Old 08-26-2012, 02:39 PM
KayWhitt107 KayWhitt107 is offline
Mein Auto: 2012 335i xdrive
Catless down pipe
Hey guys. So tomorrow I'm getting my OEM exhaust modded by taking out the cat and making it a straight pipe, adding a catless down pipe, and a jb4 tune. My question is will my car pass inspection? I know it wouldn't pass a visual inspection but I highly doubt my shop does that. Thanks!
Old 08-26-2012, 03:26 PM
twhisten twhisten is offline
Drive it like u stole it!
Mein Auto: 2016 M3
It most likely will not pass the emissions inspection.
1997 328i- retired
2007 328i- retired- lease
2006 330xi- retired
2011 335xi-PCD-12/13/10 - DINAN3-----retired
2013 M3-Laguna Seca-6 speed-EDC ------retired
2016 M3
2006 X5- retired
2011 X5- retired- buy back
bmw cca#443379
Old 08-26-2012, 03:38 PM
Even with the 02 sensors?
Old 08-26-2012, 08:00 PM
MRU MRU is offline
Mein Auto: BMW 335i Sedan (E90)
Yes, even with the O2 sensors.
Old 08-27-2012, 02:34 PM
Verts4Ever's Avatar
Verts4Ever Verts4Ever is offline
Random Helpbot
Mein Auto: 2011 E93 335i
Nice, Kay. You'll get a noticeable power bump out of that combo.
No, you'd need a DP fix to trick the DME into seeing an acceptable signal from the O2 sensor. The JB4 auto code-clearing function is not the same thing.
Until now there hasn't been a DP fix available for the N55, but you can read here about BMS currently beta-testing one. If you eventually add the DP fix and pass the OBDII inspection, there's a chance that your shop won't lift the car for visual inspection. If it does lift the car, you'll likely fail the inspection.
Cheers.
