Old 08-01-2012, 12:44 PM
Sylvain1691 Sylvain1691 is offline
Mein Auto: BMW, X1
Angry Inner excessive wear run flat tire, X1 2012
I have a BMW X1 2012 since November 2011 and at 21 000 km, I have to change the front tires because of inner excessive wear of the front tire.
The dealer say it is normal. In fact it is not normal. Now the noise of the front tires is so big, I do not listen to the radio any more.
One mechanic told me it is a alignment problem but apparently the camber is not adjustable.
I will have to install a camber kit or install non run flat tire and call a toe truck if I have a flat tire.
If I do not fix this problem, I will sell the car and never have a BMW in my life.
Is there someone with a suggestion ?
Old 08-01-2012, 01:36 PM
bimmerized bimmerized is offline
Mein Auto: 97 E36M/4
have the alignment checked first. The Toe parameter affects wear more than camber. Have the Toe corrected and the fast wear should be solved. If the wear remains uneven, though slower, then have the camber corrected too. I'd be surprised if the front camber cannot be adjusted. If it's at the maximum of adjustment, you can find camber kits in the aftermarket, but there should be no reason why you can't align it to factory specifications. If you can't that problem should be covered under warranty.
Old 08-01-2012, 01:39 PM
speedracerf4i speedracerf4i is offline
Mr. Registered User
Mein Auto: 2005 545i
This happened to all my BMW's. It's the alignment spec that BMW specifies that's causing this inner tire wear. I did an alignment on my 545i at the dealer 3 months ago ($245) and the tech asked me if I wanted a setting that preserves the tire better or BMW's more aggressive setting. I opted for economy setting. The car will loose some of the high-speed stability and I can feel the rear-end skipping out a little on the turns. I then took it back to the dealer for original BMW alignment specs. The dealer gave me a break and charged me $150 to revert back to the original specs.
MY05 545i SMG, sport-pack, L7, comfort seats, Navigation, Auburn Dakota leather/Jet Black. Euro-delivery.[COLOR=Navy]
1998 318Ti M-Pack Hellrot Red, 5 Speed.
2013 Jet Black X1 ED October pick up.
Old 08-01-2012, 05:34 PM
this agrees with my observations as well. BMWs are very sensitive to small changes in toe and the factory specifications are slightly agressive in toe for stability at the expense of tire wear. I like less toe, especially in rear. Less toe in front can make the car twitchy on center and more less toe in rear can help oversteer the car.
BMW alignment specs are likely only applicable to the factory environment in which they are originally aligned because the specs require you to fully load the car with weight before an alignment. If you don't which most places including the dealer wont, the alignment will be too agressive for a partial load.
Old 08-14-2012, 12:57 PM
Mein Auto: BMW, X1
Non run flat tires, the solution !
If I install non run flat tires, does it solve the problem of inner wear ? I am asking that because I think the combination of run flat tires and aggressive BMW alignment settings makes it impossible to have a uniform wear of front tires. Is my thinking wrong or what ?
Old 08-15-2012, 08:13 AM
no, RFT do not wear appreciably more than regular tires. your problem is with the alignment or the tire compound. Higher preformance tires have softer compounds that wear faster. Try a tire with a higher treadwear rating. I would at least have the Toe checked and adjust it to Toe Out as far as the factory spec allows.
How long did the tires last?
Old 08-15-2012, 08:45 PM
Mein Auto: BMW, X1
One year (October to November 2011 and April 2012 to now) 22 000 Km. I have and appointment to check the alignment in 2 weeks. The tires are Goodyear Efficient Grip. If I change the 4 tires, do you have a brand in mind ?
Old 03-14-2016, 11:50 AM
Vann 330i Vann 330i is offline
Mein Auto: 06 330i ,87 325i
Get out of those Goodyear tires first they change style and they have road noise go back with continental or mich u get better time and wear
