E28 (1982 - 1988)
Old 08-04-2012, 07:12 AM
thexpbogger thexpbogger is offline
Mein Auto: e28 1987 535i M Spec
Which bolt - steering column
OK
Is it possible for anybody to include a photo of the actual bolt that requires loosening or removal to make the steering column on my 1987 535i collapse inwards as it is way too far out and uncomfortable steering with it just about under my chin!!!!!!! I have tried the slide control under the column but does allow for any movement for in or out?????
thanks and waiting!!!!
Stephen
Old 08-04-2012, 10:49 AM
catso's Avatar
catso catso is offline
catso
Originally Posted by thexpbogger View Post
OK
Stephen
I don't know of any one particular bolt, but the lever under the column is the correct mechanism for adjusting the length of the column. Pull it all the way out and try working the column back and forth. It's probably stuck from rust or corrosion. Maybe some spray lube might help free it up.
![/I][/FONT]
Old 08-05-2012, 04:48 AM
Hey CATSO,
This is what was replied to my same request on another BMW FORUM!!!!!!
Thanks for the reply
Stephen
Name:	e28 column nut.jpg
Old 08-05-2012, 06:35 PM
south26 south26 is online now
Mein Auto: 535i 1989
Hi, if you loosen that nut it will not help you with the steering wheel.
Andy
