What these codes means ? plz help
Hello gentlemen,
last night I had trouble with my car and I scanned it with with my computer. This is what came up.. CB Fuel Trim bank 2 control limit CA Fuel trim bank 1 control limit E3 Fuel trim bank 1, permissible range exceeded E4 Fuel trim bank 1, permissible range exceeded Tried to erase but it came up again, also RPM is being funny not regular. plz help Thanks |
you most likely have a vacuum leak.
2001 540i - Orient Blue M5 bumpers, wheels, mirrors S/C, water/air IC A1 Headers, Random Technology Cats, Eissenmann Exhaust 3.15 diff, evosport power pullies Koni Sports, Eibach Springs/Sway Bars |
Thanks, but where should I look ? any ideas ?
I forget to tell that when I disconnect the MAF plug while the car is running and reconnect it back the car shutdown. |
I had a vacuum leak and it took me more than a year to find it (elapsed time).
I only found it with a smoke test. - How to locate all problematic (between 1/8" & 9/32" ID) 3.5x1.8mm, 3.3x1.8mm & (between 17/64" & 9/32" ID) 7mm ID vacuum tubing (single material), vacuum hoses (multiple material), 3.3mm OD curved vacuum pipes (rigid tubes), 3.5mm & 7mm ID vacuum endcaps (closed end) & 7x3mm manifold o-rings (1) & 7.52X3.52mm and 9.2X2.8mm fuel injection o-rings (1) & gaskets (1) on the M54 engine & where in the USA to get new vacuum tubing & vacuum caps (1) & what SAE sizes to get for all the metric M54 engine vacuum tubes, hoses, pipes, and caps (1) & correcting the F-connector errors in the realoem diagrams (1) & finding the ends of hard-to-locate vacuum tubes (1) & sorely needed clarification on how the M54 CCV vacuum port works on the M52 CCV valve connection to the fuel pressure regulator connection (1) & how to make, borrow, or buy lean-condition misfire test tools to test for vacuum leaks & lean conditions (1) (2)
