Old 08-30-2012, 11:02 AM
jimmyb1998 jimmyb1998 is offline
Mein Auto: 2001 525i
Bouncing front passenger tire.
Hi everyone. New member, LOVE this site. It helped me fix my ambient temp sensor. So much good info I decided to join. Thanks for having me.
CAR INFO:
2001 525i
230k miles
2nd owner, bought it from original owner with 208K miles.
Car has been AWESOME!!
Todays problem:
I've noticed that eveytime I hit a small pothole or uneven pavement I can hear and feel what I can only desribe as sounding like the tire is literally "bouncing" up and down inside the fender well like a ball on the road and shakes the steering wheel. Other than hitting bumps/potholes/railroad tarcks, car rides great and tracks well. No shaking under braking unless I hit a bump at the same time as applying the brakes.
Any info is GREATLY appreciated!!
Thanks, Jimmyb
Old 08-30-2012, 11:05 AM
AnotherGeezer's Avatar
Entwicklung 39
Mein Auto: 2003 530i/5
Time for new struts.
Old 08-30-2012, 11:51 AM
BentValve's Avatar
BentValve BentValve is offline
Mein Auto: 00 528i 3 pedals
Yup. A proper strut will rebound only once. When it goes bad, it will rebound more than Dennis Rodman in his hay days.
Old 08-30-2012, 11:55 AM
Fudman's Avatar
Fudman Fudman is offline
Although most likely a failed strut, it could also be a failed ball joint. At that mileage, a complete front end replacement would be advised. It would restore your ride and handling to like new. The parts are $1200 + labor. It all depends on how long you plan to keep this car.
Old 08-30-2012, 12:02 PM
Thanks for the answers, Dennis Rodman LOL. Good one. When replacing the strut, what parts should be replaced? Just the strut or are there other parts?
Thanks, Jimmyb
Old 08-30-2012, 01:18 PM
BentValve's Avatar
Get a new strut tower mount as well.
Old 08-30-2012, 01:26 PM
Andreas540i's Avatar
Andreas540i Andreas540i is offline
Mein Auto: 1997 BMW 540i
It sound like how my bad tie rod ball joint acts. Before you buy parts, jack it up and see if the wheels have any side to side play.
1997 BMW 540i
Old 08-30-2012, 01:56 PM
adjmcloon's Avatar
adjmcloon adjmcloon is offline
Mein Auto: e39's , e30's, e46's
+1 on the suspension refresh. You'll be amazed.
I would do upper and lower control arms, tie-rod ends, ball joints (if needed), maybe upgrade your sway bar and do the end links while you're in there. Koni makes a great shock, as does Bilstien. If you haven't already, it's probably time for wheel bearings (if you are experiencing noise).
2001 530i tiAg sport (sold)
2002 540iA sport (sold)
2006 330i sport (sold)
2008 535i-6 sport (sold)
1999 528iT sport (sold)
2002 525iT alpine sport
1990 325i sedan
1990 325is coupe
Old 08-30-2012, 01:58 PM
I must ask if it's brake related (at slow speed on bumps)?
If so, read this:
- Severe shuddering while slow speed braking on bumps (1)
Old 08-31-2012, 06:19 AM
No, not brakes. They work great. Only "bounces" when hitting pothole.
Old 08-31-2012, 07:56 AM
rdl rdl is offline
Mein Auto: 530i 2003
Originally Posted by jimmyb1998 View Post
Todays problem:
Thanks, Jimmyb
It's difficult to interpret "and shakes the steering wheel" since a bump will often result in a little tremour on the steering wheel, although not what I would call a shake. But then that's the challenge of language isn't it? Just as my "fair & reasonable" is someone else's "extreme & one sided."
Also when you mention "sounding like the tire is literally "bouncing" up and down " do you mean several/many bounces or one/two.
It's just possible that one or both sway bar links are bad and generating the noise when you hit a bump, especially if the bump/pothole is on one side only. If so, you would hear a quick click-click, maybe a third click. Which some may describe as a clunk.
However, unless you have reason to believe that the previous owner refreshed the front suspension before you bought the car, all the recommendations above regarding struts and links are right on the money. At 200k+ miles, the car is way overdue if those parts are original.
Regards
RDL
Old 08-31-2012, 10:03 AM
The "bouncing" only occurs on the right side when I hit a hole or large bump It literally feels and sounds like the tire is bouncing down the road afte hitting the bump. It also shakes the steering wheel. All is fine on the road other than that, drives and rides great when I'm not hitting bumps.
Not sure what the previous replaced or repaired on the front end. I've had the car for about 18 months and this just started about a month ago. Car has been AWESOME.
Old 08-31-2012, 10:18 AM
BhamDave BhamDave is offline
Mein Auto: 2001 530
For a good DIY with parts list see:
http://www.bimmerfest.com/forums/sho...580&highlight=
I recently did this. Huge difference! Not too hard other than removing the three ball joints.
Old 08-31-2012, 10:29 AM
WOW!!! Thanks man!
