Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M Series > E39 M5 (1998-2003)
E39 M5 (1998-2003)
Old 08-17-2012, 09:43 PM
Lucian1526 Lucian1526 is offline
Mein Auto: 2001 m5
Help
Hello... I'm new here.. I need to know what ripe of power steering fluid I need for 01 m5...I have a leak ..
Old 08-17-2012, 09:45 PM
Mein Auto: 2001 m5
...tipe *
Old 08-25-2012, 04:29 PM
ard ard is offline
Resident Curmudgeon
It uses ATF. Automatic transmission fluid.
I'll bet it was never serviced. Sad.
m5board dot com, much written about this. You have multiple hoses that can leak- low pressure (cheap) and high pressure ($$$)...oh, and if you are lucky like me a pump which grenaded and cost $400, plus $400 for hoses, a new reservour, and a very messy 3 hours.
At the very least, find out what is leaking, Buy the part and replace it, get as much old fluid out as you can, then add fluid, run and top off. I had so much metal in my system (ie the only part that wasnt replaced was the steering biox) that I had to run a few quarts through to flush the debris properly...
GL
A
