Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 3 Series / 4 Series > E30 (1982 - 1993)
E30 (1982 - 1993)
Old 08-06-2012, 09:01 AM
Girlwithabimmer Girlwithabimmer is offline
Mein Auto: 1987 BMW 325i
Oil change?! Help please!
I just bought an '87 e30, It has high miles and the oil is black!This is my first bimmer and I'm not sure what kind of oil to use. The car does have high mileage and after a couple minutes of driving it puts out a little bit of smoke. Starts up just fine though. Please help!
Old 08-06-2012, 09:41 AM
Pennyw1se Pennyw1se is offline
Mein Auto: 1988 325e
I'd go with conventional 20w-50. I normally use Castrol GTX High Mileage 20w-50.
Old 08-06-2012, 10:22 AM
BmwMan92's Avatar
BmwMan92 BmwMan92 is offline
I <3 my E34
Send a message via Skype™ to BmwMan92
Mein Auto: 1985 318i// 1988 325e
Isn't that pretty heavy?
Brandon
http://www.facebook.com/brandon.m.fore
Originally Posted by v8bimmer View Post
I just dont see any other logical way around this problem.
Old 08-06-2012, 11:18 AM
Yes, and it's what's recommended for these older engines, especially during the summer.
Old 08-06-2012, 02:08 PM
a228380 a228380 is offline
Mein Auto: 1991 325i
I run 20-w50 year round but i am in florida for oregon maybe 20-40 in the summer but I would not in the winter, i would run 10-30 in the winter.
Old 08-06-2012, 02:36 PM
BmwMan92's Avatar
I <3 my E34
Well washington is a mindf*ck for weather so i just run 10w-30 constant
Brandon
Old 08-06-2012, 04:11 PM
yes 10w-30 year round should be good. i used to use 10w-30 but my old girl valve taps and the 20w-50 seemed to help and since i am in florida the extra wieght is not a problem in the winter months of 60 degrees.
Old 08-06-2012, 04:21 PM
Terrains's Avatar
Terrains Terrains is offline
Mein Auto: 1987 BMW 325e
I thought the w in oil stood for winter? As in, it would have a viscosity rating of 10 in cold weather, and 30 in normal/hot weather
Old 08-06-2012, 04:31 PM
correct i wanted a heavier wieght for my car
Old 08-06-2012, 06:44 PM
downhiller's Avatar
livin large
you should actually be running 10w40. but ive only been able to find that at bmw dealers. i ran 15w40 for winter and 20w50 for summer in colorado. as long as you let the engine warm up for a few minutes in the morning, it works pretty good
Old 08-07-2012, 02:10 AM
Nick323's Avatar
Nick323 Nick323 is online now
Nick's Toys
Mein Auto: 323i E30 2-door
Cool Flushing out old oil
I would first flush the engine with Wynn's engine flush !
i.e. pour it in & drive it for about a 100 miles without Reving the engine too high. Why not pour in WM Penn valve ease into the tank, whilst you're at it.
I am not a fan of additives, but these products have prooven themselves to me over 20 years.
Then you properly flush your oil when hot & pour in a oil formulated for old engines, such as Caltex Delo Gold 15W40.
I am not advocating the use of these liquids, but that's what we can get here
If you now remove the tappet cover, you should see little sludge remaining
If it is sludge that held the motor together, then you can expect a spun bearing in the near future
I have already removed 40 year old tar from a motor with Voco or Petrolium, but that should hardly be neccesary in a engine that runs
Don't take life too seriously; no one gets out alive !
Old 08-07-2012, 07:29 AM
Tkaczuk's Avatar
Tkaczuk Tkaczuk is offline
1 John 1:9
Mein Auto: E30, Rabbit GTI
Well I live in PA and used castrol gtx highmilage in my e30 with the 2.7. In warmer Places like phenix or florda it makes sense to run the thiner oils but in the colder weather up north 10w-30 or 10w-40 would be my recomendation atleast to use in the colder months.
Old 08-07-2012, 08:09 AM
hornhospital's Avatar
hornhospital hornhospital is online now
D'oh, You kids!
Mein Auto: 1995 318is / 1993 325is
You should be running thicker (higher weight) oils in hot weather, not thinner. 15W-50 Mobil1 or 20W-50 RP is what I run year round here in mostly very hot south Alabama.
Quotes to live by:
Ken Kanne, Silverhill, AL, Honorary Forum Grandpa/Craigslist addict/Hoarder of all sorts of stuff
BMW-CCA #441426
1995 318is "Bebe"; 1993 325is "Elvira" 1985 635CSi "Katja" 1984 633CSi "Sylvia"
I NEED A NAP, DANG IT!
