E90/E91/E92/E93 (2006 - 2013)
I just bought 2 new thrust arms (tension struts) for my 2006 330i (e90). I have the Haynes manual (which is just short of expensive fire starter paper) and it is saying that the ball joint torque setting is 122 ft lbs. This seems insanely high! Its saying the bushing nut torque setting is either 50 ft lbs plus 90 deg or 74 ft lbs plus 90 deg, depending on the nut grade.
Does anyone have a bentley or manufacturer manual that can confirm these settings?
I don't have a manual, but I've googled some fragments of bentley manuals. As far as I can gather, that does seem insanely high. Typical numbers seem to be < 80 ft lbs.
I am, of course, not a mechanic. I guess it's dumb to ask, but that number isn't actually 122 NM, right?
BMW CCA Member |
But, I sure would like to know before I ruin a $100 part (and potentially the ball joint socket which would really SUCK!) |
this may help:
http://www.engineershandbook.com/Tables/torque1.htm personally i dont know what the torque spec is for you application, but it looks like 122 ft/lbs is plausible for the application. on the E46 if i remember correctly, the bolts were 14mm.
Past: 2001 330i ZSP/ZPP/Step Past: 2004 S60R 6MT Sport Past: 2007 335i 6MT ZSP/ZCW/322/655 Past: 2010 335xi ZMP/ZCW/ZPP/PPK/PE Present: 2013 335i 6MT ZMM/ZDH/ZTP/3AG/494/508 Current Homeland Threat Level: Last edited by Orient330iNYC; 08-22-2012 at 09:04 PM. |
Tension strut to the swivel bearing (it's an M14 thread) is 165 Nm. The tension strut to the front axle support is 68 Nm plus 90 deg if it is an M12 8.8 thread or 100 Nm plus 90 deg if it's an M12 10.9 thread. I think your hex bolt is M12X1.5X115-8.8.
Thanks for the help!!
Appendix B - Torque Values ____________________________________ Ft Lb ________ N/M MISCL Wheel Lug Nuts..........................89..........120 Exhaust - forward flanges...............15...........21 - turbo engine only Exhaust - reinforcement plate...........43.5.........59 - +90° -+30° -- 8 Torx Bolts Exhaust - mid-pipe brace................??...........?? Exhaust hanger - differential...........26...........35 - turbo engine only Exhaust hanger - wheel carrier..........15...........21 - turbo engine only Exhaust hanger - rear chassis...........15...........21 - turbo engine only M3 STRUT BRACE Bulkhead mounting bolt...............73.75..........100 All other bolts......................25.07...........34 FRONT SUSPENSION Sway bar end link.......................44...........60 Sway bar mount to subframe..............16...........21....M8 bolts Tension Strut @ knuckle................122..........165 Tension Strut @ subframe................74..........100 Control Arm @ knuckle..................122..........165 Control Arm @ subframe..................74..........100 Strut Pinch Clamp.......................60...........81 REAR SUSPENSION Brake line to hose.......................9...........12 Sway bar end link.......................42.7.........58 Sway bar mount to subframe..............16...........21....M8 bolts Rear subframe bushings..................73.7........100 Upper Control Arm @ bearing carrier.....73.7........100....+90° Upper Control Arm @ subframe............73.7........100 Guide Arm @ bearing carrier.............73.7........100....+90° Guide Arm @ subframe....................73.7........100 Camber Arm @ bearing carrier...........121.6........165 Camber Arm @ subframe..................121.6........165 Toe link @ bearing carrier..............73.7........100 Toe link @ subframe.....................73.7........100 ------------------------------------------------------- |
Thanks Calwaterboy.
Quick question. On that Tension strut at subframe. Is it 74 ft. lbs. plus 90 deg or just the tourque of 74 ft lbs? My Haynes and the Bentley had 74 or 50 + 90 deg (depending on bolt grade), BUT your TIM may be a more current revision... |
Spec is: Tighten to torque, then turn add'l angle ammt. Excellent tool: CLICK HERE -- 1/2" does better at suspension torque values . Last edited by CALWATERBOY; 08-26-2012 at 08:28 AM. |
