Old 08-27-2012, 08:58 PM
shawnsheridan's Avatar
Mein Auto: 2011 535i M-Sport
Originally Posted by falcongeek View Post
I think you sent me 47.4, at least the files all had 47.4 in the title so I am assuming they were right.
Ok, good.
You actually have 47.1 on your car, and for some inexplicable reason, 47.4 did not contain 6 CAFD files that were in 47.1, so if you need the other 5, let me know.
Right Orphan Files (6) Size Modified
cafd_0000000f.caf.005_024_220 1,006,395 6/14/2012 8:28:02 AM
cafd_0000000f.caf.005_024_221 1,004,963 6/14/2012 8:08:18 AM
cafd_0000000f.caf.005_024_222 1,005,095 6/14/2012 8:00:04 AM
cafd_00000a3f.caf.005_001_008 142,521 6/14/2012 7:06:02 AM
cafd_00000794.caf.002_020_029 6,060,497 6/14/2012 7:05:54 AM
cafd_00000794.caf.004_122_077 6,468,403 6/14/2012 6:40:58 AM
- 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC
- 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11)
- BMWCCA #446923
- flick
Old 08-27-2012, 10:20 PM
Randeyman Randeyman is offline
Mein Auto: 2013 X3
Originally Posted by shawnsheridan View Post
PM Sent with D/L Links.
Shawn
I too may need the 47.7 files. I have a 2103 x3 and am in Germany, Just now got all my things together and started coding. With your previous help (and I am so ever grateful) I was able to change the radio frequencies to the European standards (instead of the US) and it really works! But I have some data display errors (when the display is showing the radio frequencies or names) and cannot figure out how to correct it. For example - some numbers appear to be doubled on a single character. i.e. a 7 and a 4 may appear on top of each other... and sometimes it looks like a check-mark is on top of a number (single digit)
Anyway - I am using 46.6 (as far as I can tell) and have had no coding errors - it may be that some other setting needs to be changed. However a link to 47.7 would be greatly appreciated
And if anyone else in the Kaiserslautern Germany area would like to get together to work on this coding stuff, please let me know....
Thanks for ALL of the help and assistance you guys provide to us newbies!!!
Old 08-27-2012, 10:37 PM
Originally Posted by Randeyman View Post
Shawn
47.7? I want that too, but I think it is still baking in the BMW oven in Munich.
I'll send you 47.4 links now though to hold you over...
So, HU_CIC / 3002 AUDIO_TUNER_TRAFFIC / RADIO_COUNTRY - ECE did the trick for you in that your FM Radio is now tuning in 100khz increments, and you are picking up the even FM channel center frequencies? I figured it would, but thanks for confirming it did. I will update the F10 Cheat Sheet for Rev. 4.
- BMWCCA #446923
- flick
Old 08-27-2012, 11:54 PM
Mein Auto: 2013 X3
Shawn
Got your PM. Thanks so much! And...Sorry about the 47.7 typo - I should put my glasses on when I first get up!
Yes! I can confirm the info you gave works to change the FM frequency spacing. It ALSO works on the AM band - it changed that to 9khz (rather than 10khz) so the AM works perfect. Now if I could just get rid of the random "check-marks" that show up on the display...
Additionally the scrolling function for "automatically scanned" frequenciies does not work properly. If I go to that screen, I see 10 - 15 radios frequencies that the tuner has found and normally you can just scroll thru them and select one - well the "scroll" function (the red rectulangular box) does not scroll correctly. If you go up 3 or 4 it jumps back to the bottom of the list.
(I don't know.... but perhaps Bummel can help? He is in Germany too?)
There must be something else that I need to change - I will search tonight (I am at work)
btw - the auto door unlock function works GREAT! I am soooo happy! (simple things can make a big difference)
Old 08-28-2012, 05:22 AM
Sleb Sleb is offline
Mein Auto: BMW
Hello,
i´m new on the board and i have expirience with NCS-Expert and Esys.
I have Esys 3.18.4 with PSDZDATA V46.3 an did some coding on a F10 2010
Now my friend will visit me on Sunday with his brandnew 535i (F10 2013).
Is it possible to do VIM with this version of PSDZDATA-Files?
If not, where can i find new files?
Do i need a newer Esys-Version?
Old 08-28-2012, 07:16 AM
Shawn
There may still be other coding. One option you may want to try is to remove S645A RADIO-STEUERUNG US BMW US Radio from your VO, Write the new FA/FP to the car, and then VO CODE the CIC and see if that works.
- BMWCCA #446923
- flick
Old 08-28-2012, 07:21 AM
Originally Posted by Sleb View Post
Hello,
You need only the new PSdZData. E-Sys 3.18.4 is fine. PM Sent.
- BMWCCA #446923
- flick
Old 08-28-2012, 07:58 AM
Mein Auto: 2013 X3
delete
Old 08-28-2012, 08:08 AM
Mein Auto: 2013 X3
Well.. OK I sincerely appreciate the advice/suggestion. Not sure I am ready to try to change the VO just yet. I'm still a bit nervous about the changes I have made/am making. I have the .pdf file about changing the VO, but really don't fully understand it all. When I read your suggestion, it doesn't fully compute (its not you - its ME!)
I don't know how/where to remove the S654A.... from the VO.. and thats just the start.
If its somewhat "dangerous" to the car or too complicated (without very specific instructions), I'm not sure I want to try it yet. But I'm ready to learn!!!
Old 08-28-2012, 08:42 AM
It really isn't. When you get more comfortable with E-Sys, PM me, and I will explain it in detail.
- BMWCCA #446923
- flick
Old 08-28-2012, 03:15 PM
April1 April1 is online now
Mein Auto: X3 2011
As a first exercise to gain more confidence, try to save your FA and SVT to a local folder. And also see that you can load them back to E-Sys without reading from the car.
Old 08-28-2012, 11:50 PM
sibob sibob is offline
Mein Auto: F10 535d
You need only the new PSdZData. PM Sent.
hey shawnsheridan
can you send me the new full 47.4 data package too?? i will experiment with the HUD Entertainment List and Telephone, cause i didnt found these options in kombi Module.
i will also ask my dealer about an update for programming with 47.x, perhaps it will work than.
thanks
sibob
Old 08-29-2012, 04:45 AM
clem86 clem86 is offline
Mein Auto: BMW
Please send me a PM with the download of 47.x too.... THANKS!!!
Old 08-29-2012, 05:53 AM
Originally Posted by sibob View Post
hey shawnsheridan
thanks
sibob
PM's Sent.
- BMWCCA #446923
- flick
Old 08-29-2012, 01:33 PM
Dr.Frankenstein Dr.Frankenstein is offline
Mein Auto: F11 530D
Could you please send me the link to the 47.4 PSDZdata files as well. My 530D from July 2012 also has 1 module that does not work with 46.6.
Old 08-29-2012, 01:39 PM
PM Sent.
- BMWCCA #446923
- flick
Old 08-29-2012, 02:09 PM
Mein Auto: 2013 X3
Shawn
I am still going thru all the SVT to see if any other thing looks like it will help. One item of note is the fact that for FM in the US, the normal deemphasis is 75us (micro seconds) most of the rest of the world uses 50us. So I am gonna change that option - Idoubt it will do anything, but ya never know....
AND.... I finally got Jdownloader working to get all the new 47.4 files. Took a while but they are here. Thanks so much for the post and advice! Now I just need to know how to load them into esys and "move out" the 46.6 version. Do I need to re-install esys? or just unpack the rar files? Will they self install and replace the old version? I don't want to mess up what I already have...
THANKS!
Old 08-29-2012, 02:12 PM
Mein Auto: 2013 X3
Are you anywhere near K-Town? If so PM me - maybe we can share info.
Old 08-29-2012, 02:20 PM
Shawn
THANKS!
Remove 46.6:
1)Delete psdzdata folder from C:\ESysData\
Install 47.4:
2) Extract psdzdata folder from 47.4 Archive
3) Copy new psdzdata folder to C:\ESysData\
- BMWCCA #446923
- flick
Old 08-30-2012, 07:40 AM
Mein Auto: 2013 X3
Remove 46.6:
Install 47.4:
Got it. THANKS (again and again!)
Will give an update on things in a day or two - today is my Anniversary - so the wife is top priority!
Old 08-30-2012, 07:51 AM
Mein Auto: X3 2011
Celebrate!
Old 09-02-2012, 03:23 PM
crazyiven crazyiven is offline
Mein Auto: E90 LCI 335d
Hi!
I want to code a F30 but my PSDZData is to old, can some please send me the links for the 47.4 Version? That would be very nice, thanks
Btw cool board ... was using another but i think i will switch to this
Old 09-03-2012, 01:45 AM
Originally Posted by crazyiven View Post
Hi!
PM sent.
- BMWCCA #446923
- flick
Old 09-03-2012, 06:47 AM
Thx
Old 09-03-2012, 02:09 PM
user4970 user4970 is offline
Mein Auto: F30 328i
Here the same issue
want to code F30 but only some modules were shown
HU_CIC is missing which contains many features which i want to code
actually ive 46.3 and 46.6 both arent good for me
could you send me 47.4 please
are these 6 cafd-files which are in 47.1 and in 47.4 missing important?
do i need them?
thanks in advance
