Old 08-15-2012, 04:21 PM
Kevingovro Kevingovro is offline
Mein Auto: 2004 X3
White smoke on start up...
Hello,
I have a 2004 X3 with 87,000 miles on it...
Today I started it up and quite a bit of smoke blew out of the exhaust I turned the car off and looked and smelled around and found nothing ... I just had the oil separator hose/valve replaced, oil change, and the transfer case fluid flushed... I am getting ready to replace my expansion tank and upper radiator hose as well as a coolant flush....
Could any of this have a role in this smoke I just got this stuff fixed last week...
Any help is appreciated
Old 08-15-2012, 04:22 PM
Mein Auto: 2004 X3
Also I have no ses light showing up and my low coolant comes on when driving for a little bit ...oh and the ATF looks pretty low
Old 08-15-2012, 04:50 PM
Mein Auto: 2004 X3 2.5i
Originally Posted by Kevingovro View Post
.... and my low coolant comes on when driving for a little bit ...oh and the ATF looks pretty low
How do you know the ATF looks pretty low? No easy way to judge this that I know of.
Hopefully you haven't been driving too long on low coolant, and the white smoke is remaining junk from the oil separator issue.
Even with the oil change, I doubt all water in the engine gets purged right away.
Old 08-15-2012, 08:10 PM
Mein Auto: 2004 X3
Oh I just took the ATF cap off and it looks low
Old 08-15-2012, 09:09 PM
That's the power steering reservoir!
Uses ATF but only up until model year '07 or '08 I think, then specific PS fluid.
Old 08-15-2012, 09:26 PM
Mein Auto: 2004 X3
Oh so what do I put in it or do I need to worry about it
Old 08-15-2012, 10:00 PM
If the fluid is up to the notch at the lower part of the dipstick when cold, no need to add anything.
If it's not, check for a leak, and top off with any good brand name Dexron III.
Probably worthwhile changing the fluid every few years.
Old 08-16-2012, 06:36 AM
X3-terrestrial's Avatar
Aficionado
Was it smoking before? How many miles? A leakdown and cylinder compression test would be recommended to eliminate head gasket or other internal issues.
-Mario Andretti.
___________________
River City Bimmers BMW CCA
2002 ///M3 Coupe, Steel Gray Metallic on black leather, HK, three pedals.
1991 E30 325ic, AW, Black Leather, Black top, Three Pedals.
Old 08-16-2012, 06:50 AM
Mein Auto: 2004 X3
It's never done it before
Old 08-26-2012, 08:09 AM
Mein Auto: 2004 X3
This morning I had another white smoke on start up... Any ideas?
I changed the coolant, expansion tank, upper radiator hose,ect last week car has been running great
This is the second time I have seem white smoke on start up since taking it to the deal and having the oil seperator valve replaced and transfer case fluid changed...
Old 08-26-2012, 09:30 AM
Aficionado
Why did you have the the oil separator replaced in the first place? White smoke can be a sign of oil separator, so I 'd take it back to the same place and have them double check their work.
As said before, it also could be the head gasket, have you noticed the coolant disappearing? is that the reason you changed the expansion tank and the radiator hose? Again, from here you'll need a leak down and compression test to be able to diagnose.
-Mario Andretti.
___________________
Old 08-26-2012, 11:25 AM
Mein Auto: 2004 X3
The old one had a large crack and was falling apart had it done at the dealer
