epic fail... DSP amp installation must be the holy grail of Google.
used yellow/red - grey/brown left, blue/white - blue/brown right. Amp remote to the white. Amp power LED is lit, 50amp @ battery is intact, t-taps secure, all contacts solid. ARGH. anyone have this wire color info handy? I have been on like 35 conflicting pages today. Last edited by eohagan; 08-07-2012 at 05:17 PM. |
still reading - seems i may need to get a plug to feed my Xplod's HIGH LEVEL INPUT from the post-DSP-amp sub leads
http://www.bmwtips.com/tipsntricks/s...les/wiring.htm
or try looking here best DIY!! http://www.bmwtips.com/tipsntricks/
00 BMW 528ia Sport M5 F+R Bumpers, M5 Mirrors with OEM setup, M5 rear sway bar, Cluster Rings, 03 Business player with AUX input, HID fogs slim, OEM 01+ Hella headlights, EAC Aluminum Adjusters, FX-R low beam retrofit, Umnitza VXX 10w LED Halos, Hella Euro Celis Retrofit Kit, Koni yellow shocks adjustable, 19" M6 Reps, Full LEDs. ![]() |
thanks man, and I've been there ..
1st link is non-DSP, 2nd link links to a ****load of bimmer.org posts that died years ago :/ |
since i disconnected to factory nokia 'subs' should i be using those wires, or the rear midrange wires?
high-level sub signals to sony amp... nada. Power LED still on, love/hate right now. Made a troubleshooting appt at local stereo shop for tomorrow, grudgingly.
are u sure ur amp is working ? check the fuse on the amp check ur ground and positive leads did u put a fuse on the positive lead coming from the battery if so check to see if that fuse is good
_______________________________________ |
sorry just reread ur post sounds like what u need is a line output converter instead of running it to the high output run the factory wires to the line output converter or loc then run the RCA wire to the amp
Here`s an image of what it looks like try and get this brand its really good quality it what we use at the shop i work for
Haha, that's the exact product I worked in installing yesterday. Never got sound so I pulled it. Been drinking enough tonight to be less than effective so I'll take the LOC to the shop in the morning...
so, i paid $50 to have it hooked up - they fixed my ground, fixed the 2 subs being out-of-phase, and 'tuned' it ... and it sounds like crap. Told me because the amp sucks and the BMW trunk is so insulated (need a mono block for $300) it'll never sound good. Insulation part makes sense, but I've had this setup in a '93 integra, '06 silverado (different box) and '97 CL and it was LOUD. Is this guy full of crap?
my wagons faster than yours
Ah
Xplod '1200w' (old, like 10yrs old red X version) 2 sound stream SPL 12's 4ga kit 50amp fuse |
And they ended up using the high level input on the amp. If I fade left or right the subs get louder but they're crap quiet in the center...
