Old 08-05-2012, 12:26 PM
Droz23 Droz23 is offline
Mein Auto: 2003 325xi
E46 engine hissing on start up
My 2003 bmw 325xi is hissing when I start it up. The check engine light came on and I'm assuming that it is relating to this problem. Any suggestions what the hissing noise could be? It sounds like it is primarily coming from the driver side towards the center of the car. Right above the oil dipstick. Please let me know with any suggestions.
Old 08-05-2012, 12:27 PM
sa220 sa220 is offline
Mein Auto: 94 325i
I'm new to BMW's but what u described, from other cars it would be a vacuum leak possibly
Sent from my Galaxy Nexus using Bimmer App
Old 08-05-2012, 12:33 PM
thanks, is this an easy fix?
Old 08-05-2012, 05:15 PM
jonathan2263's Avatar
jonathan2263 jonathan2263 is offline
Cogito Ergo Zoom
Mein Auto: 325iT
Step 1: get it scanned for codes to find out what the CEL means.
Hissing from the top, front left side of the engine could easily be a torn intake boot. A common issue and a cheap and easy DIY.
http://www.facebook.com/home.php?sk=...?id=1338939628
"I May Be Going To Hell In A Bucket But At Least I'm Enjoying The Ride"
Old 08-06-2012, 01:01 AM
thank you. i also checked this evening when i remove the disa valve sensor from the disa valve the hissing noise stops. and when I replace the sensor it continues to hiss. Could it just be the disa valve or its sensor?
Old 08-06-2012, 09:03 PM
Mein Auto: 94 325i
Yea
Old 08-07-2012, 04:40 PM
Can the disa cause sputtering, and stalling of the engine?
check engine light, e46, engine, hissing, noise
