Old 08-07-2010, 02:21 PM
bimmer80 bimmer80 is offline
Mein Auto: 745LI
A/C compressor drive belt
Hello Guys, does anyone know how to remove the A/C compressor drive belt on a 2005 745?
Thank you.
Old 09-17-2010, 10:59 AM
yuril yuril is offline
Mein Auto: 745i
From what I've heard from the shop, you just cut it off (!), as there is no tensioner.
Installing a replacement belt will need a special BMW provided tool.
'05 745i
Old 09-17-2010, 12:03 PM
Mein Auto: 745LI
I had to remove some screws from the back of the ac compressor and loosen the compressor for it to come off but no special BMW tools needed.
Old 09-17-2010, 12:53 PM
MakaveliFaison's Avatar
MakaveliFaison MakaveliFaison is offline
Mein Auto: Bmw E64/5, Maserati GT
There is a tensioner on the AC belt
650i sport hud ac schnitzer eibach resognator delete m6 quads akebonos
Old 08-16-2012, 06:29 PM
CatsMeow CatsMeow is offline
Mein Auto: 2009 750Li
Missing belt tensioner
Not on all models, just found this out. My ac belt broke and week ago so I decided to replace it as well as the drive belt however, when I went to put the belt on there was a lot of slack and no way to tighten it as there was no belt tensioner, so I was stumped. Either the guy ordered the wrong belt or when my belt broke it snatched the tensioner off as well....not likely but I had no clue. The tensioner was not in the pan and where it should be bolted was caked with road debris and what not. After I read this post a few times I realized that on some models they put a AC belt tensioner and on some models they didn't, not sure of which ones but I am absolutely certain that I didn't drop a belt tensioner when the belt broke. I'll do so more digging because apparently this belt is not the standard one that the parts stores see when they do there search, only the ac belt that goes along with the belt tensioner comes up. I'll be back.
Old 08-16-2012, 07:29 PM
Rookie2008's Avatar
Rookie2008 Rookie2008 is offline
Mein Auto: BMW 328GT/740LI/750LI
You do realize this thread is from 2010 right?
13 740LI W/Msport package. Executive Package
DRIVER ASSISTANCE PKG, HUD,
OYSTER; NAPPA LEATHER SEAT TRIM,
Lane departure, blind spot detection,
Collision Mitigation,
Side & Top View Cameras
Aftermarket Rear entertainment
Old 08-17-2012, 05:30 PM
Ah yeah.......however my AC belt did not break in 2010, just the last week, when I did a search this was the only thread that I came across and it was inconclusive. After doing some research and found out that both members are correct, BMW outfitted some cars with belt tensioners for the AC belt and others with no belt tensioner. However when you order a belt the only one that comes up is for the setup with the belt tensioner. Nevertheless after half a day of working I have replaced my AC belt for the non AC belt tensioner setup.
Old 08-17-2012, 06:26 PM
Rookie2008's Avatar
Good Deal!
Old 12-15-2012, 12:54 PM
Larryd745i Larryd745i is offline
Mein Auto: 2004 745i
did you replace the non tensioner belt without the tool? if so how did you do it. did you loosen the compressor?
Old 03-08-2014, 01:30 PM
erniejazz erniejazz is offline
Mein Auto: 745il
yes, how is this done, have the same issue getting it back on.
Old 05-11-2014, 08:28 PM
BobbyBucher BobbyBucher is offline
Bobby Bouchet
Mein Auto: 2005 545i
Erniejazz,
Did you get yours replaced? I have been trying all day to get mine on after doing a full cooling system replacement and just can't get it to go on. Please let me know how you did it.
I have a 2005 545i without the tensioner on the AC belt.
Bobby
Old 05-12-2014, 05:57 AM
Mein Auto: 745il
Bobby you need to buy the tool. Do not order on ebay! Get someone on the phone and make sure they know what the tool is. $50
Old 05-12-2014, 03:47 PM
Bobby Bouchet
Thanks, I will work on that tomorrow and I appreciate the reply!!
Old 08-12-2015, 03:22 PM
BigBody BigBody is offline
Mein Auto: 745Li
A/C Belt not all the same
There is a special tool and some models have a A/C belt tension-er some don't. I was told when they switched to the electric fan those models have the none tension-er belt on the A/C compressor. The belt is not the same as the models with the tension-er. I experienced this first hand on my 2005 E66. Just for the record that's all. I hope this helps someone I came to the blog and couldn't get a clear answer to this question I had to find the answer first hand via paying a mechanic to do it versus doing it myself. Good luck !!!
Old 08-12-2015, 03:45 PM
A B Able Truck's Avatar
A B Able Truck A B Able Truck is offline
Mein Auto: 2006 550I (N62TU) V8
Here's an option;
NAPA #70990
OTC #7425
The early bird may get the worm, but the second mouse gets the cheese.
Old 08-14-2015, 06:21 PM
Mein Auto: 745Li
thanks for the information
Originally Posted by A B Able Truck View Post
Here's an option;
NAPA #70990
OTC #7425
Thanks A B Able Truck that's good stuff to know I hope that video saves someone else some money.
Old 01-08-2016, 11:33 PM
paulmurphyhomes's Avatar
paulmurphyhomes paulmurphyhomes is offline
Mein Auto: M3, 745li, Speclzd FSR Pr
I've tried a few of the generic ones and they did not work for me. For any SoCal people, I have the proper one if you need to use it. Easy with it and a pain if you don't.
