Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 6 Series > F06 Gran Coupe (2013 - Current)
BMW's entrance into the 4 door coupe segment to go head to head with the Audi A7 and MB CLS
Old 08-04-2012, 09:06 PM
GirlLuvMyBMW640's Avatar
GirlLuvMyBMW640 GirlLuvMyBMW640 is offline
BeachBitch
Mein Auto: 2013 640i Gran Coupe
USB Flash Drive Plugin
So I bought new Sandisk flash drive so I could plug it into the USB slot in the glove compare. I downloaded some music from CD from my iMac on to the flash drive. When I put into the slot and select external Devices front or if I put it the center console where I normally put in my iPhone it tells me no data found. Do I have to format the disk? I am sure I have either done something wrong or have not done something. If anyone can help that would be great. Thanks in advance.
Old 08-05-2012, 08:39 AM
Leslierc's Avatar
Leslierc Leslierc is online now
Sejanus
Mein Auto: `11 MSport 750ix/`08 135i
Did you check to see if the music was successfully downloaded onto the flash drive? If it did, then there shouldn't be a formatting issue. In my 7 I had a USB slot in the armrest and that's where I connected my iPod. Have you tried connecting your flash drive there? Also, it might be better to use an iPod if you have one...album artwork appears on your information screen when you connect using the white Apple cable.
2011 Panamera 4S...GT Silver / Espresso
2012 Mini CooperS convertible
2008 135i Convertible - Sparkling Graphite Metallic
Prior BMWs: `05 645CiC; `07 650i; `08 M6 convertible; `11 750ix MSport
2004 GX470
Old 08-05-2012, 08:58 AM
mjrbimmer335i mjrbimmer335i is offline
Mein Auto: 2009 BMW 335i
I have had this problem as well. When I plug in my iPhone it says that it's unsupported. So I transferred music from iTunes to a flash drive and plug it to the USB in my console. The music is there just not really in the right place it seems and it doesn't play. I'm thinking the music files transferred as the wrong type?..
Speaking of music, my car is an 09 335i and has iDrive. Would it be Sirius/XM capable?
Old 08-05-2012, 11:50 AM
BeachBitch
I spoke to a friend that works at Apple (Tech Guy) He told me that when you copy a CD you need to first copy to iTunes. Once you do that you need to go into iTune preference > General> 3rd section down > "When you insert a CD" you will a drop down menu. Select in menu select "Ask to Import CD". Then open "Import Setting…". Select "MP3 Encoder. Go into Finder select Music find the CD then drag in USB drive. This is all being done on an iMAC. I have no clue whats needed on a PC based computer. I hope this helps.
Old 08-05-2012, 11:54 AM
What if it's all purchased from iTunes instead of from a cd?
Old 08-05-2012, 01:13 PM
BeachBitch
I am assuming as long as it's converted into an MP3 format within iTunes it's good to get put on a USB drive and put into the AUX front input. Don't hold me to that. Just attempting to use the logic side of my brain. On a Sunday that can be pretty demanding. So try it at your own risk. Tomorrow logic has to be in play or I better not show up for work!!!
Old 08-05-2012, 02:55 PM
Thanks for your help!
Old 08-10-2012, 05:25 AM
f01driver f01driver is offline
Mein Auto: 750i, S5
I think the USB stick needs to be formatted in fat32 so a USB stick from a Apple won't work. And some USB sticks for whatever don't work, I've had issues with some of my USB sticks.
2011 750i
Old 08-10-2012, 09:47 AM
BeachBitch
Update: My USB works now that I simply converted the songs to any mp3 format. I could have easily put them on my iPhone but I just wanted to segregate this particular music collection to the USB device. It only has 25 songs and I know exactly where they are without having to search for a playlist in the iPhone. Plus I like to know everything in the car actually works as advertised.
Forget your Past but don't let it stop you. Tough times don't last. Tough people do.
My Car:
1994 E36 Convertible (Inherited from my Loving Father)
Carbon Black Metallic
Ivory White Nappa
Everything but B&O, Night Vision and Active Cruise Control.
