Old 08-13-2012, 10:53 AM
X3 Soccer Dad X3 Soccer Dad is offline
Mein Auto: 2006 X3
Front Strut replacement
Hey guys,
Need some advice. My X3 puked its oil out of the LF dampener and needs replacement.
What would you do?
1. OEM or aftermarket?
2. Is a service manual available for a 2006 X3? If so where can I buy one?
3. Any additional parts that should be ordered while changing both the left and right?
4. Last, what is the best site on the net for our Bimmers parts?
Thanks for your help
~Jamie
Old 08-13-2012, 01:56 PM
mlukas161's Avatar
mlukas161 mlukas161 is offline
Mein Auto: 03 330i, 04 X3
Originally Posted by X3 Soccer Dad View Post
Hey guys,
What would you do?
~Jamie
1.) Most do aftermarket due to the cost savings. Bilstein HDs are a popular choice.
2.) No Bentley Manual
3.) Strut tower bearings and the rubber pads. Possibly springs depending on mileage.
Here are some helpful threads.
http://www.bimmerfest.com/forums/sho...light=bilstein
http://www.bimmerfest.com/forums/sho...t=spring+thing
Old 08-14-2012, 08:32 AM
UncleJ UncleJ is offline
Mein Auto: '09 Cayenne "S"
My '06 had same problem with left front. Replaced both at indy for serious coin ($2K) along with some other maint. work! Indy used OEM struts and assorted collateral stuff. Happened at around 80K miles. Didn't want to hassle with trying to do it myself -- don't have the equipment for that sort of thing any more and it was easier to just have it done. First time I have ever had a strut fail in any car. Have replaced them before because of wear but outright failing -- no.
Old 08-14-2012, 10:34 AM
X3-terrestrial's Avatar
X3-terrestrial X3-terrestrial is online now
Aficionado
Uncle-When you say OEM struts, you mean BMW original part or anyo ther OEM brand like Sachs?
-Mario Andretti.
___________________
River City Bimmers BMW CCA
2002 ///M3 Coupe, Steel Gray Metallic on black leather, HK, three pedals.
1991 E30 325ic, AW, Black Leather, Black top, Three Pedals.
Old 08-14-2012, 10:52 AM
AzNMpower32's Avatar
Tar Heel Faithful
My right front strut started to leak last year, so both fronts were replaced with the Sachs (OEM) struts, along with the lower control arms and bushings for around $1500, not including the alignment afterwards.
Current consumption: Spritmonitor.de
Old 08-14-2012, 04:00 PM
PSUEng PSUEng is offline
Mein Auto: 2007 X3
I would put the Bilstein HDs on--and do the mounts and pads.
Old 08-14-2012, 05:45 PM
OEM from BMW is what I recall.
Old 08-14-2012, 06:14 PM
jerry325 jerry325 is offline
Mein Auto: 2006 X3 Blue & silv.325ci
Had both of my front shocks/struts replaced about a month ago at BMW dealership as well at 110,000 miles. Front springs were fine, but just had the rear ones replaced a month earlier. Must have broken a seal on the front because I had grease all over front left wheel after a trip on a very rough highway. Noticed poor ride/bounciness afterwards and found it was broken. Hefty bill of nearly $1,800 for fronts. Noticed the dealership charged full list on parts. I could have bought them from one of the board sponsors for about 30% less, but a little too intense for my patience level to replace.
Old 08-16-2012, 03:44 AM
vwvwvw vwvwvw is offline
Mein Auto: '08 X3, '08 535xiT (gone)
Why did you replace the control arms? Were they bent?
Old 08-16-2012, 07:30 AM
Aficionado
I was going to ask the same thing...usually the bushings are the ones needing replacing not the actual CA's.
-Mario Andretti.
___________________
Old 08-16-2012, 11:05 AM
Tar Heel Faithful
The right control arm was bent.
Old 08-17-2012, 03:12 PM
Mein Auto: 2006 X3
Awesome thread guys! Thanks for the input.
damper, front suspension, replacement, struts
