Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > BMW Diesel Owners & Enthusiasts
Old 08-05-2012, 06:11 PM
finnbmw's Avatar
finnbmw finnbmw is offline
Mein Auto: 2010 & 2012 X5 35d
What happens with urea during extended storage?
I recall reading somewhere that the urea we are using in our diesels will crystallize over time. Is this true? If so, wondering what will happen with the system if the car is left sitting for a prolonged period? Will the urea crystallize in the lines, filter etc. and cause damage when the engine starts back up?
Just curious...
Old 08-06-2012, 12:02 AM
Snipe656 Snipe656 is offline
Mein Auto: 2009 335d
It has a shelf life of well over a year if I remember right. It does not crystallize due to age but instead seems to be because of temperatures. When too old it looses it's efficiency. Your fuel will probably get algae growth long before the DEF becomes an issue from sitting for prolonged periods of time. You'd still be talking about extremely long periods of time of sitting for the fuel to be a worry.
--Admiral Aaron Rouse
Old 08-06-2012, 01:48 PM
F32Fleet F32Fleet is offline
Mein Auto: 435i, 335d sold.
Evaporates and leavs crystal behind. IIRC 2 yr storage life so it should be a none issue.
Old 08-06-2012, 10:46 PM
In my experience fuel normally gets growth in it before 2 years so that would be my bigger worry if I were to have any worries about sitting. I could not imagine though having such a new car and leaving it collecting dust for so long.
Old 08-09-2012, 11:40 PM
bimmerdiesel's Avatar
bimmerdiesel bimmerdiesel is offline
Mein Auto: 335d
I left my car in garage for 1 month and it started just fine and no issues. This was in Nov month with temps in 20-30F. And I am currently away for 7 weeks and left car in parking. Hopefully I will have no issues after these 7 weeks.
Old 08-09-2012, 11:44 PM
My car has sat for months on end and I have had zero issues with DEF crystallizing. I of course do not live in a very cold environment either so take it for what it is worth. I am more worried about my battery holding enough charge through the long periods of sitting than anything else on the car.
Old 08-10-2012, 08:11 AM
UncleJ UncleJ is offline
Mein Auto: '09 Cayenne "S"
I think I would worry about the car stored for a long period in a hot environment which would hasten the evaporation of the urea solution in the lines and perhaps cause crystallization and clog the smaller orifices in the system. The urea system is a fairly new and I suspect that we will have much to learn about it as the years pass.
Old 08-10-2012, 08:14 AM
But what is a "long period" in days?
Old 08-11-2012, 07:10 AM
6 months would be a "long period" IMHO.
Old 08-11-2012, 07:13 AM
ericwarren ericwarren is offline
Mein Auto: 2011:335d and Touareg TDI
My car was on the lot for about 18 months before I purchased it
Have put on about 700 miles and all seems ok.
Should I have it drained and refilled??
Old 08-11-2012, 10:10 AM
I doubt that it just sat in storage for 18 months. Almost certainly it was moved around the lot, if only to be washed, started frequently (to keep the battery up) and not shunted off into a dark corner to be forgotten.
Old 08-11-2012, 10:45 AM
GreekboyD GreekboyD is offline
Mein Auto: 2009 BMW 335d
Hard to say. I bought my 2009 BMW 335d with only 3,800 kms on it last August. About 2-3 days later I had the SES light come on and the SA said it was due to old urea sitting in the car and hadn't been changed for over two years. Fault code showed a clogged/hardened urea valve.
With 700 miles on yours though, I'd say you should be fine.
Old 08-11-2012, 05:54 PM
i'll let the onboard computer be my guide then!
thanks.
e
Old 08-11-2012, 11:05 PM
My car sat outside for almost a year prior to being purchased but that was in Texas so not like it saw much cold weather. Now one that sat outside in Canada for such a period or longer then I'd be wondering about the transfer pump.
