Old 08-20-2012, 11:52 PM
epremsoft epremsoft is offline
Mein Auto: 1998 528i
Lightbulb Cylinder 3 Misfire
Hey guys. I have a problem, couple days ago my 98 528i start shaking and after that i got check engine light on. The code is P0303 (cylinder 3 misfire detected) and i just changed my spark plugs last month and i also checked all my coils they are working. And no leak from anywhere. The mechanic said it might be the valve, and it will cost $300 to $500! Didnt sound good to me...How can i fix this problem?
Thank you Apram.
Old 08-21-2012, 05:21 AM
shaftdrive's Avatar
shaftdrive shaftdrive is offline
Matching beemer & bimmer
Mein Auto: 1999 K1200 & 2001 525
There is only one answer to your question.
You need to get the diagnostic trouble code that triggered the SES light.
Autozone will read it for you for free in most states.
Old 08-21-2012, 08:58 AM
mbell666 mbell666 is offline
Mein Auto: e39 2002 540i6
How did you check your coils? Have you tried moving coil pack 3 to a different cylinder and seeing if the miss fire moves?
Have you removed the plugs and checked they are ok? Tried replacing them again?
Are there any other fault codes (e.g. fuel trims)
A valve would cost a lot more than $300 to $500.
An e39 is like a beautiful wife, needs constant attention, lots of money, lets you down at the worse times but you’d never be without it.
Old 08-21-2012, 09:07 AM
cn90 cn90 is offline
Likely bad ignition coil.
I have a few Bremi coils for 98 528i laying around.
Old 08-21-2012, 09:57 AM
If it is the coils, a /coil F3 in the bestlinks netted the following:
- How to test a BMW ignition coil (1) (2)
I don't consider those threads all that wonderful for testing coils, in and of themselves (other than the basic hints) ... so if the OP comes up with a better procedure, please let us know so all benefit.
Note: The second link though is great for general misfires!
As for the DTC, the OP needs to go here first:
- How to help someone who has an SES but hasn't read the codes yet (1)
Old 08-21-2012, 02:21 PM
Exclamation
I tried everything and still I have misfire on cylinder 3.
There is no other codes only P0303 (cylinder 3 misfire detected)
Old 08-21-2012, 03:11 PM
You probably overheated the engine recently.
Old 08-21-2012, 03:55 PM
I dont think so i did. I only use the car for 1 or 1 and half hour.
Old 08-23-2012, 01:54 PM
Question
I think I found the problem... its head gasket! there is a leak on cylinder 3, so it taking coolant and it mixing it with the oil! How much do you guys think its gonna cost me?
Old 08-23-2012, 07:17 PM
I gotta scratch my head and wonder how you know that just from a single code????
Hmmm... cn90 was right. How did he know?
Anyway, we have a ton of links waiting for you once you tell me that ... hope these help.
- Summary advice to provide users who suspect a major engine repair due to overheating (1) (2) (3) (4) & how to test an engine for a blown head gasket, cracked heads, a warped block, stripped head bolt threads, cam seizures, contaminated bearings, coolant hydrolock, or piston, ring, or valve damage (1) (2) & what are the major factors in deciding whether to rebuild the engine, replace the engine, or sell the car (1) & a DIY for replacing the I6 M54 head gasket (1) (2) & replacing the V8 M62TU head gasket (1) & why these engines are so prone to heat-related damage in the first place (1) & welding the crack between cylinder #3 and the water jacket on the exhaust side (1) & what engine swaps are most recommended (1) (2) (3) & where to obtain a new or rebuilt head (1) replacement short block or long block (1) (2) & how to lift & remove the engine (1) & the most recent real-world results from the last 50 people faced with similar blown engine problems from which this advice came from (1) (2) (3) (4) (5) (6) (7) (8) (9) (10) (11) (12) (13) (14) (15) (16) (17) (18) (19) (20) (21) (22) (23) (24) (25) (26) (27) (28) (29) (30) (31) (32) (33) (34) (35) (36) (37) (38) (39) (40) (41) (42) (43) (44) (45) (46) (47) (48) (49) (50)
Old 08-23-2012, 08:37 PM
ztom's Avatar
ztom ztom is offline
I gotta have more cowbell
Mein Auto: 1997 528i
Typical for cyl 3 head crack on 528. I find coil packs usually don't fail.
Old 08-25-2012, 12:48 AM
Old 08-25-2012, 03:37 PM
poolman poolman is offline
Mein Auto: 525i station wagon
You might be better off finding a good used engine. Cylinder 3 problems often come with a cracked head on that cylinder. Some have weilded the head and been OK--but there'e going to be alot of down time here--I would think somewhere around 2500 bucks for the fix--u might find a used engine cheaper in the long run.
Old 08-25-2012, 03:56 PM
EconoBox EconoBox is offline
Mein Auto: 2001 530i (E39) 140k
cnn, how did you know a misfire was related to a overheat / head gasket?
Is this a common explanation for misfire? (Vs a bad coil which seems to normally be the case)
Old 08-26-2012, 03:02 AM
I think the most 'common' explanations for a misfire are here:
- How to diagnose a BMW E39 engine misfire (1)
I think cn90's logic was that the #3 cylinder is generally the one that cracks when the M54 overheats.
So, a persistent misfire in #3 without any other explanation is cause to do a compression check of #3.
Old 08-26-2012, 03:03 AM
Many estimates are in the threads I reference for you (everyone asks the same questions!).
Old 08-26-2012, 12:05 PM
I read all of them thank you
Old 08-26-2012, 12:06 PM
Question
In this case what parts I need? I know one of them is head gasket.
Old 08-26-2012, 12:16 PM
bkovalick bkovalick is offline
PURE AWESOMENESS!!!!
Mein Auto: 03 BMW 530i / 2006 H2 SUT
If you buy a Bentley repair manual, head gasket jobs aren't that hard to DIY but I recommend finding a machine shop to deck the head before reinstalling it. You can DIY for a couple hundred bucks at the most
Old 10-17-2012, 04:30 AM
jarhed1964 jarhed1964 is offline
Mein Auto: '99 528i Sport, '05 530i
Yep.
Same engine (M52) I did in December, cost me a little less than $1000, but I did literally EVERYthing. Vanos seal, CCV, ALL hoses, injector o-rings, and even replaced a couple lifters and chain guides. If your lifters are all good, you won't have that expense, but if you have it all apart, I do recommend doing the VANOS seal, CCV, and every last hose you can reach.
Old 10-17-2012, 06:59 AM
ztom's Avatar
Head is likely cracked
