E36 (1991 - 1999)
The E36 chassis 3-Series BMW was a huge hit among driving enthusiasts from the first moment the car hit the pavement. The E36 won numerous awards over the years it was produced and is still a favorite of many BMW enthusiasts to this day! -- View the E36 Wiki |
Hey guys, I used to have 4 OEM wheels on my 1998 BMW 323IS coupe, and it runs smooth after I balanced them, no matter how fast i drive, there is no shaking on Steering wheel.
Recently, i put 4 after market wheels, 17x7.5 rim with 235/45-17 tire on it. I checked the spacing with my friend, and confirms that there is enough spacing for the new wheels to run. However, here is what happen, after I balanced these wheels at pep boy, my e36 start to shake really, really bad around 60mph. I can't hold the steering wheel even though i use my muscle. Lower than 60mph, everything is great, no shaking at all. and my e36 just finished aliment. Well, here are what i had changed, 1. Left front control arms 2. Right front control arms, 3. L and R control arms' bushings. 4. four new break pads, and rotors. 5. Four wheel balanced 6. Aliment What should i do? my body at All tune and Lube told me that everything under the car is perfect, no obviously problems. WHAT SHOULD I DO???? MAYDAY! feel free to text me at 202 644 3821 |
Where do you feel the vibration? Your hands or your ass?
If hands odds are better than good that it's your tie rods, ass RTAB's. Ed.
“No cop born isn't a sucker for a finely-executed hispeed Controlled Drift all the way around one of those cloverleaf interchanges. Few people understand the psychology of a traffic cop. A normal speeder will panic and pull over to the side when he sees the big red light and start begging for mercy. This is wrong. Contemptuous to the cop-heart. When running along about a hundred and you find a redflashing CHPtracker on your trail you accelerate.” - Hunter S. Thompson, |
More like my hands than ass...
Tie rods then would be where I'd look first.
EDIT: Or ball joints. None of the three (2 ball joints -per side- or tie rods) should have any play in them.
“No cop born isn't a sucker for a finely-executed hispeed Controlled Drift all the way around one of those cloverleaf interchanges. Few people understand the psychology of a traffic cop. A normal speeder will panic and pull over to the side when he sees the big red light and start begging for mercy. This is wrong. Contemptuous to the cop-heart. When running along about a hundred and you find a redflashing CHPtracker on your trail you accelerate.” - Hunter S. Thompson, Last edited by jonesin; 08-01-2012 at 01:38 PM. |
But if a shop did an alignement, don't you think they would have mentioned if the tie roads had play in them?
Just thinking out loud here... |
They should have. Then again, they may have had the 16 year old nephew working that shift... ... ...
![]() When my 318 would shake at 70mph-- I had the front control arm replaced, and smooth riding since. |
Simple, they goofed up the wheel balancing. Take out back and have them re-balance all four wheels.
Sent from my LG Revolution 4G using BimmerApp
Chad // 2001 BMW 740i M-Sport // 2000 BMW 540i Sport // 1997 BMW 328i Premium // ![]() E38 16" Style 5 Basketweaves, M52 Parts, and New Gaskets/Seals for Sale!! PM for info. . |
OEM = no shake
Aftermarket = shake Wheel weights never installed/poor job done on Balance, or your BMW DOESNT LIKE CHEAP. These wheels? http://www.bimmerfest.com/forums/sho...37#post6985046
Hey guys, here is the update, i found out that my ball joints are bad, so i had changed both L and R ball joints with new arms and bushings. after aliment, it sill shaking, but it is much better than the last time.
Help...i can't find any other problems with suspension parts, i will try to balance the tires tomorrow, if it still shaking, i will change back to my old oem wheels. 60 small shaking 70-80 exterlmy shaking 80 and above just small shaking |
100% sure there is no bent rim even the slightest?
I'm pretty much sure that my rims are good,
they are 100% new |
What kind are they? Could always be a defect.
You should switch back to oem rims and see if problem goes away.
Patrick ///98 328i hellrot///BMWCCA#465139 |
What should I do? The seller told me he won't refund at all. |
Get the wheels rebalanced..
Why do you think the seller sold them?
Call him on his sh!t and check the laws in DC you might be able to get the law involved. Did you buy from private seller, or a retail shop? It sounds like the wheels (AFTERMARKET WHEELS) are either cracked & got welded bad, bent, poorly made, or balanced improperly. Take them to a wheel specialist.. Or look in classifieds for BMW wheels F/S near you. I'd burn the bastard down.
The guy who work at pep boys bring me into the service area and let me see how those wheels are balanced, I see that the wheels are being balanced and the computer says 0.00. But after i drive for a while, it shakes again, so i come back to pep boys, when they put my wheels on the balance computer, the computer read it is not balanced. I saw they balanced and the computer read is 0.00, but as long as they put them back on my e36, driver for a while, and re-test them, the computer reading is not 0.00 but 1.75 or 3.75...... Anyway, I will fight for this |
Are the after market wheels you bought for a 3 series or did they come off a 5 series Bimmer?
If they came off a 5 series or they have too large a hub diameter you'll get lots of shake unless you have hubcentric rings to center them on the hubs of the car even if they're balanced correctly.
^ valid.. and overlooked.
