E90/E91/E92/E93 (2006 - 2013)
The E9X is the latest evolution of the BMW 3 series including a highly tuned twin turbo 335i variant pushing out 300hp and 300 ft. lbs. of torque. BMW continues to show that it sets the bar for true driving performance! -- View the E9X Wiki |
Driver's mirror angle
Does anyone else find the range of vertical angle adjustment to be all wrong in the e90 driver's side mirror? I'm not a tall guy but I have to hunch my head down to see the tops of cars on that side. At the low end of the motion I can see asphalt 2 feet behind my shoulder, which is no use.
I shimmed the motor unit against the casting it screws into and got maybe 8 degrees more viewing angle on the upper edge. If anyone is interested I will write it up, PM me. It's not that hard; you start by popping the mirror out with a bent screwdriver. The rest of it comes apart in ways you can see.
-Wankel Boy 2007 335i 1991 300ZXTT 5 speed conversion "But sweetie, any additional costs from the high pressure fuel pump will be more than offset by the mileage increase from direct injection." |
Looking to purchase a 06 330 and noticed this mirror issue. Could not adjust the mirror properly, not enough range. Current owner is short and did not notice the issue. Is there a simply fix other than shimming? Would hate to buy and then need to replace an expensive mirror/housing.
Thanks Dan |
Hate to tell you guys, but you are the only two I have seen have this issue in all the time I've been on Bimmerfest and in the E9x forum, since November of '05.
Keep Right, Except to Pass Then & Than usage - "It was hotter than ever (comparison). Then (time) it got cool." 2006 330i Sonora w/ ActiveAutoWerke flash tune - I like it! 2004 330i ZHP Imola/NB - missed 2000 328i TiAg - gone but not forgotten BMW CCA member #388003 - www.bmwcca.org Use me as a referral, you could win a one day ///M Driving School! |
Are you aiming the mirror into your blind spot or looking at the rear end of your car?
Laser ___________________________ 2011 535i Black Sapphire Metallic, Sport, Euro Del (ret) 2009 328i Black Sapphire Metallic 2007 Honda S2000 Berlina Black |
Good question.
I always use the side mirrors when backing to locate the car and typically set the mirrors to show a very small amount of the side of the vehicle. The mirror will not adjust enough to allow anything but a view of the ground near the rear tire. Adjusting the mirrors in my 325, M3, and X5 is not a problem. Is there a problem with the car I am looking at or is this a e90 characteristic?
Thanks Dan |
Next time you're at the dealer, try the post LCI mirrors -- they're significantly larger -- and compare.
E91 "Classic" BMW inline six, six-speed manual transmission, Alpine, Terra, Xenons, ZSP, ZCW, ZPP, PDC, CA, alarm, M shifter and M brake handle, Euro rear fog light switch, Euro aspheric mirrors, rear power outlets, Garmin nüvi custom cupholder mount, Lidatek, V-1 built-in remote display, tire pump, jack, floor mats. |
I couldn't say. I keep my mirrors adjusted to eliminate my blind spots while driving and I do the old fashioned arm on the top of the seat back and look over my shoulder for backing up. I can tell you that my mirrors give me all the rear vision I need while driving.
I have the same issue with the driverside mirror...have it tilted out more horizontally than i'd like to get a higher vertical view
Sent from my DROID RAZR using Bimmer App |
Black 325i- I will PM you a picture regarding your question. I built up the casting with 2 kinds of epoxy.
tturedraider, what can I tell you? Laser- I like them outward just past the point where I can see the rear corner of the car and that was always possible. It was just generally too low.
- Tom ------- Mine: 2006 Z4 Roadster (E85) | Interlagos Blue Metallic | Black Extended Nappa Leather | Carbon Leather Trim | Purchased 7/19/12Hers: 2011 335is Coupe (E92) | Le Mans Blue Metallic | Black Dakota Leather | Dark Glacier Aluminum | 6MT | ED 5/12/11 BMWCCA #444696 - Click to join and a chance to win a 1-Day M School at the BMW Performance Center!
![]() I took the car to the dealer, who of course couldn't reproduce it. It started after I used the autofolding mirrors on my '06 330i. I had to hunch down to see well out of the driver's side mirror. After the dealer coulnd't fix it, I took it home, looked at the range of motion, and noticed that the mirror wasn't angled the same as someone else's 330i. I took it apart and found that the collars that spin the mirror were not aligned. I realigned them and the problem went away. I should clarify... the mirror housing was able to extend out to its proper location which allowed the mirror itself to utilize its full range. It was partialy retracted (maybe a half inch) and couldn't till up as far as it should have. I have had no issues with my post LCI '09.
__________________________ 1993 325i - Gray/Gray (sold) 2004 325Cic - Gray/Gray (sold) 2005 330Cic White/Saddle (sold) 2006 330i - TiAg/Black (sold) 2009 335i E90 M Sport Space Gray/Chestnut 2010 328i E93 Alpine White/Saddle (sold) 2012 X5 35d Black Sapphire/Cinnamon Last edited by rgzimmer; 08-03-2012 at 09:02 AM. |
To adjust the driver side, put your face against the window, turn the mirror out until you can barely see the side of the car. To adjust the passenger side, position your eyes right at the center of the rear view mirror, then adjust the pass side out until you can barely see the side of the car. When you are in the normal driving position, the two side mirrors will be far out. You won't see your car at all. But you can see blind spots by looking at all three mirrors. It takes some time to get used to this arrangement. Still turn your head before merging or change lanes though to be safe. |
rgzimmer
I have shimmed the mirror drive motor several different ways to stop the mirror glass from jamming into the housing, although improved still not corrected. Your adjustment might be what I to resolve. Can you provide more detail or pictures of what you adjusted? Thanks Dan |
I don't know if this will help, but when i got my 325xi 06 the drivers side mirror would not adjust enough. So I took it to my indy shop and they found it to be a recall and fixed it. Now it works great.
Sent from my SAMSUNG-SGH-I997 using Bimmer App |
Do you recall what was done? I looked for applicable TSB's/recalls and could not locate any information. |
Heres the TSB on the folding mirror issue. Hope it works!
SI B 51 31 09 Body Equipment September 2009 Technical Service SUBJECT Power Fold Mirror Position Incorrect MODEL E60, E61 (5 Series) equipped with power fold mirrors E63, E64 (6 Series) equipped with power fold mirrors E82, E88 (1 Series) equipped with power fold mirrors E85, E86, E89 (Z4) equipped with power fold mirrors E90, E91, E92, E93 (3 Series) equipped with power fold mirrors F01, F02 (7 Series) SITUATION One or both mirrors appear to have folded out further than the standard position. The incorrect position of the mirror housing is typically not visually noticeable and as such, the customer typically states that the mirror glass is not in the stored position. Folding the mirror in and out does not restore the correct mirror housing position. CAUSE The mirror has shifted outward from its standard home position. The new position is now stored as the home position. CORRECTION Do not replace any parts. Reset the mirror home position using the following procedure. PROCEDURE 1. Fold the mirror in using the power fold button on the door switch block. 2. Grasp the folding part of the mirror and fold it outward manually. The mirror housing will disengage from the mirror base and will now be in the breakaway position. 3. Operate the mirror via the power fold button. The mirror will now fold out past the expected end stop. 4. Operate the mirror via the power fold button again to fold the mirror in. When the mirror is fully folded in, the motor will continue to run until a clicking and/or popping sound is heard. This sound is the mirror housing resetting its position. 5. Fold the mirror back out, using the power fold button to ensure it has folded out to the correct position. |
That solved the problem. This forum is full of good people and info. Dan |
I tried that with my driver's side mirror but didn't work. In step #2 I understand I should fold outward manually until normal position, correct? After I do this, step #3 moves that mirror all the way forward (towards hood) and step #4 folds it to normal position instead of expected fully folding it with clicking noise per the TSB.
Are there any other ideas? I had this problem 3 years ago when the car was under warranty. Dealership re-programmed and it got the mirror to almost the right state. But it didn't seem it was the right fix because the issue re-appeared and gradually gets worse bit by bit. I think it's been too long ago to have dealership fix it as a part of that warranty job. |
I should have explained that my problem is that the driver's mirror stops half an inch further than it's supposed to.
I tried the TSB again and got the expected movement but still no luck fixing driver's mirror. While the passenger side mirror makes loud click noise in step #4 as expected, driver's mirror doesn't. Interestingly, in step #3, my driver's mirror goes much further forward towards the hood than passenger's. Does anybody know if this is a mechanical or programming issue? |
