E36 (1991 - 1999)
Old 08-30-2012, 07:51 AM
The Tick's Avatar
The Tick The Tick is offline
The Annoying One
Mein Auto: 2 E36's
What to do after buying an E36.
Ok, so I just bought an E36, and was wondering what to do after I have already bought it. I know I should change oil, air filter, oil filter, spark plugs, alignment, balancing, rotating, etc. But what else? If it were you buying the car, what would you do to make sure that it will be well taken care of and be babied? (I am doing this half for me and half for others.)
  • Cars
1993 BMW 325i 5-Speed Manual (Approximately 207,000 Miles) Daily Driver
1992 BMW 325i 5-Speed Manual (Approximately 270,000 Miles) Old Fixer Upper, and Eventually, a Track Monster
Old 08-30-2012, 08:02 AM
Psquare75 Psquare75 is offline
Insert funny text here
Send a message via AIM to Psquare75
Mein Auto: 93 325i
Close your eyes and open your wallet.
In all seriousness, mileage and age would matter. a 98 with 50K miles needs a lot less than a 205K mile 93...
Old 08-30-2012, 08:09 AM
TheFinanceGuy's Avatar
TheFinanceGuy TheFinanceGuy is offline
still learnin'
Mein Auto: 1998 328i Hellrot Red
Age matters... Parts wear out no matter what the milage reads.
Look into replacing the cooling system in addtion to your list (raditator, T-stat, platic hosing to metal, hoses and expansion tank. re-fill and bleed, then bleed some more).
Otherwise, enjoy the car!
Old 08-30-2012, 08:11 AM
jonesin's Avatar
jonesin jonesin is online now
The Canadian Prick.
Mein Auto: '96 328is Cosmos
Tranny fluid
brake fluid
diff fluid
power steering fluid
cabin micro air filter.
Then the whole cooling system:
fan, rad, expansion tank, bleeder screw, thermostat, thermostat housing, upper & lower rad hoses, water pump, rad cap, and if needed the fan clutch.
The fan clutch is the one component that can fail and not be an immediate catastrophe.
Then there are all the suspension bushings, the control arms, the tie rods, the bearings, the reinforcements for the rear shock mounts and the front shock tower reinforcement plates.
Get through all that, then we'll start going over the rest.
The Evolution of a Lady
“This is the fast lane, folks...and some of us like it here.”
--Hunter S. Thompson
Member of the Non-M Bumper By Choice Club
Old 08-30-2012, 09:06 AM
Mein Auto: 93 325i
I wouldn't be changing tie rod ends, front control arms, control arm bushings, fan clutches, and the like, simply due to age, as these are easy to check on the car.
If I were doing that cooling system refresh however, I'd definitely do the heater hoses. I'm not sure why no one ever mentions them. Yes it requires pulling the intake manifold, but odds are the vacuum hoses are soft and brittle under there anyway.
Oh. Buy this shirt, before you run out of money.
Old 08-30-2012, 09:37 AM
The Tick's Avatar
The Annoying One
Mein Auto: 2 E36's
Haha lol it is a '93 with 202k miles, you were close. Thanks everybody. This weekend I will order parts, and then start fixing stuff.
  • Cars
Old 08-30-2012, 10:09 AM
Time2Fly's Avatar
Time2Fly Time2Fly is offline
BURRR!!!!
Mein Auto: 1993 318i 1994 325i
Check with the local BMW dealership give them the VIN # and ask where was originally purchased and what maintenance has been done to it. The biggest thing about buying these cars is HOW WELL THE PRIOR OWNERS TOOK CARE OF IT. Before you spend a crap load of money you may find that it just had all the cooling parts, hoses, bushings, control arms replaced. From the picture it looks clean, post some pics. of the interior and engine.
Old 08-30-2012, 10:17 AM
The Tick's Avatar
The Annoying One
Mein Auto: 2 E36's
I checked the carfax, and it looks like it was taken pretty good care of. The guy aligned it about every year, and rotated and balanced every 2 years. But I did find a receipt in the trunk that says he declined replacing the struts and tie rod ends. And he didn't do it himself, because the tie rod ends are original. I am not a spoiled little brat, but my parents are going to pay for the maintenance until I am out of college because I do not have a job, so I can spend some money fixing it up. I will post pictures soon.
  • Cars
Old 08-30-2012, 10:26 AM
The Tick's Avatar
The Annoying One
Mein Auto: 2 E36's
I have pictures up on my profile. http://www.bimmerfest.com/forums/album.php?albumid=8036
  • Cars
Old 08-30-2012, 10:44 AM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
Replacing the entire cooling system is what I'd put at the very top of my to-do list.
1998 BMW 328is
1966 Pontiac GTO
Old 08-30-2012, 10:50 AM
The Tick's Avatar
The Annoying One
Mein Auto: 2 E36's
Ok, I will.
Originally Posted by jonesin View Post
Tranny fluid
brake fluid
diff fluid
I even need to replace the radiator? Why? does it get clogged up?
  • Cars
Old 08-30-2012, 11:04 AM
The Tick's Avatar
The Annoying One
Mein Auto: 2 E36's
Will this kit do, or is there more? http://www.ecstuning.com/BMW-E36-325...ling/ES205298/
  • Cars
Old 08-30-2012, 11:07 AM
ZeGerman's Avatar
Warm Leatherette
The reason why the radiator needs to be replaced is the same reason the rest of the cooling system needs to be replaced: Plastic. The radiator has plastic side tanks, which after 75-100k miles, or 7-10 years, will eventually become perilously brittle from being subjected to years of heat cycles. The cooling systems in BMWs are a known weak spot for this very reason, and due to the aluminum cylinder head, even one mild overheating due to a cooling system failure can warp and/or crack the head, resulting $1200+ worth of damage. For reasons unknown, BMW used low quality plastics in the cooling system, which means that unlike with many other car manufacturers, we have to replace our cooling systems preventively, BEFORE something breaks and the engine overheats. With the radiators, the hose necks will suddenly snap off and you will dump all of your coolant out in an instant. Before you realize what's going on, your temp gauge will be creeping toward the red and it will already be too late. The same idea is true for all the other plastic items in the cooling system - the plastic will look totally fine, until it snaps without warning and you have a catastrophic system failure on your hands. So this is why you must replace the cooling system parts which, although they may look to be in perfect working order, they are a serious liability if they have over 75k miles on them.
The cooling system parts you should replace are the following:
- Radiator
- Expansion tank
- Expansion tank cap
- Bleeder screw (replace with brass unit)
- Thermostat
- Thermostat housing (replace with aluminum unit)
- Water pump (be sure to use one with a metal impeller)
- Upper & lower radiator hoses
- Fan
- Belts
1998 BMW 328is
1966 Pontiac GTO
Old 08-30-2012, 11:10 AM
ZeGerman's Avatar
Warm Leatherette
I've heard not so good things about the GEBA pumps.
1998 BMW 328is
1966 Pontiac GTO
Old 08-30-2012, 11:11 AM
The Tick's Avatar
The Annoying One
Mein Auto: 2 E36's
Ok, thanks.
  • Cars
Old 08-30-2012, 11:18 AM
Time2Fly's Avatar
BURRR!!!!
GEBA what the hell is that? Not being a smart arse, I guess it's the stupid in me....
Don't forget the fan clutch, while the engine is running if you can put a piece of card board slowly into the fan and it stops the clutch is bad or if you don't feel good about doing that look at the fan if it's not spinning or looks like it's not spinning the same RPM as the engine ooppps sorry motor as you rev do the card board test. As jonesin said the clutch won't be immediate but it will over heat in traffic at the worst possible time!
Old 08-31-2012, 05:11 AM
VEESERIES VEESERIES is offline
Mein Auto: 325i e36
I replaced the entire cooling system plus the fuel pump before I even drove it anywhere far, then got my suspension done fairly recently (end of last year to be precise) and it runs well, my next task is the paint work, paint is fading a bit esp on the bonnet, roof, boot and rear bumper), will post pics once am done
Old 08-31-2012, 05:38 AM
Mein Auto: 93 325i
It's actually much more exciting when the top radiator hose explodes! BOOM! Make you feel like you just experienced a car bomb in Lebanon... until you realize you're, well, alive.
Old 08-31-2012, 06:09 AM
Dmharvey Dmharvey is offline
Mein Auto: E36 M3 Coupe
Look the car over, determine what it needs, address those needs, and drive it.
Old 08-31-2012, 06:25 AM
The Tick's Avatar
The Annoying One
Mein Auto: 2 E36's
Ok, I will stop reading this in class. I laughed out loud, and now everyone is staring at me...
  • Cars
