Failed inspection - Bimmerfest - BMW Forums
E36 (1991 - 1999)
Old 08-22-2012, 02:53 PM
Jaredd5 Jaredd5 is offline
Mein Auto: 97 328is
Failed inspection
Just bought a 97 328is with 64000 miles on it and took it to get inspection and failed. My mechanic said i needed new ball joints, right rear trailing arm, transmission mount, and sway bar bushing. I can do all the work myself but a new trailing arm seems kinda weird. Isnt it usually a bushing that goes? I feel like the mechanic is just trying to get money. It drives pretty good and dont notice and rear end slop.
Old 08-22-2012, 03:37 PM
kptaylor kptaylor is offline
Mein Auto: '98 323iS, '99 528i
Sure he didn't mean trailing arm bushing? Get under it and take a look! Right at the front of the rear wheels.
Old 08-22-2012, 03:54 PM
Mein Auto: 97 328is
He meant trailing arm because he quoted me 650 for the part itself..
Old 08-22-2012, 04:29 PM
drivinfaster's Avatar
Mein Auto: rescued bmw's
is it bent or cracked??
df
Old 08-23-2012, 11:51 AM
ReillyM3's Avatar
ReillyM3 ReillyM3 is offline
Mein Auto: 1994 325i sedan
Sounds like he is padding the invoice. If I were you I would take it somewhere else and see if the two estimates have commonalities. If there are any, there you go.
1994 325i (current)
2006 325i (current)
1995 525i
1990 325i
1988 Jetta 8v
1987 Gti 16v
1985 Jaguar Xj6
1984 Jaguar Xj6
1966 Mustang
1965 Falcon Wagon
1961 Buick Special
1962 Buick Special Wagon
1955 Pontiac Cheiftan
1961 Falcon Tudor
1962 Faclon Ranchero
Old 08-25-2012, 12:15 PM
Mein Auto: 97 328is
I have access to a lift today so im gonna check for any warping or cracks in it.
Old 08-26-2012, 09:23 AM
DEATH2000's Avatar
DEATH2000 DEATH2000 is offline
Mein Auto: 1998 BMW E36 328i,
A trailing arm is not a normal wear item. Replacements are pretty expensive. Unless you smashed into a curb i dont see it needing to be replaced. As Reilly said, hes just milking it for more.
The sway bar bushings i can see needing replacement as they do wear out. Their pretty inexpensive and something you can do yourself. As for the ball joints, to test if their good or not, grab the wheel at 3 and 9 and shake it. Their shouldnt be any play. It should feel solid.
ProjectTechnik.com - Alberta based BMW Community
See My car on Project Technik HERE!
| OE M3 Bumper | M3 Mirrors | Jim Conforti CF CAI | UUC Motorwerks Underdrive Pulleys | 18x8 ASA AR1's | Koni Sport Springs & Shocks |
Founding Member of the Canyonrot Club! #343!
Old 08-27-2012, 11:29 AM
Mein Auto: 97 328is
my mechanic said that the trailing arm bushings are bad so thats why i need a whole new trailing arm. Im just gonnna get the ball joints done there too because i dont have a press to get the ball joints in and out of the control arms.
Old 08-27-2012, 03:53 PM
hornhospital's Avatar
D'oh, You Kids!
Just buy the control arms with the ball joints in them. You can't change the inner ball joint anyway (can't change either one on the M3 arms, FYI)
Quotes to live by:
BMW-CCA #441426
