Heater Control Valve Rebuild '92 318i - Bimmerfest - BMW Forums
E36 (1991 - 1999)
Old 04-21-2012, 03:06 PM
paulelmore paulelmore is offline
Mein Auto: 1992 BMW 318i
I've had intermittent problems with my heater system, culminating in a repetitive ticking sound coming from the heater control valve which is mounted on the firewall, drivers side. New ones cost around $250, which is not cool, so I decided to rebuild mine.
Here's what it was doing before: (not my car or video, but the same problem)
1. Locating the HCV
It's mounted in a rubber mounting clip on the drivers side fire wall, behind the oil dip stick. It's tight getting in there, but doable without removing anything else.
2. Removal
Unplug the electrical clip from the HCV. You'll have to pinch and pull the plug out.
You'll have to remove THREE hose clamps total-two from the heater core mounted in the fire wall (leave the top two hoses clamped to the HCV) and the lower hose clamp ON the HCV. The last one's a little hard to do, but if you have a long enough screwdriver, it's not to tough.
Gently pull the two hoses from the heater core pipes (everything is plastic so go carefully). I give the hoses a twist first to break the seal. Mine came off fairly easy. The bottom hose is easiest to take off after you unmount the HCV from it's rubber clamp.
The HCV is mounted to the firewall with a rubber clamp on the bottom and a round rubber "boot" on the top. To remove, pivot the bottom of the HCV away from the firewall to unclamp the bottom and then slide the whole unit upward to remove the plastic pin on HCV from the rubber boot. (look at the pics of the HCV on the bench and it will make sense.)
(In this picture, you can see the shaft of a long screw driver just inserted into the lower hose to keep it upright to prevent excess spillage of coolant-FYI... you don't have to drain the coolant from the system to do this job.
HINT-I found it easier to remove the HCV through the bottom of the car.
3. Disassembly
Here's what it looks like sitting on the work bench.
You'll need a T10 Torx Screw driver to remove the 6 screws from the housing.
Remove the six screws. There is a little rubber sealant around the bottom of the electrical clip which might keep the two parts held together. GENTLY GENTLY GENTLY lift off the two metal cylinder units TOGETHER. In the picture below, you'll see the little copper wires you're trying to NOT break. Move the two metal cylinder units around as ONE unit.
4. Cleaning
Inside there are two metal plungers, springs and plastic sleeves that will come out. The pins on the plungers are hollow. There is a small plastic pin that seats inside the shaft of the plunger. Clean everything real good with degreaser, including the inside of the metal cylinders. You want to make sure everything travels smoothly with no binding. DON'T LOOSE THE SPRINGS OR PLASTIC SLEEVES.
5. Assembly
The following picture shows the proper assembly order.
Use a little WD40 to make sure everything is moving smoothly. Again, make sure the small plastic posts seat inside the shaft of the plungers when reassembling.
It's easiest to put the plungers, springs, and plastic sleeves inside the bottom half of the HCV and then put the metal cylinders OVER the bottom unit. Make sure everything aligns and seats well. Reinstall the 6 torx screws. Do not over tighten. Just snug.
Reattach the hoses to the top pipes on the HCV. Make sure you get the right hose on the right pipe.
6. Reinstall
Slide the HCV back through the bottom of the car and let it rest somewhere until you can go around to the top and pull it up to where it belongs. I found it easier to...
First, install the bottom hose onto the HCV,
Second, install the two hoses onto the heater core pipes,
Third, clip the HCV into it's rubber mounting clip,
Fourth, tighten down all the hose clamps,
Fifth, plug in the electrical.
Start the car, turn on the heater, let it run for a minute, and then double check the coolant levels to make for the small spillage that happened when you removed the HCV.
Total time-less than an hour.
Hope this makes it easier for others to rebuild their HCV.
ID:	321855   Click image for larger version
ID:	321856   Click image for larger version
ID:	321857   Click image for larger version
ID:	321858   Click image for larger version
ID:	321860   Click image for larger version
ID:	321861   Click image for larger version
ID:	321862   Click image for larger version
ID:	321863   Click image for larger version
ID:	321865   Click image for larger version
ID:	321866   Click image for larger version
ID:	321867   Click image for larger version
Old 04-21-2012, 03:15 PM
armando325i armando325i is offline
Mein Auto: 325i
i dont see no pict, but did it work? easier wud be to get second handed on ebay for about 40 or 50 bucks!
f..k the fuel economy
Old 04-21-2012, 04:09 PM
Pictures are up now. Everything seems to work now. No more ticking.
You're right, you could pick one up on ebay, but I'm never sure about the history or condition. I'd rather see something with my own eyes and know for sure. Personally, it's more fun to work on something and save the money.
Old 08-17-2012, 09:01 PM
Marco 237 Marco 237 is offline
Von Trips
Location: Perth, Western Australia (Lots of nice open roads)
Mein Auto: E30 S50B30....Rocket
Angry Nasty little French Heater valve....
Great post.
The pics really helped alot. I've been tackling this problem with my E36 320i for months.
I've gone through two heater valve units (both secondhand) without success, so it goes to show that there are some secondhand parts that should either be thrown out or completely rebuilt. The heater valve (with aircon) has has two rubber seals that cover the plunger ends inside the unit. You didn't take the metal plate off to reveal these two little evil seals. When these perish or disintegrate, they block everything up. Also, as the seals lose their ability to hold their shape, they start to leak the hot water into the core when you don't want it to.
This isn't a good idea on a hot day with the air conditioning on!!!!
The dealer will only replace the entire unit for about $480 Aud ($500 US) which is RIDICULOUS. I know it's another story but I am completely speechless how BMW rips the heart out of the Australian market to subsidize Europe and the States. We pay $168k for the M3....you do the sums on that one!
Getting back to the topic.....
Until I can find someone on the planet who will sell me a new internal rubber seal, I am going to re-use the cleaned unit without the internal seals. It still works but is not as efficient.
I hope this helps anyone else out there with the same problem.
Old 08-17-2012, 10:56 PM
hornhospital's Avatar
D'oh, You Kids!
How did I miss this when it was first posted???? That's a GREAT write-up, and some outstanding pictures. Well done, sir!
Quotes to live by:
BMW-CCA #441426
Old 03-26-2013, 08:46 PM
07lilredwagon 07lilredwagon is offline
Mein Auto: 07 e91
very nicely done!
JP
Old 01-07-2016, 05:49 PM
ezekielSB ezekielSB is offline
Mein Auto: 95 BMW 318i
I have a 95 bmw 318i and am attempting to replace the coolant connector pipe as well as all the connecting hoses. While removing the heater hose it popped right off due to a brittle hose connector (not at the hcv but at the firewall) it broke right off and now I need to replace it but can't find the part. Would you or anyone here happen to know what part this is?
It is the black plastic connector piece. In your pic your hose is still connected (this is where mine is broken and needs replacing) would I need to replace the whole unit?
Your picture-
My broken connection-
_sl_
Old 01-07-2016, 06:38 PM
Mein Auto: 07 e91
From what I remember about taking the donor car apart for my trailer conversion, yes, that is a whole unit comprising of the 3 hose outlets you see....
it was very straightforward from what I recall.
Pelican parts has something very similar...and it may be the part for your car but do some research
Heater Pipe (3-Pipe Connection Flange) from Heater Core Pipes to Heater Core
Part #: 64-11-1-469-180-M604
JP
Old 01-07-2016, 07:21 PM
dc_wright's Avatar
bimmerfest Supporting Member
Your picture-
_sl_
The part you need is item 11.
http://www.realoem.com/bmw/enUS/show...diagId=64_0555
Old 01-07-2016, 10:52 PM
Thanks guys!!!
coolant, hcv, heater, heater control valve
