Heated Seats Problem - Bimmerfest - BMW Forums
Old 12-27-2011, 10:13 AM
gofastslowly gofastslowly is offline
Mein Auto: 2006 325i
I have a 2006 325i with heated seats. Yesterday when turning the seats on (it always defaults to the highest or "3 lights" setting), the function turned itself off after 10 seconds or so. I tried changing the setting to medium or 2 lights; same result. This happened several times throughout the day. However today the heat worked fine. Any thoughts as to why this is happening? Loose wire, fuse, switch, etc? Has not happened on the passenger side.
Old 12-27-2011, 11:13 AM
AzNMpower32's Avatar
Tar Heel Faithful
What condition is your battery in? The module shuts off unnecessary functions or reduces functions when the battery charge is too low.
Old 12-27-2011, 11:17 AM
Scorchpa Scorchpa is offline
Mein Auto: 335 ix
Same thing happened to me yesterday with my steering wheel. A search on this forum showed that others have had the same. recommendations were...
1) do not turn on heater for 10-15 seconds after car starts
2) replace the fuse for the heater.
might work with your seats as well
Old 12-27-2011, 01:33 PM
Great thought. Battery seems to turn over fine although we haven't had much cold weather yet this year. How do I know if my battery is starting to get weak otherwise? Should a battery be replaced after "x" number of years before it goes dead or show signs of weakness as you've mentioned?
Old 12-27-2011, 02:20 PM
Tar Heel Faithful
We replaced the battery on the 06/06 build 325i last month. Probably a good idea if you're still on your first battery even if it turns over fine. We didn't notice any issues with the 325i but did it anyway.
Old 12-27-2011, 03:54 PM
SD ///M4's Avatar
SD ///M4 SD ///M4 is offline
(prev. SD335is & SDZ4MR)
Mein Auto: 2016 M4 Coupe | 2006 Z4MR
Is your clock running slow?
- Tom
His: 2016 M4 Coupe | Sakhir Orange Metallic | Black Full Merino Leather | CF Trim | M DCT | Adaptive M Suspension | 19" Black Alloy Wheels | ZEC | ZLP | ZDB | MPE | ED 5/13/16
Hers: 2011 335is Couipe | Le Mans Blue Metallic | Black Dakota Leather | Dark Glacier Aluminum | 6MT | ED 5/12/11
Also His: 2006 Z4 Roadster (E85) | Interlagos Blue Metallic | Black Extended Nappa Leather | Carbon Leather Trim | Purchased 7/19/12
Old 12-30-2011, 12:05 PM
Update: The battery was replaced in 2009; the clock is accurate; and the issue with the heated seats continues although it's sporadic. I will leave the main heat off and wait at least 15 seconds before turning on the seat heater (only the driver's side is problematic). Any other suggestions would be appreciated. Perhaps a loose wire or contact or the switch itself?
Old 01-10-2012, 12:03 PM
Problems continue. I think I've narrowed it down to either the switch or the element in the seat. It is only on the driver's side. To reiterate; when I push the heated seat button, the 3 lights go on and within 1-4 seconds the lights turn off; if I again hit the switch, the heating level reduces indicated by 2 lights, however the system turns itself off as well. I will not pay big $$ to have the seat taken apart. Is there a DIY for the switch? Can I take the passenger side switch and swap for the driver's side to isolate if in fact it is a switch? Lastly, any other thoughts? Battery is new, clock runs fine and all other electrical is good.
Old 08-24-2012, 10:45 AM
midnitemyst midnitemyst is offline
Mein Auto: 528i
Did you ever find any answers to this? I'm in the exact same situation with the same exact questions. Would be nice to know if you got anywhere with the repair. Hope to hear from you soon. Gonna need these seats for the upcoming winter!
Old 08-24-2012, 01:31 PM
heated seat problem
Seems like a fairly common problem. The contact within/inside the seat breaks and renders the heat useless. The only way to repair is to rip apart the seat and fix/replace the contact parts. I decided the $1,000+ estimate I got was not worth it. Also, soon after my power seat (driver side as well) went haywire. It only works when no pressure is on the seat, ie. from a standing position or when I lift my butt up. Only real problem with my 06 325i since I bought it new....at 92k miles and running.
Old 08-24-2012, 10:52 PM
Mein Auto: 528i
That's a shame to hear. Would have really liked to use this heated seat for winter. Didn't try anything with the switch then? Or anything else to try and fix it?
Old 08-25-2012, 07:17 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
I'd have a look at the system layout to begin, assuming this a DIY request.
Are you familiar with the seat heating electrical system? True to BMW philosophy, and German Engineering, it's much more complicated than we think.
Dang! Just noticed....this thread last year's news....like, now giving birth?
Old 08-25-2012, 07:55 AM
sunny5280 sunny5280 is offline
Mein Auto: 2011 X5-M
Don't feel embarrassed...it was "reopened" as someone did a search on their problem, came across the thread, and asked if there was a resolution (as none was posted).
Old 08-25-2012, 05:11 PM
BobBNY BobBNY is offline
Mein Auto: 2015 535d
An idea
How about trying to find a used replacement seat from a salvage yard, etc? Probably a lot cheaper. Not sure how you can test it before buying, but perhaps you can buy it on the condition that all of the electronics work, etc.
BB
Old 08-27-2012, 10:44 AM
Mein Auto: 528i
I may still try just replacing the switch as a cheap solution to an otherwise pretty expensive problem. Better than nothing. I finally have heated seats and I can't use it in Winter!
Old 12-24-2013, 06:27 AM
loboracer loboracer is offline
Mein Auto: 1999 328i
I am having the same problem with the driver's seat on my 99 328i e46. The light will not stay on for more than a second when cold. Once I get driving I can get it to stay on. The seat doesn't seem to heat as fast as my 99 323i but does work well once it will stay on. Pass side works great. I have checked multiple forums. Is there no one that has figured this out yet?
Old 12-24-2013, 02:44 PM
Banned
Mein Auto: 2007-335 HTC
A Digital multimeter would be a good investment and check the plug under the
Seat and see if there is power to the seAt. Also not too difficult to take
The bottom seat cover off. Just need some hog rings and hog ring pliers
Old 12-24-2013, 02:50 PM
I have the multi meter. There has to be power getting there at least a few minutes after I am driving it because it will cook my rear. Is there a ground or something that is common for having a bad connection? Really weird, seems like once I start driving it will stay on but will not if car is cold and idling. Car starts right up, batt is good.
Old 12-24-2013, 05:31 PM
fdriller9 fdriller9 is offline
Mein Auto: '06 AW 330xi
How is your battery? In e9x at least, heated seats are considered a convenience feature. The car will disable convenience features such as heated seats, welcome lighting, comfort access, etc to conserve power.
| LCI Msport Conversion | Exotic Tuning Front Lip | H&R Coilovers | M3 Subframe Bushings | Custom Polyurethane Shore A90 Tension Strut Bushings | E93 M3 23.6mm Rear Sway Bar | UUC Front Sway Bar | Custom Heim Joint Rear Control Arms | Apex ARC-8 | Dunlop Direzza ZII Star Spec | Modified Dinan Cold Air Intake | aFe Oiled Drop-in Filter | Custom Hand-Made LED Angel Eyes | Alpine MRP-M500 | Custom LED Reverse Lights | OEM Blacklines | BMW Performance Trunk Spoiler |
Old 12-24-2013, 05:38 PM
R1200 R1200 is offline
Mein Auto: 328XiT and R1200C
It's not worth spending big bucks to fix this problem when you can easily add a heated cushion for a couple of winter months. I have used the heating element from these cushions as they include a thermostat and I sew them into a pocket on the back of my motorcycle jackets for days when wind chill is a factor. It might be possble to add a thermostat to your existing heated seat and skip the fancy three level control from BMW which probably cycles the heater at varying rates.
I once disassembled a leather seat from a sports car to make repairs and improve the cushioning. It was a project where hands get cut up and special tools are required. Not fun and certainly not worth it when a separate cushion will fix the problem.
Consider lamb skin for a seat cushion. It's not heated but an excellent insulator.
Don
328XiT Sonora
Old 12-24-2013, 05:39 PM
It turns over fast and starts easily even in the single digit temps we are having. I was wondering if there could be a bad connection somewhere that would make this happen until warm.
