BMW Coding and Programming
Discuss coding options and features on your BMW here. |
#26
You actually have 47.1 on your car, and for some inexplicable reason, 47.4 did not contain 6 CAFD files that were in 47.1, so if you need the other 5, let me know. Right Orphan Files (6) Size Modified ------------------------------------------------------------- cafd_0000000f.caf.005_024_220 1,006,395 6/14/2012 8:28:02 AM cafd_0000000f.caf.005_024_221 1,004,963 6/14/2012 8:08:18 AM cafd_0000000f.caf.005_024_222 1,005,095 6/14/2012 8:00:04 AM cafd_00000a3f.caf.005_001_008 142,521 6/14/2012 7:06:02 AM cafd_00000794.caf.002_020_029 6,060,497 6/14/2012 7:05:54 AM cafd_00000794.caf.004_122_077 6,468,403 6/14/2012 6:40:58 AM
![]() - 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC - 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11) - BMWCCA #446923 - flickr® |
#27
Shawn
I too may need the 47.7 files. I have a 2103 x3 and am in Germany, Just now got all my things together and started coding. With your previous help (and I am so ever grateful) I was able to change the radio frequencies to the European standards (instead of the US) and it really works! But I have some data display errors (when the display is showing the radio frequencies or names) and cannot figure out how to correct it. For example - some numbers appear to be doubled on a single character. i.e. a 7 and a 4 may appear on top of each other... and sometimes it looks like a check-mark is on top of a number (single digit) Anyway - I am using 46.6 (as far as I can tell) and have had no coding errors - it may be that some other setting needs to be changed. However a link to 47.7 would be greatly appreciated And if anyone else in the Kaiserslautern Germany area would like to get together to work on this coding stuff, please let me know.... Thanks for ALL of the help and assistance you guys provide to us newbies!!! |
#28
I'll send you 47.4 links now though to hold you over... So, HU_CIC / 3002 AUDIO_TUNER_TRAFFIC / RADIO_COUNTRY - ECE did the trick for you in that your FM Radio is now tuning in 100khz increments, and you are picking up the even FM channel center frequencies? I figured it would, but thanks for confirming it did. I will update the F10 Cheat Sheet for Rev. 4.
#29
Shawn
Got your PM. Thanks so much! And...Sorry about the 47.7 typo - I should put my glasses on when I first get up! ![]() Yes! I can confirm the info you gave works to change the FM frequency spacing. It ALSO works on the AM band - it changed that to 9khz (rather than 10khz) so the AM works perfect. Now if I could just get rid of the random "check-marks" that show up on the display... Additionally the scrolling function for "automatically scanned" frequenciies does not work properly. If I go to that screen, I see 10 - 15 radios frequencies that the tuner has found and normally you can just scroll thru them and select one - well the "scroll" function (the red rectulangular box) does not scroll correctly. If you go up 3 or 4 it jumps back to the bottom of the list. (I don't know.... but perhaps Bummel can help? He is in Germany too?) There must be something else that I need to change - I will search tonight (I am at work) btw - the auto door unlock function works GREAT! I am soooo happy! (simple things can make a big difference) |
#30
Hello,
i´m new on the board and i have expirience with NCS-Expert and Esys. I have Esys 3.18.4 with PSDZDATA V46.3 an did some coding on a F10 2010 Now my friend will visit me on Sunday with his brandnew 535i (F10 2013). Is it possible to do VIM with this version of PSDZDATA-Files? If not, where can i find new files? Do i need a newer Esys-Version? |
#31
#32
#33
delete
#34
I don't know how/where to remove the S654A.... from the VO.. and thats just the start. If its somewhat "dangerous" to the car or too complicated (without very specific instructions), I'm not sure I want to try it yet.
#35
#36
hey shawnsheridan can you send me the new full 47.4 data package too?? i will experiment with the HUD Entertainment List and Telephone, cause i didnt found these options in kombi Module. i will also ask my dealer about an update for programming with 47.x, perhaps it will work than. thanks sibob Last edited by sibob; 08-28-2012 at 11:54 PM. |
#38
Please send me a PM with the download of 47.x too.... THANKS!!!
#39
#40
Could you please send me the link to the 47.4 PSDZdata files as well. My 530D from July 2012 also has 1 module that does not work with 46.6.
#41
PM Sent.
#42
I am still going thru all the SVT to see if any other thing looks like it will help. One item of note is the fact that for FM in the US, the normal deemphasis is 75us (micro seconds) most of the rest of the world uses 50us. So I am gonna change that option - Idoubt it will do anything, but ya never know.... AND.... I finally got Jdownloader working to get all the new 47.4 files. Took a while but they are here. Thanks so much for the post and advice! Now I just need to know how to load them into esys and "move out" the 46.6 version. Do I need to re-install esys? or just unpack the rar files? Will they self install and replace the old version? I don't want to mess up what I already have... ![]() THANKS! Last edited by Randeyman; 08-29-2012 at 02:09 PM. Reason: spelling |
#43
Are you anywhere near K-Town? If so PM me - maybe we can share info.
#44
1)Delete psdzdata folder from C:\ESysData\ Install 47.4: 2) Extract psdzdata folder from 47.4 Archive 3) Copy new psdzdata folder to C:\ESysData\
![]() - 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC - 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11) - BMWCCA #446923 - flickr® Last edited by shawnsheridan; 08-29-2012 at 02:34 PM. |
#45
Will give an update on things in a day or two - today is my Anniversary - so the wife is top priority!
#46
Celebrate!
#47
Hi!
I want to code a F30 but my PSDZData is to old, can some please send me the links for the 47.4 Version? That would be very nice, thanks Btw cool board ... was using another but i think i will switch to this |
#48
PM sent.
#49
Thx
#50
Here the same issue
want to code F30 but only some modules were shown HU_CIC is missing which contains many features which i want to code actually ive 46.3 and 46.6 both arent good for me could you send me 47.4 please are these 6 cafd-files which are in 47.1 and in 47.4 missing important? do i need them? thanks in advance |
