Old 08-07-2012, 09:40 AM
three28iguy three28iguy is offline
Mein Auto: 2000 328i
Need a used transmission ASAP (Auto)
well just as i was getting my engine running correctly, my reverse goes out on me. anyone know of a good source to get a used auto trans from? or would it be more practical to just do a manual swap?
Old 08-07-2012, 10:13 AM
NEVERMIND i found out it is my TCC and PWM solenoid because i have the GM transmission it only acts up once in a while the solenoids are bad because it will engage into reverse and then not engage sometimes. now my new question is where to get these solenoids??
Old 08-07-2012, 10:18 AM
crowz's Avatar
crowz crowz is offline
Mein Auto: 2000 323i, 97 528i
http://www.sonnax.com/
Old 08-07-2012, 02:57 PM
Starless Starless is offline
Mein Auto: 2002 325i Auto
I'd look into getting an entire valve body replaced, the problem could be more than a solenoid. I have a link in my signature that can be helpful
Old 08-08-2012, 06:33 AM
thank you for the advice, but im going to just try replacing the solenoid first because i really want to do minumum and spend minumum i am also replacing the gasket and filter for the trans.
Old 08-08-2012, 08:19 AM
Good luck, let us know how it works out for you. The solenoid seems to be a hit or miss solution. Hope it will help your non reverse. Worth a try.
Old 08-08-2012, 08:49 AM
yeah from what i've read on this thread http://forum.e46fanatics.com/showthread.php?t=706809 it seems to me that the solenoid will fix my problem because i have the same symptoms this guy had. and i believe even taking the tcc solenoid out and cleaning out the screen and a fresh fluid change could also fix the problem.
