F10 / F11 (2011 - Current)
The new chapter in the highly successful story of the BMW 5 Series Sedan (F10) and wagon (F11) |
#1476
Have followed the topic some while, my cable is on its way, got the files already. Great thread!
Now, my first questions already: 1. has anyone been able to disable the speed limiter of the car itself? I mean the DME value which limts the car to 250 kph? Not to confuse with any speed warnings... (I know it will mostly have a meaning in Germany ... :-) ) 2. Did I get it right that I can enable digital tach in my dash? (Have the extended cockpit version, thus all you can order but no HUD) Last edited by Ray_S; 06-29-2012 at 10:19 AM. |
#1477
@mrbombastic;
To backup of the CAFD files from your car, as soon as you start reading the CAFD files from your car, E-Sys automatically stores the files into "C:\ESysData\CAF". All you need to do is to copy these files and store them somewhere safe. It's best is to make a new copy, and keep all previous ones, every time you want to code, this way you always have a copy of the last working version. User April1 created this nice batch file to do just that: http://www.bimmerfest.com/forums/sho...3&postcount=21 It will take all the files in C:\ESysData\CAF and move them to a Time & Date Stamped Folder based on the Batch Execution run time. Also, you should read this document: http://www.bimmerfest.com/forums/att...2&d=1339151911
![]() - 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC - 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11) - BMWCCA #446923 - flickrŪ |
#1478
@Ray_S;
In the F10 DME, there was an specific code to disable the speed limiter, but I can't remember off the top of my head what it was. If you can't find it, you can try adding S231A DELETION VMAX (250 km/h limitation) to the VO order, and recode (CODE not CODE FDL) the DME module. As for the dash, you can enable Digital Speed, not Digital Tach.
![]() - 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC - 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11) - BMWCCA #446923 - flickrŪ Last edited by shawnsheridan; 07-01-2012 at 09:05 PM. |
#1479
Folks, this thread was abandoned for a reason.
You will have better luck posting follow up questions to this thread here at our new BMW Coding and Programming home: http://www.bimmerfest.com/forums/forumdisplay.php?f=175
#1480
Do you guy know where to find a concise VO/FA list? I find info scattered, very little condensed on F1x series
Perhaps we could collaborate and make it a sticky worthy post...
X5 5.0 MY12, M package, black sapphire 650i vert, MY12, Blue/ivory, to be modded soon... Gone: 997.2 modded, 987s (not forgotten ), MB C55 amg, Passat W8, Cayenne MY 08
#1481
E.g. can you lock the car without folding mirrors? I think I'd prefer that short tap on CA would lock the car, and long would close the moon rood/mirrors.. Same for the keyfob. |
#1482
That is the way it works.
Tom '11 M-Sport 535i, Carbon Black - Cinnamon, Head-up, P-II, SAT, + Returned to the Mother Ship: 2008 335i E93 |
#1483
Thanks, works as advertised!
Short tap or click locks the car, long (about 3 seconds) - closes the mirrors. Only one note: ASP_BEIKLAPPEN_BEI_KOMFORTSCHLIESSEN is in another module - FRM (I didn't find it at first..) Last edited by nesterk; 07-09-2012 at 01:15 PM. |
#1484
E-SYS w/token
Can someone tell me where I can get a working copy of E-SYS with a token? I've been all over the internet looking and come up short. I am willing to pay for a copy. Thanks
#1485
Obviously you didn't read/follow post 1479 above...
I am new to the forum, is there any one that can assist me with coding my 535? I am in southeast michigan.
#1487
Is there anyone in the Nashville area that can help me do this? Thx
2012 BMW 535 ... Silver / Black, M Sport, Premium, Premium Sound, Technology, Heated Seats, Sport Automatic Other Cars ... Mercedes S550, Chevrolet Tahoe LTZ, Porsche 996 Turbo |
#1488
http://www.bimmerfest.com/forums/sho...postcount=1479
#1489
Anyone know what these two mean:
F10/F11 X CAS 3002 CLM OPEN_RSCR_WITH_REMOTE_KEY_SPFN aktiv / Werte=01 nicht_aktiv / Werte=00 Comment = Remote Key opens with a 4th button tailgate or rear window (active) F10/F11 X CAS 3002 CLM REAR_SCREEN_IS_PRIMARY aktiv / Werte=01 nicht_aktiv / Werte=00 Comment = Remote Key opens with 3rd button tailgate or rear window (active) Also, is there a way to change the directionals from 3 to 5 flashes? |
#1490
Hey Gents, can someone help me?
I changed region code from 1 to 2 and front display shows me only menu of DVD disc and Rear DVD still says unknown code. I guess we changed wrong player. Can someone please tell me how I can change it for back DVD and why the front one doesn't play it? Also vehicle profile still says: [102] 697_DVD_CODE_1_US_CAN |
#1491
As for the Rear, I do not know for sure, but it should have it's own ECU, likely called RSE. In it, it should have the same parameter, or something very similar in name as the CIC AREA_CODE_DVD setting that can be changed as well. I would not worry about the VO Option, as your FDL Coding is overriding that. It would only revert back to the VO if you later decided to CODE the CIC and RSE modules based on the VO. Just as an FYI, these are the factory Option Codes for DVD Regions: S697A Area-Code 1 for DVD S698A Area-Code 2 for DVD S699A Area-Code 3 for DVD S700A Area-Code 4 for DVD S701A Area-Code 5 for DVD S702A Area-Code 6 for DVD I do not think there is a factory Option Code Area-Code 0 for DVD "All Regions", although it may be an FDL Coding option. I don't know without looking. I don't think either that there is a factory Option Code "ALL", although there is an FDL Code setting of "alle_anderen / Werte=00", which is "all other". This is confusing, as it is unclear if it includes or excludes the U.S. Usually Region "ALL" means it can play discs with any region flag set, however, "ALL OTHER" indicates perhaps something else. One BMW Document I read states "all countries excluding the USA." A few words of CAUTION taken from the "E70 Rear Seat Entertainment" manual (RSE): "The DVD area code can be changed during coding only if mileage is below 60 miles on the odometer." I am not sure I believe this. "The RSE control unit permits a maximum of five area code changes, then the area code of the DVD most recently inserted is stored in the RSE control unit. As a result, only DVDs with the area code defined in the RSE control unit can then be played" This I believe, I know someone with an F25 that retrofitted his CIC, and he changed his AREA_CODE_DVD setting one too many times, and it locked in the last setting and he was unable to FDL Code it anymore. "The number of changes still possible and the area code currently set can be issued in the BMW diagnostic system under RSE control unit functions" I wonder if this is a setting that can be coded, effectively resetting the change count back to 5? "Changing the area code in the control unit by coding reduces the number of possible area code changes. If changes are no longer possible, the control unit must be replaced when a DVD with a different area code is to be played." I think rather than replaced, the firmware can be flashed, resetting the change count.
![]() - 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC - 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11) - BMWCCA #446923 - flickrŪ Last edited by shawnsheridan; 08-18-2012 at 12:26 PM. |
#1492
This problem was fixed by coding different module. It was RSE, not HU_CIC module. Changed to all other regions and it fixed it!!!
#1493
Try playing a DVD coded for region 1 though using the alle_anderen / Werte=00 (all other) setting. It is unclear if this will allow playing Region 1 DVD's (U.S.), so it would be good to know. Was Area-Code 0 for DVD an option?
![]() - 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC - 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11) - BMWCCA #446923 - flickrŪ Last edited by shawnsheridan; 08-18-2012 at 01:25 PM. |
#1494
No, Area code 0 was not an option!
#1495
Guys....
there was a separate sub forum for coding.... It would be more productive to every if we can take the coding discussion over there. Please use the below forum.... http://www.bimmerfest.com/forums/forumdisplay.php?f=175 |
