Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 1 Series & 2 Series > E82 / E87 / E88 1 Series (2008 - 2013)
BMWs throw back to the iconic 2002, with a renewed form and function. The smallest car in BMW's line up but still packs a punch. Available in coupe or convertible, powered by a naturaly aspirated inline 6 in the 128 or the turbo twin power inline 6 rocket sled 135.
Old 08-18-2012, 06:37 PM
RustyShark RustyShark is offline
Mein Auto: 135i
Snow Tire Question
Hello,
I have a 135i that has 18inch summer tires. I never drove the car in the winter but I have to drive it this winter. I don't want to buy new snow tires ($800+) for just 1 winter.
I'm looking at craigslist and I see some Nokian Hakkapelitta Q 235/60 R16 Snow Tires On Borbet Rims.
Can I get any tire that's already on a rim and use it on my car? Or does the rim/wheel itself have to be BMW compatible? (Sorry I'm a newb here).
Old 08-18-2012, 06:46 PM
Carnivora Carnivora is offline
Registered Poser
Mein Auto: 2011 335i 2008 X5
It has to be compatible somewhat. There are different bolt patterns, hub sizes, offsets, wheel sizes, tire sizes, brake sizes etc to consider.
I have dedicated snow tires and they make a HUGE difference.
I wish.
Old 08-18-2012, 08:03 PM
Chris90's Avatar
Chris90 Chris90 is offline
Mein Auto: '04 330i
Go to tirerack and see what Borbet wheels are available for your car. Enter 128i to see smaller wheel options. Doubtful 16s will fit over the brakes.
"When you were born, you cried and the world rejoiced. Live your life so that when you die, the world cries and you rejoice." - Cherokee Expression
Old 08-19-2012, 09:32 AM
Tom K.'s Avatar
Tom K. Tom K. is offline
Mein Auto: '07 328iT.'13 Boxster
As 16" wheels have never been available for the 135i, you can be pretty sure they will not clear the brakes.
Tom
Old 08-19-2012, 04:15 PM
Chris90's Avatar
Mein Auto: '04 330i
Tom
you can't be sure if that - some 16s fit on my 330, it depends on the wheel.
Old 08-19-2012, 04:59 PM
ND40oz ND40oz is offline
Mein Auto: 09 135i
As Tom said, 16" wheels will not work on the 135i, they won't clear the front brakes.
17 Volvo XC90 T6 Inscription P* (OSD 7/16)
15 BMW 328d xDrive Sports Wagon M Sport
15 Audi SQ5 Prestige
13 Honda Insight EX
Old 08-19-2012, 09:33 PM
jsc's Avatar
jsc jsc is offline
Mein Auto: E85 M-Roadster, E82 135i
E46 330Ci front brake rotor diameter is 325mm. 135i front brake rotor diameter is 338mm. Very unlikely any 16" wheel could clear the 13mm larger rotors on the 135i, when it was very difficult to find ones to fit an E46 330.
Old 08-22-2012, 10:29 AM
awarr awarr is offline
Mein Auto: 135 cab
On a related note, I need to replace my OEM run flat tires. I want to go with Michelin but move away from run flats. Has any one done this and if so what results can be expected.
Old 08-22-2012, 11:47 AM
Tom K.'s Avatar
Plenty of folks have gone to non RFTs. The go flat Conti DWS tires on my 128i have improved both ride and handling and cost less than 1/2 of the OEM RFTs.
Tom
Old 08-22-2012, 12:58 PM
Chris90's Avatar
Mein Auto: '04 330i
Ok, that's a good reason to be sure (not just cause BMW never sold 16s).
Old 08-22-2012, 04:01 PM
Mein Auto: 09 135i
I have Pilot Sport A/S Plus's on mine, they work fine and they ride a lot better then the OEM Bridgestones. If you're not looking for an all season though, go with the Pilot Supersports.
13 Honda Insight EX
Old 09-23-2012, 09:01 AM
Desmarais27 Desmarais27 is offline
Mein Auto: BMW
Does anyone have a set of snow tires they are happy with?
Old 09-23-2012, 09:45 AM
dthompson dthompson is offline
Mein Auto: 128i Cp, 1st year Boxster
I like my Michelin XIce2s
Old 09-23-2012, 02:37 PM
Registered Poser
Bridgestone Blizzaks.
I wish.
Old 09-23-2012, 04:44 PM
sd330Ci's Avatar
sd330Ci sd330Ci is offline
Mein Auto: BMW 1M, MINI Countryman S
Dunlop Wintersport 3D
Old 09-23-2012, 07:00 PM
ProRail ProRail is offline
"Clunker" *****
Mein Auto: 1999 BMW 528A-220K-traded
Tirerrack or any other reputable tire store will tell you what's appropriate. Should not cost $800 but if it does it does. Would you rather have your muti K car end up in a ditch? Buy what you need to be safe and to get you where you need to go.
