Old 08-26-2012, 08:59 AM
pastman pastman is offline
Mein Auto: 2007 328xi
Question TPMS "rebuild"
Greetings Members:
I own a 2007 328xi with sport package, I've just hit 84K. The previous owner of my car (I bought it with 47K) had switched out the original run-flats for 4 Nokian WR G2 (225/40 18). I've been happy with these tires, they're awesome in Connecticut winter conditions. I plan to replace them - question: is it necessary to do a TPMS sensor "rebuild"? The car is 5 years old, some people say that the sensors are good for 10 years. I've had no problem with the TPMS. Please advise.
Thanks,
Alan
Old 08-26-2012, 09:08 AM
Orient330iNYC's Avatar
Flying monkey herder
Mein Auto: Daihatsu Terrios
a rebuild kit is only new gaskets and washers-- typically not needed unless the valve is removed or leaking.
a whole new sensor is about 50-80 each.
Past: 2001 330i ZSP/ZPP/Step
Past: 2004 S60R 6MT Sport
Past: 2013 335i 6MT ZMM/ZDH/ZTP/3AG/494/508
Present: 2016 F34 335i xDrive ZCW/ZDA/ZDH/ZTP/ZMP/2V5/5DL
Old 08-26-2012, 09:20 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
What recommended that?
Old 08-26-2012, 09:23 AM
laser's Avatar
laser laser is offline
now driving number eight!
Mein Auto: 2007 S2000
When we replaced our tires recently my tire dealer (who I trust) recommended rebuilding the TPMS sensors for $8.50 each. At that price I did't over think and just went with their rec. They always put new valve stems when replacing tires as well.
Laser
"sometimes you're the windshield .... sometimes you're the bug"
___________________________
2014 328i Mojave Metallic
2007 328i Black Sapphire Metallic
(Hey Jim... am I diversified?)
Old 08-26-2012, 09:30 AM
the "rebuild" kits are almost pure profit. a new valve core and a rubber gasket. no new stem, no new sensor.
Old 08-26-2012, 09:31 AM
roadkillrob roadkillrob is offline
Mein Auto: 325CIC, 335CIC
It is normally recommended when replacing the tires, the rebuilt kit is the valve and hardware, not the TPMS itself, there is a rubber seal that does not crush well the second time that I would do as they are 5 years old .
2008 335i Vert Montego/Saddle/Grey Poplar
2013 Mercedes C63 AMG Obsidian Black/Black
2016 X5 M-Sport Mineral White/Mocha Design Package/Fineline Oak
Old 08-26-2012, 11:51 AM
Zooks527's Avatar
Zooks527 Zooks527 is online now
Winding up the M235xi
Mein Auto: 2015 M235xi / 2005 Tacoma
Same here. My indy quoted $4 per sensor for the new gaskets/cores and suggested their being changed with the tire, as he was pulling the cores to deflate them. Tire Rack said the same thing. I had them replaced.
2015 M235xi coupe, Black Sapphire Metallic, Black Leather, Fineline Stream trim, Steptronic, xDrive, ZPP, ZTP, ZCW, ZDA, ZDB, 5DP, hk w/ BimmerTech amp, Enh. BT
Ordered 3/12/15, Off the line 4/7/15, Delivered 5/14/15
Prior 40 years of cars: 1967 BelAir wagon / 1968 LeMans Tempest / 1970 Mustang Mach 1 / 1972 El Dorado / 1978 Corvette / 1981 Subaru GL wagon 4WD / 1983 s10 Blazer 4x4 / 1985 Bronco 4x4 / 1996 Bronco 4x4 / 2004 Passat 4motion / 2009 BMW 335i xDrive E92
Old 08-26-2012, 02:01 PM
pointandgo's Avatar
Greetings Members:
Thanks,
Alan
The rubber grommet (air seal) on your TPMS is now five years old. The rebuild kit contains a fresh replacement, and I would recommend doing this as another 2 - 3 years is too much IMO. Even BMW says that our tires shouldn't be used beyond 6 years!
F30 320i
F30 328i
E90 328i
E92 335i 6MT
E46 M3 6MT
E39 528i 5MT
MBz W140 S320
MBz W124 300E (slammed)
(unmentionables in between)
Member: BMW CCA
Old 08-26-2012, 03:21 PM
fun2drive's Avatar
BMWCCA 149159
Mein Auto: 335 vert/14JGC/ 13Outback
The real issue is the li-ion battery which has a useful life of around 8 years. From what I know you cannot replace the battery since it is sealed and must replace the whole unit.
Old 08-26-2012, 10:52 PM
Thanks for the info on the ion battery. I'll get the "rebuild" gasket kit (for the tire valves) when I get the new tires installed. Hopefully, I won't have to worry about replacing the TPMS sending units until the new tires have been used up.
Has anybody out there had the ion batteries fail in a 2007 or newer?
Old 08-27-2012, 12:15 PM
pointandgo's Avatar
There have been a few posts of apparent battery failures for 2007 vehicles. I'm not entirely sure that these reports weren't due to TPMS damage from tire mounting/dismounting or contamination/clogging of the unit. Nevertheless, Beru stated battery life of 5 - 9 years IIRC. I've heard of 10 yrs. on the upper end. Certainly the '07 models will be the first to go, and we can expect battery life failures to fall into a 'normal curve' for age at failure.
F30 320i
F30 328i
E90 328i
E92 335i 6MT
E46 M3 6MT
E39 528i 5MT
MBz W140 S320
Member: BMW CCA
