Old 12-05-2003, 01:32 AM
Ron Stygar's Avatar
Ron Stygar Ron Stygar is offline
19,585 Miles
Mein Auto: Z4 M Coupe 6LL93033
S54 Coolant block drain
Normally (my experience) the coolant block drain is between cylinders 3 and 4. Not so on the S54 after spending some time looking after an oil change.
I found it under cylinder 2. Without opening it, I'm pretty sure that it is. I purchased the bolt and it matches the one in the following pic. The bolt in the pic also has a gasket ring under it (Bingo).
Looks like I can add the eliminate the mess valve.
http://www.fumotousa.com/nseries.htm
Old 12-05-2003, 10:29 AM
scy scy is offline
Mein Auto: '00 Z3 Coupe
Hi Ron,
Did you installed that N-Series Valve on the oil pan in your Coupe? How did it work out? The manufacturer doesn't recommend the N-Series Valve for cars with low ground clearance, but it seems like a good product for my Coupe. I might put one in next time I change the oil.
How did you torque the valve properly? It doesn't look like it will accept a standard socket driver.
Thanks.
Old 12-05-2003, 10:34 AM
JonM's Avatar
JonM JonM is offline
Moderator
Mein Auto: 01 Mc, 08 M3, Motorrad x2
Originally Posted by scy
Hi Ron,
Thanks.
There is no need for it on the oil drain in my opinion. The oil drain bolt on S54 is easy to get to and it drains nice and clean. The reason why it's nice on the coolant drain for the block is because when you drain the block, coolant goes all over the place. Onto headers, brakes, trim, lines, everything. Horrendous mess. Way worse than the coolant drain on the radiator or the oil drain bolt. Or on any other drain bolt for that matter.
I would assume you would install the stopcock valve Ron posted with a crowfoot wrench. Then you can get the right torque, if you correct for it.
Jon Maddux
08 E90 M3 | 06 M Coupe | 01 M coupe | 99 M coupe
http://coupenut.blogspot.com/
http://x5nut.blogspot.com/
Old 12-05-2003, 11:44 PM
Ron Stygar's Avatar
19,585 Miles
Hi Ron,
Thanks.
I had the normal one on my '86 325 and a '84 528 that I used to take care of. I agree with Jon's comments.
I'm going to order a type N, F106N, M14x1.5 Monday to see if it will fit replacing the stock coolant plug. The type N will stick out 1.125 inches more than the stock plug. Will also call the main place for the recommended torque value.
Old 12-06-2003, 12:40 AM
01silber's Avatar
01silber 01silber is offline
Im here
Send a message via AIM to 01silber
Mein Auto: 2001 Z3 3.0i
Question
Ron
Since we are talking about coolants, what is your opinion on me changing my coolant, I have 3600 miles on it, build date 07/01
should I change it or should it be ok for awhile. it is the factory filled fluid in it now
Old 12-06-2003, 01:34 AM
Ron Stygar's Avatar
19,585 Miles
Originally Posted by 01silber
Ron
BMW says every four years.
Old 12-06-2003, 12:34 PM
01silber's Avatar
Im here
Thank you
Old 12-12-2003, 12:41 PM
Ron Stygar's Avatar
19,585 Miles
More block pics plus
The following are pics from the M brochure showing the drain plug.
Called Fumoto looking for a a type N one for the radiator drain which is a M10x1.5. They have a prototype M10 but the pitch is 1.25.
Will try to get a blank from them and have it threaded.
Ordered the M14x1.5 one for the block drain from Gomco Sales & Marketing in NY. 1-800-793-0154. Part number F106N $25.60 retail.
There are other distributors listed on the web site depending where you are.
Old 07-22-2010, 07:57 AM
dwm's Avatar
dwm dwm is offline
Send a message via AIM to dwm Send a message via Yahoo to dwm
Mein Auto: 2002 M roadster
Dragging up an old thread...
Ron, did you ever figure out if the Fumoto valve with nipple had enough clearance?
Daniel
2002 M roadster
Old 07-22-2010, 09:09 PM
Ron Stygar's Avatar
19,585 Miles
No. When I did the water temperature sensor there, I didn't.
Looks like it will work. I'll try to do some pics tomorrow.
Old 07-22-2010, 11:30 PM
dwm's Avatar
dwm dwm is offline
Thanks, I figured that you hadn't done it due the temperature sensor taking priority.
I'm probably going to try one. Do you still have the valve? Is the nipple threaded into the valve? If it is, do you know the thread on it? It might be handier for me to be able to thread in a Drainzit hose or the like instead of using the nipple. It's been a couple of years since my last coolant drain so I'm not remembering clearly if that's going to be more work than I'd like. At the moment the MINI is occupying my jack and stands (power steering pump replacement and some other underside maintenance) so I can't easily look.
It's too bad Fumoto didn't do an M10x1.5 with nipple, it'd be nice on the radiator.
Daniel
2002 M roadster
Old 07-24-2010, 04:45 PM
Ron Stygar's Avatar
19,585 Miles
Looks like it. The inside meets the ball and shell.
Don't know if you can get it back right.
Looks like it will fit on the S54.
ID:	239621   Click image for larger version
ID:	239622   Click image for larger version
Old 07-25-2010, 12:48 PM
dwm's Avatar
dwm dwm is offline
Thanks Ron!
Yes, it looks like I wouldn't want to remove the nipple. Not a big deal, I was just curious. I'll order the valve next month when I'm due to change my coolant.
Daniel
2002 M roadster
Old 07-08-2012, 07:54 PM
inTgr8r's Avatar
inTgr8r inTgr8r is offline
Ron, do you recall where you sourced the M14 1.5 sender adapter?
That looks like a good solid one.
Old 07-09-2012, 06:22 AM
Ron Stygar's Avatar
19,585 Miles
Old 07-09-2012, 09:56 AM
inTgr8r's Avatar
thanks
Old 07-09-2012, 10:47 PM
Randy Forbes's Avatar
Randy Forbes Randy Forbes is offline
Investigative Tinkerer
Mein Auto: ///Motorized Vehicles
Looks like it's just the OE drain plug drilled and tapped to hold the sensor. You could make that in your sleep
Randy Forbes
1957 Austin-Healey 100/6 Wine Red
1961 McCulloch R1 go-kart Screaming Yellow
1999///M Rdstr Cosmos Black Eurosport Twinscrew S/C
1999///M Coupe Estoril Blue Eurosport Twinscrew S/C
2001///M Rdstr Steel Gray
2011 X5 35i Sport Deep Sea Blue/Cinnamon
Old 08-06-2012, 02:36 PM
inTgr8r's Avatar
lol.... true, except no longer have a drill press.
I found a fitting from auto meter.
