Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M3 & M4 > E36 M3 (1995-1999)
E36 M3 (1995-1999)
Old 06-02-2012, 12:33 PM
jimjim805 jimjim805 is offline
Mein Auto: 1996 M3
Question Rattling Noise
Hi all,
For a few months now I've been getting a noise that I can really only describe as a "tink" or "marble hitting a tin can" on my 96 m3. I've had the car for a year and a half now (2nd owner), the engine and drive are bone stock as far as I know, and the car has 132k on the clock.
I hear the noise when engaging or disengaging the clutch in any gear, when the car changes momentum. I don't hear it engaging / releasing the clutch in neutral. Since I don't hear it out of gear or rolling in neutral, I'm not inclined to believe it is any of the components behind the transmission.
Previously I've examined the flex disc, the drive shaft, differential, center support bearing, and rear axles. Separately, the Vanos has been replaced recently and the noise I hear now is quite different from that noise.
My best theory right now is there is slop or a loose component on either the clutch/flywheel or transmission. I don't have too much experience diagnosing manual transmissions, but I have heard flywheel noise is not uncommon. Two German mechanics (which I believe have sufficient experience working on these cars) do not believe the noise is indicative of a mechanical problem, and without pulling the clutch/transmission I'm not sure if I can further diagnose it. Obviously I'd prefer not to spend the time, money, and effort pulling the clutch/flywheel if I can avoid it.
Has anyone else had these symptoms on their e36 or have any insight on what the problem may be?. I appreciate any advice you may have, and thank you in advance for the responses.
Old 06-06-2012, 11:08 AM
petriej's Avatar
petriej petriej is offline
Cruising 280 Top Down
I have similar symptoms, but I have yet to discover any cause. I'm interested in what you find and I'll post back anything I discover.
GGC BMW CCA #443004
Join the BMW CCA!
Originally Posted by hornhospital View Post
Jared, why don't you just put "It's Giubo" in your sig? Save a lot of typing.
Originally Posted by e36 miguel View Post
this jared guy sounds intimidating lol.
2005 X5 4.8is Le Mans/Black/6spd Steptragic SOLD 3/2016
1999 M3 Cabrio TiAg Metallic/Dove Grey/Black 5 Speed Manual FS
1997 328iC Schwarz II/K/K 5MT SOLD 5/2012
2004 645Ci Mineral Silver Metallic/Black 6MT RIP 04/2011
Old 07-30-2012, 03:57 AM
Dmharvey Dmharvey is offline
Mein Auto: E36 M3 Coupe
My car had a similar sound when the RTABs were bad, happened when I sped up/slowed down or went over a bump. Might be worth checking.
Old 08-05-2012, 09:06 AM
X3-terrestrial's Avatar
X3-terrestrial X3-terrestrial is offline
Aficionado
Mein Auto: '05 X3, '02 M3, '91 E30
Is it coming from under the car or the front of the engine?
"If everything seems under control, you're just not going fast enough"
-Mario Andretti.
___________________
River City Bimmers BMW CCA
2005 X3 3.0i ZPP, Htd seats, Htd strng, Black Sapphire on Terracotta.
2002 ///M3 Coupe, Steel Gray Metallic on black leather, HK, three pedals.
1991 E30 325ic, AW, Black Leather, Black top, Three Pedals.
clutch, flywheel, manual transmission, rattling noise, transmission
