E46 (1999 - 2006)
Old 08-01-2012, 06:35 PM
Jussybro Jussybro is offline
Alfa.M.twd.2012
Mein Auto: 06 325Ci E46 Coupe
Cool **HELP** is sound to my ears
So I’m in the process of upgrading my speakers in my 2006 325Ci E46 Coupe.
Questions that need your help are as follows:
1. How do you know if you have a HK system or not?
I want to keep the original head deck (looks, nav-no internet needed, cost).
2. Does anyone have a Link to the workshop and operators manual for the Nav MK4?
3. Ive ordered a set of splits for the front and was going to run them off 2400W 4 channel Boss Amp and bridge 2 channels for the Alpine 12” sub.
http://www.ebay.com.au/itm/190456852...84.m1439.l2649
http://www.ebay.com.au/itm/190648013...84.m1436.l2649
4. The boss amp sez it has an “Input Sensitivity Selector” so will I need a PAC line output converter?
http://www.ebay.com.au/itm/280489083...84.m1436.l2649
5. I’m stuck for ideas on the back speakers?
Thinking a second Boss amp and ???
6. What speakers are in the rear armrest area of my coupe?
Regards... da j-bro
Old 08-01-2012, 07:54 PM
Fast Bob's Avatar
Fast Bob Fast Bob is offline
Keeping it surreal
You`ll know if you have an HK system because the rear deck speakers will say "Harmon-Kardon" on them. If you choose to keep the stock head unit & amp, you`ll have to be careful about impedance-matching the new speakers so they`ll be compatible with the existing system.
The road goes ever onward....
(R.I.P. Jever)
Old 08-02-2012, 08:27 PM
Alfa.M.twd.2012
Cool
The boss amp mentioned above has the following spec:
Line/Speaker Level Inputs - Separate line and speaker level inputs mean the amplifier can handle high-level signals from receivers lacking RCA outputs.
This means I should not need the "PAC SOEM-4 FOUR CHANNEL PREMIUM LINE OUTPUT CONVERTER" right?
Also with this Amp inbetween my speakers and nav head deck, there shouldn't be a problem with the speakers I choose right?
Regards... da j-bro
Old 08-02-2012, 09:56 PM
Fast Bob's Avatar
Keeping it surreal
All this^^^^^^^^^^^^^^^is marketing gibberish, and contains absolutely NO technical information....
(R.I.P. Jever)
Old 08-03-2012, 02:29 AM
Alfa.M.twd.2012
Cool
Ok fast Bob give me some technical details that will help me set up a killer system.. please..
Regards... da j-bro
Old 08-03-2012, 10:29 AM
Fast Bob's Avatar
Keeping it surreal
It`s not something you can learn in 5 minutes, it requires knowledge & planning. Let`s start with "Impedance matching amps and speakers":
http://www.google.com/#hl=en&rlz=1R2...w=1280&bih=510
(R.I.P. Jever)
Old 08-05-2012, 08:40 PM
Alfa.M.twd.2012
Cool Lesson #1 COMPLETE
So done a quick search and found, "quote"
"On the output side, a loudspeaker may still have a nominal impedance of something like 8 ohms, which formerly would have required having an amplifier output stage carefully matched to 8 ohms. But now with the active output circuitry of audio amplifiers, the effective output impedance may be very low. The active circuitry controls the output voltage to the speaker so that the appropriate power is delivered."
ref: http://hyperphysics.phy-astr.gsu.edu...dio/imped.html
This is for general audio so I'm assuming its relevent to car audio also.
am i ready for Lesson #2 Bob?
Regards... da j-bro
Old 08-05-2012, 11:14 PM
Fast Bob's Avatar
Keeping it surreal
Planning and assembling a system from well-matched components is still important if you don`t want to spend a small fortune and still have it sound good. It takes an expensive amp to handle the really difficult loads without self-destructing.
Lesson #2:
All electrical devices run on smoke....if you exceed their limits, the magic smoke will get out....
(R.I.P. Jever)
sound system
