Old 08-16-2012, 09:14 AM
oembimmerparts oembimmerparts is offline
Mein Auto: 2001 Z3
Coolant pipe repair kits
We have added the coolant pipe repair kits to the deal of the day page. Thank you all for supporting a bimmerfest sponsor.
http://www.oembimmerparts.com/dealoftheday.asp
Old 08-16-2012, 09:40 PM
sirstopher's Avatar
sirstopher sirstopher is offline
bimmerfest Supporting Member
Mein Auto: POS Honda
Can you guide me to references that have used your product in success?
97 740i e38 - SOLD
02 745i e65
03 Montero Limited
Old 08-16-2012, 09:52 PM
flewis_1 flewis_1 is offline
Mein Auto: BMW 745Li
I've personally used the URO pipe solution and installed back in February of this year. My coolant pipe gasket gave in at about 185K on the clock. I am now at 197K. Do note I am in no way affiliated with the vendor outside of purchasing the product from them. I'd recommend replacing head gaskets and valley pan gasket while in there too.
Old 08-16-2012, 09:57 PM
sirstopher's Avatar
Ok, I don't want to remove heads so I will go with another manufacture.
Thanks for the quick reply.
97 740i e38 - SOLD
02 745i e65
03 Montero Limited
Old 08-16-2012, 10:08 PM
It's the same procedure for any pipe you choose. You'll need to remove the air intake manifold which exposes the head gaskets and valley pan to get access to the coolant pipe. If you are an ambitious DIYer I'd recommend purchasing TIS software off ebay to guide you step by step. There are also a couple of youtube videos I referenced to get a gist of where everything is.
Old 08-16-2012, 10:11 PM
sirstopher's Avatar
I have TIS, you mean valve cover gaskets not head gaskets right? I am not pulling the heads.
97 740i e38 - SOLD
02 745i e65
03 Montero Limited
Old 08-16-2012, 10:15 PM
no not the VCG...let me rephrase...the manifold gaskets...you don't have to pull any heads.
Old 08-17-2012, 09:33 AM
Mein Auto: 2001 Z3
I do not know of any DIY write ups from any of our past customers but it seems one of them has posted above. I can tell you that over the past 5 months we have sold somewhere around 50 of these with 1 person ripping the seals during the install as I recall having to send a new set of seals to them.
Max
Old 08-17-2012, 09:35 AM
MakaveliFaison's Avatar
MakaveliFaison MakaveliFaison is offline
Mein Auto: Bmw E64,E65,Chrysler 300c
not bad. i may be ordering one tonight
650i sport hud asanti af132
Old 08-17-2012, 09:50 AM
sirstopher's Avatar
About 600.00 less than AGA, might just be getting this to stick on my shelf as I know I have to replace soon.
97 740i e38 - SOLD
02 745i e65
03 Montero Limited
Old 08-17-2012, 12:14 PM
Dead Dead is offline
Mein Auto: 2002 745I
