17-2012, 05:45 PM
dunderhi's Avatar
dunderhi dunderhi is online now
0-60 in 4 secs or less!
Mein Auto: '13 X5M, 650xi
I'm a winner! I got a Fuel System Malfunction this evening on the way home from work. It happened right after I restarted the engine after checking the mail.
BMWUSA 650i xDrive Build Link ...................................BMWUSA X5M Build Link
2013 X5M ........ 2013 650xi ...... 2011 550xi (ret) 2011 335d (ret)
Old 05-25-2012, 04:00 PM
dunderhi's Avatar
My dealer said it was caused by a faulty low pressure sensor, so they just replaced the sensor.
Old 07-28-2012, 05:29 PM
musialor musialor is offline
Mein Auto: 2012 535
I just drove home new 2012 535 from dealership. Got it in driveway and it stalled with the same error message. It would not restart. They just took the car with 110 original miles off on a flat bed. Yes, the fuel system is an issue of some sorts. Software or otherwise, this does not bode well with my future with this car. I can still get out while there is time
