Old 08-04-2012, 05:39 AM
brewder brewder is offline
Mein Auto: '07 328xi
"Damp" smell when A/C turned on
Hello,
I have noticed a damp sort of smell recently when we turn on the A/C... We bought the car with 63k on the odo and it currently has 72k... So we have had it now for about 7 months and its been garage kept ever since. I have replaced the micro filter back in February....
Any suggestions on where I could spray some lysol and/or febreeze to try and stop the smell? It only lasts for 5 seconds or so when the AC first comes on, then it's gone...
I really don't think we have a leak anywhere....but I suppose that might not be 100% true..
//Brew
('07 E92 328xi / '08 E83 X3)
Old 08-04-2012, 08:17 AM
X3-terrestrial's Avatar
Aficionado
Mein Auto: '05 X3, '95 M3, '89 MkI
Search this forum for "a/c smell", you'll find plenty of info. The Klima-cleaner treatment seems to work well.
-Mario Andretti.
___________________
River City Bimmers Chapter
1995 ///M3 Coupe, Lux, MT, Htd seats, Cosmos Black on Black.
Old 08-04-2012, 01:04 PM
PSUEng PSUEng is offline
Mein Auto: 2007 X3
Change your cabin filter. Get the Bosch charcoal activated one on Amazon. $23.
Old 08-06-2012, 06:12 AM
Aficionado
Cabin filter won't eliminate this type of odors, this is caused by moisture/mold in the evaporator core.
-Mario Andretti.
___________________
Old 08-06-2012, 06:42 AM
john@eac john@eac is offline
Past Sponsor
Mein Auto: Many
Take a look and make sure water is draining from the evaporater . (water dripping under the car when the a/c is running) If it is plugged up and not draining you will have a hard time getting rid of the smell.
Old 08-06-2012, 08:59 AM
08X3si 08X3si is offline
Mein Auto: 2008 X3si
I think mine is plugged. How can you unclog? Thanks
Old 08-06-2012, 09:23 AM
Past Sponsor
Mein Auto: Many
The best way is if you have an air source like an air compressor that you can use to blow air in the drain tube. If you don't have air then you need to stick something in the drain to try to open it beiing carefull not to go in to deep. You should be able to find the drain on the firewall toward the bottom.
Old 08-06-2012, 02:50 PM
Mein Auto: 2007 X3
So if caused by mold growing on the evap, running the blower for two or three minutes after turning off the AC before turing off the car should help dry the evap. This is what I do in all my vehicles.
Old 08-06-2012, 05:52 PM
for the life of me, I could not find the drain lines where they come out under the car. spent 30 minutes. anyone have experience with this?
Old 08-06-2012, 08:16 PM
Aficionado
I don't think it is visible. Is it not dripping at all?
Found the link for the odor eliminator: http://www.1z-usa.com/einszett_klima_cleaner.html
-Mario Andretti.
___________________
Old 08-07-2012, 07:36 AM
swapsafari swapsafari is offline
Mein Auto: 07 BMW X3 3.0si Black
I have had the issue of Damp Smell in the past and used Klima Cleaner as per the recommendations here. It worked for me. Give it a try!
