09 BMW Z4 3.0i - Transmission Shifting - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > Z Series > E89 Z4 (2009 - current)
Old 08-23-2012, 06:10 AM
RufusKing RufusKing is offline
Send a message via MSN to RufusKing
Mein Auto: Z4 3.0i Roadster
I bought my Z as a CPO with remaining Factory Warranty. When i have the Z in Sport mode man does it shift hard. I have the automatic transmission. Is that a normal characteristic of the car or is there likely something wrong. Honestly it feels like the double clutched version of the M3 but dont have a double clutch in mine obviously. There is little to no time between gears and it jsut rockets away. (Sometimes it feels like it is leaving me sitting on the pavement and the car is going on without me) I upgraded E85 to the E89 and there is a huge dfference. What do you guys think? Does your shift as hard a mine?
One more thing, it doesnt happen so much when i am under full throttle. It happens more when I am under half throttle or less.
thanks for the insight.
Also do we have any how to documents on various procedures like the E85 board has listed in their sticky section? If not we should really think about starting one. This car is coming up on the point where we are likely to start tinkering with it a bit more for tuning purposes or cosmetic upgrades such as wind deflector installations etc.
This one is called OPey
2009 BMW Z4 sDrive 3.0i
I call her weezey
2006 BMW Z4 3.0i Roadster - Sold and I miss her.
Old 08-23-2012, 11:45 AM
645/333's Avatar
645/333 645/333 is offline
Michael
Hi! in sports mode it does shift a lot harder subject to the throttle which has a quicker response window, sometimes it can catch you out in queueing traffic,
As for working on the car, well you cannot do the rear brakes or discs as you need to be able to code the release of the electronic parking brake....only time will tell if people get smarter at doing things.....
Old 08-23-2012, 12:36 PM
Originally Posted by 645/333 View Post
you cannot do the rear brakes or discs as you need to be able to code the release of the electronic parking brake..,
So are you saying that it automatically engages and you cannot undo that while the car is off? That would seem odd. Maybe will ahve to go lay now to see what is up with that unit.
I call her weezey
Old 08-23-2012, 01:23 PM
645/333's Avatar
Michael
Yes ! even with the car off ? you have to release the parking brake with a special code, then recode when you have replaced the pads/disc, this tells the controller that new pads have been fitted hence how far to move the piston.......
Old 08-23-2012, 06:17 PM
oh my that is genius!!!
I call her weezey
HTML code is Off
