Old 08-21-2012, 01:27 PM
Orient330iNYC's Avatar
Orient330iNYC Orient330iNYC is offline
Flying monkey herder
Mein Auto: Daihatsu Terrios
Originally Posted by anE934fun View Post
What about going to a higher capacity AGM battery? Same technology (AGM) as the stock battery, but deep cycle vs std. (non-deep) cycle? I am thinking about a deep cycle AGM battery (like an Optima Yellow top) as a future replacement when the factory battery goes permanently on holiday.
nope, as long as its the same type its fine regardless of the capacity.
the charging circuit stops when the battery is at 12.6v, it will just take longer to get there with a larger capacity one
Past: 2001 330i ZSP/ZPP/Step
Past: 2004 S60R 6MT Sport
Old 08-22-2012, 01:33 PM
SD ///M4's Avatar
SD ///M4 SD ///M4 is offline
(prev. SD335is & SDZ4MR)
Mein Auto: 2016 M4 Coupe | 2006 Z4MR
Originally Posted by haskindm View Post
Here’s another option: these are Smart Jumper Cables from Michelin. Now, the first thing that you’ll notice about these is that there’s this big box in the middle of the cables. This is a module-it’s a smart module. Next thing you’ll notice is that all four cable ends are blue. So, here’s the drill: you start with the car that is running-has the good battery. You hook up two of the cable ends, doesn’t make any difference which way you hook them up because polarity is going to be controlled inside the module. Then you come over to the car with the dead battery, you take one of the remaining ends and hook it to the positive battery cable. Now you never hook booster cables-both of them-on the car with the dead battery, right to the battery. You always connect the last connection-the ground connection-to a good clean metal surface on the engine, not to the body because that can lead to its own set of problems. So, just make sure you’re connecting it to something that doesn’t move, and you’ve got a good connection.
Alright, you can also tell by looking at the module because the module has two warning lights on it. They’re both lit, then everything is good to go. If one of them isn’t, then you wiggle the cable ends around until you get a good connection. Both lights are lit-wait a couple of minutes, start the car with the dead battery and disconnect the cables. And no, you don’t have to worry about the surge, because this module has a built-in surge protector that protects both vehicles against that deadly voltage surge.
http://reviews.cnet.com/8301-13746_7-20063320-48.html
- Tom
His: 2016 M4 Coupe | Sakhir Orange Metallic | Black Full Merino Leather | CF Trim | M DCT | Adaptive M Suspension | 19" Black Alloy Wheels | ZEC | ZLP | ZDB | MPE | ED 5/13/16
Hers: 2011 335is Couipe | Le Mans Blue Metallic | Black Dakota Leather | Dark Glacier Aluminum | 6MT | ED 5/12/11
Also His: 2006 Z4 Roadster (E85) | Interlagos Blue Metallic | Black Extended Nappa Leather | Carbon Leather Trim | Purchased 7/19/12
Old 08-25-2012, 12:35 PM
BB_cuda's Avatar
BB_cuda BB_cuda is offline
Mein Auto: 2011 335D Msport
Guess i was careful and lucky
I have an older project car that the battery went dead on. I needed to jump and normally use my 2003 dodge truck for this. It happened to be a time when the 335D was nose to nose with the project car and it was starting to rain. So, I jumped using old school cables. I was very careful and methodic to get good strong bites with the jaws like connections. These slipping and touching is where i can see catastophy happening. Jumped off just fine and no drama for me.
After reading this, I will stick with the Dodge as the jumper although its a 2003 so it has a fair bit of electronics too. I'm thinking if you get a short in the wrong place it's not just high end cars that will get disabled. Now, the 67 cuda I'm sure you couldn't hurt provided you didn't catch the harness on fire. This last car is where my forum alias comes from
after jump, short, won't start
