Comfort of 20" All season non-RFT vs performance RFT - Page 2 - Bimmerfest - BMW Forums
Old 08-27-2012, 11:59 AM
Lance Alot Lance Alot is offline
Mein Auto: 2012 BMW X5 35D
Originally Posted by bxmxwx View Post
The logic is right, but calling Chicago having *the worst roads imaginable* is a bit too much Have you been driving around NYC?
Saying SF roads are B+ is also a stretch, as they suck pretty bad in SF proper. The highways are OK, but if you spend much time in the city - be cautious about going with the 20's.
Old 08-27-2012, 12:06 PM
ard ard is online now
Resident Curmudgeon
Originally Posted by X548i20" View Post
Does anyone know if I can use the same spare tire for my winter (20's oem 214's) and my summer tires (19's oem 212's)?
I am pretty sure that the OD of all the tire offerings is the same...hence an OE 20" will have the same outer diameters at the OE 19"...which would mean only one spare tire is needed, or your spare should work for both.
Check for yourself- go to tirerack and look up both TIRES and see what the spec is for OD.
Of course, TREAD is a different story, but with a spare you are going no more that 40 miles at 40MPH, right?
A
Old 08-27-2012, 08:26 PM
dnadrifter dnadrifter is offline
Mein Auto: 2004 M3
Yep in SF and in CA in general, road quality can vary greatly. There are a lot of stretches that are quite poor.
2004 M3, Silver Gray / Blk, 6MT
2011 X5, 35d Sport Activity, Deep Sea Blue / Cinn
2013 X5, 35i Sport Activity, Platinum Gray / Blk, AD
Old 08-27-2012, 08:31 PM
Mein Auto: 2004 M3
I had a dealer comment yesterday that he would be very careful about putting non run flats on an X5, because the X5 and its suspension was designed for hard side walls not soft. He thought that it would make the care feel mushy. Granted this is just his opinion, but he is probably the most technically sound dealer of about 5-10 that I have talked to in the last 3 months.
I am curious what opinions are on this here. I had been pretty set on putting non-run flats on regardless of the size, but now I am thinking about it a bit. I think ARD has said the that he Michelin latitude run flats are actually pretty good.
Old 08-27-2012, 09:00 PM
335i 335i is offline
Sup3rman
Mein Auto: '11 E90 AW M3/ '11 AW X5d
I changed to non-RFT's the ride softened a bit after the Michelin's that came stock, but I got the spare tire intentionally so I could ditch RFT's. I will say that I anticipate AD to be a better option with non-RFT's than stock suspension. Stock suspension didn't seem to wallow, but not as harsh, and not quite as "planted" as the RFT's (I think the "planted" feeling was a byproduct of the harshness though. 20's and AD are perfect, but I think non-RFT's will still be in my future. Had a 335i with RFT's, my m3 doesn't, and the m3 suspension actually feels less harsh over rough roads. Same with the X5 and RFT's being extremely harsh over rough roads - drove a LOT in OK, some of the worst roads in America, and AD made me instantly thankful.
2011 ///M3 Sedan Alpine White/Bamboo Beige/Piano Black ED 9/16/2011
2011 X5d Alpine White/Cinnamon/Bamboo PCD 6/21/2010
2007 335i Coupe - 6MT Alpine White/Saddle Brown ED 5/23/2007 (retired)
ED Trip Report W/ Pics (And Engagement Story/Pics)
Old 08-28-2012, 01:41 PM
Racedoc Racedoc is offline
Mein Auto: '08 X5 4.8, '04 M3 vert
I have the 20"'s on my X5 and just switched to the non-RFT continental extreme contacts. Greatest improvement in drive I've ever seen. Would recommend them highly.
Old 08-28-2012, 11:07 PM
Mein Auto: 2004 M3
So, I am guessing they are smoother? Any drop-off in handling?
Old 08-28-2012, 11:46 PM
the kidd's Avatar
the kidd the kidd is offline
pay it forward
Mein Auto: Subaru Impreza for now
also, there are no staggered 20 inch RFT all season that i know of. If there were, it would save me 2 hours at Direct Tire. I personally use the Dunlops in the warmer months and Perelli Scorpion Ice and Snows in the winter months on the same rim.
Present: 2012 X5M
2013 Honda Pilot Black/gray
Past: too many (the good, the bad, and the ugly)
Old 08-29-2012, 08:14 AM
Mein Auto: 2004 M3
I believe michelin latitude tour HP and cont dws are available
