How to test, clean, & redesign the original BMW dipstick guide tube (CCV vent clogs!) - Page 3 - Bimmerfest - BMW Forums
Old 06-12-2012, 03:29 AM
Steve530 Steve530 is offline
Mein Auto: 2001 530i
As rdl mentioned in the other thread, it is only important to measure the vertical distance between the water levels. If you make sure the manometer is plumb, you make the measurement directly. If the manometer is not plumb, make sure you measure the difference in a vertically, not along the manometer.
As redl also pointed out, when you blow into the hose, it will open the diaphragm.
AFAIK, there will be no DTC because there is nothing in the system to monitor the CCV.
Steve
OSRAM CBI
BMWCCA Member #337964
Old 06-16-2012, 08:58 PM
BTW, RDL mentioned, over here, a fifth option to modifying the dipstick guide tube:
1. Buy the new dipstick guide tube
2. Drill 180 from the lower CCV vent 'finger' (above the o-ring location) through all 4 layers of metal and then weld shut the hole in the outer layer
3. Drill holes every inch or so through all 4 layers of metal BELOW the o-ring location
4. Dremel away most of the outer guide tube below the o-ring location
5. Drill away the inner guide tube with a large drill bit going straight up the bottom of the dipstick guide tube
Interesting. Thanks for the information that nothing in the DTC codes is for monitoring CCV operation.
Thanks for the clarification that only the vertical distance between the proximal and distal water levels matters, with the rule held normal to the earth.
I'm really not sure what that means because I get ZERO RESISTANCE no matter what the engine speed when I blow into the upper CCV vent pipe.
If that means the diaphragm is holed, I 'still' (unfortunately) don't get how that's supposed to indicate that. I wonder if someone with a known good CCV can test and report what happens when they blow into the upper vent pipe?
Old 06-17-2012, 11:23 AM
rdl rdl is offline
Mein Auto: 530i 2003
... stuff deleted ...
See this link for a comment on your question
http://www.bimmerfest.com/forums/sho...4&postcount=83
Regards
RDL
Old 06-17-2012, 08:51 PM
Originally Posted by rdl View Post
See this link
Hi RDL,
I was looking for that link! I knew you had answered it, but, I searched before posting that last re-request ... and I couldn't find it. I started to (erroneously) think it was never answered. Thanks for finding it for us!
Here's the answer you gave over there:
I appreciate that the "blow for bubbles test" has been recommended for some time.
It has never made sense to me. (Doesn't work for me either).
Making bubbles would require pressurizing the CCV chambers in order to force air down to the dipstick guidetube and bubble through the oil in the sump.
But, while the engine is operating, the CCV is keeping the port to the inlet manifold open "just the right amount" so that the hose (which the CCV thinks should be connected to the crankcase) has 4 - 6" w.c. vacuum.
Any pressure rise generated by blowing into the pipe would cause the CCV diaphragm to open the port wider to overcome the effect and maintain vacuum.
When the engine is stopped, the CCV default position is for the port-to-inlet manifold to be fully open; again making it impossible to generate pressure to bubble through the oil.
Any pressure would go to the inlet manifold, past the throttle toward the engine air filter, or though a cylinder that has both valves open in overlap, and down the exhaust.
Can anyone report that they have succeeded in making bubbles with a properly functioning CCV?
Old 06-18-2012, 07:02 PM
Of course, you could remove the hoses to the intake and plug them. Then you should be able to blow into the vent hose and cause bubbling in the crankcase. Not sure that would be worthwhile, but it should work.
Steve
OSRAM CBI
Old 06-19-2012, 10:10 PM
I'm not sure how much 'trouble' that would be - but it 'seems' like too much trouble for an inconclusive test.
I'm assuming at this point that the consensus is that the oft-mentioned 'vent tube bubble test' is not really a usable test for CCV operation.
Given that, yet given my high vacuum test, I need to re-read the CCV testing thread because I find it hard to believe my CCV is toast because I have no 'other' symptoms of a bad CCV (smoke in exhaust and/or loss of oil over time).
I lament a nice, simple, definitive test for a bad CCV (but maybe I just did it all wrong so I need to re-research).
Old 08-31-2012, 11:39 AM
In a post today, someone with a blinking SES and three cylinders out reported that the shop is intimating a clogged CCV caused the problem, as evidenced by oil in the intake:
- SES light
My question (keeping in mind Fudman's initial response to a similar question in post #8 of this thread & a more detailed response in post #19):
Q: Could a clogged CCV or dipstick tube really cause 3 cylinders to misfire consistently?
Old 08-31-2012, 12:30 PM
doru's Avatar
doru doru is offline
Mein Auto: 2003 530iA
stuff deleted
Not on the v8. the dipstick goes straight into the sump without any other "attachments" (read tubes).
V8 CCV design is actually a cyclone, a different design than i6. It has no diaphragm.
The vacuum is created different.
Also, if ingestion occurs, the cylinder bank that gets it should be all disabled, not only 3 cylinders. Why is the 4th healthy?
Old 09-03-2012, 12:17 AM
Originally Posted by doru View Post
Not on the v8
Wow. I never realized the CCV works that differently on the V8 than on the I6 (I did know the V8 had a separate separator).
So that we don't waste this nice research, I'll add it to the CCV testing thread:
- How to test the crankcase ventilation (aka CCV, CVV, PCV, CPV, & OSV) pressure regulating valve system (1)
In addition, there are some GREAT PICTURES in this thread for how to more gracefully remove the connections for the dipstick:
-> E39 (1997 - 2003) > How do diagnose a sudden and disturbingly unsettling cold-engine misfire (vanos?)
Originally Posted by mjbennett9 View Post
Help-at point of no return. Cut hose to dipstick :-) I'm actually flying along and doing great! However, there appears to be a non-OEM electrical connection that doesn't have the spring clip? I can't figure out how to get it off. I got all the other ones off no problem (other than someone going crazy with zip ties in crazy places to reach). I'm ready to remove throttle bottle. but electrical box is in the way. I could probably do it with it like it is but it will be a royal pain. as an FYI, I haven't found any of that mayo yet. dipstick looks clean. Did notice that there was no dipstick gasket in place. Dipstick came out no problem and no mess at all.
The problem with the connector is that it looks like either the smaller end could come out of the bigger plastic piece, or the whole things comes out. The plastic clips are very rigid and can't tell if the push in, or you have to open them outwards. Either way is very very hard as the plastic is very hard. Once I get this connect off, I'll be flying along again. Notice the yellow circle with the normal metal clip. All the others have that and came right off. Do I remove piece in the red circle from teh piece in the blue circle? or remove the blue circle (which takes the red one with it)? and how hard/far to I squeeze or open that connector? I've tried but no luck either way. But also not sure which piece(s) come out.
Another note. While I cleaned the MAF a month ago, I did not inspect it well enough. there are major cracks in the both boots. Guess it's always good to replace if old, or you do not know the vehicle history. CCV hoses look better than boots. CCV so far looks good from outside. Will check for mayo as I get more things out--once I get this flipping connector off. :-)
Old 12-29-2012, 09:21 PM
Part number for the dipstick seal over here today:
Originally Posted by vavet5308 View Post
Yes, the oil dipstick tube has a seal.
BMW part number 11 43 1 740 045
Old 01-18-2013, 05:52 AM
For cross reference, sources for and discussion about the cold weather dipstick tube guide are over here today:
Originally Posted by JNMNL52 View Post
Preparing to replace my CCV system and getting the parts in order. As a preventive measure, based on comments here in this forum, I believe it is wise to replace the dipstick tube. The replacement oil dipstick tube part number on RealOEM.com is 11437531258 - costing about $75.00. I have read about the new improved BMW dipstick tube part number 11437565437 - costing about $145.00. This new part is NOT listed on RealOEM.com. My dealer does not have a listing for this new PN. I looked it up on several parts websites through Furiousmethod.com (awesome website) and the new tube is classified as a cold climate dipstick tube and many have it in stock. I am replacing my CCV system with a regular design not cold weather design CCV. My question is will the new so called "cold climate" dipstick tube adapt and fit with the regular CCV hose system?
Old 02-04-2013, 08:08 AM
jholt jholt is offline
No Igloo's
Mein Auto: '97 528i
Does anyone believe that this dipstick tube issue could cause a slightly irregular idle at start-up for 10-15 secs, and some white exhaust on acceleration for a few minutes and then all is normal.
Not burning coolant, have checked for head gasket leaks. Thanks
Against logic there is no armor like ignorance
Old 02-24-2013, 10:49 PM
I do not know - so we'll have to wait for someone else to report whether that's possible.
In the meantime, this note from Gary is hopeful:
> E39 (1997 - 2003) > Gary's updated CCV thread
Originally Posted by gary@germanautosolutions View Post
The kit is going to include a new redesigned dipstick tube.
Gary
Old 05-03-2013, 09:21 AM
For the record, this related thread was opened today:
> E39 (1997 - 2003) > New oil guide tube - Dipstick HARD to remove
It referenced this thread (which covered the hard-to-insert new dipstick guide tube):
- CCV Replacement FYI - M54
Old 07-31-2013, 11:15 PM
For the record, this related thread was posted today:
> E39 (1997 - 2003) > How to remove dip stick tube?
EDIT: For the record, this thread has nice pictures of the dipstick operation & flow:
> E39 (1997 - 2003) > Stoping Oil Useage--Long
ID:	390911   Click image for larger version
Old 08-20-2013, 10:57 PM
bbgg bbgg is offline
Mein Auto: BMW E46 320i
This is a great thread - thank you all.
Bluebee, did you find the cause of the high vacuum reading? I also have a higher than normal vacuum reading (6-8 water inches) and slurping sound coming from the dipstick. I'm am trying to decide if I need to replace the CCV.
Old 08-20-2013, 11:36 PM
My misfire codes stopped when I replaced the broken hoses, so, I never pursued it further.
Sorry. I don't have any other details.
EDIT: Here's a shot of the dipstick guide tube hose from another thread on the X5 forum where they replaced the CCV with a $3 PCV valve.
Old 07-01-2014, 07:08 AM
This is apparently a problem with the re-designed dipstick guide tube ...
> E39 (1997 - 2003) > new cold weather dipstick
Originally Posted by sevarino View Post
Just installed new cold weather CCV and revised oil dipstick guide. My old oil dipstick is harder to push in and gets stuck on what feels like an inside ridge coming out. i really have to pull on it to get it out and am worried I'll break the end off and have it fall in the oil pan. Anyone else have this issue?
Old 08-13-2014, 09:44 AM
Heh heh ... It looks like I'm not the only one who lost the dipstick guide 19.5x3mm tube lower o-ring:
> E39 (1997 - 2003) > Dipstick O-Ring Frustration
Originally Posted by helmet75 View Post
Tonight, I went to 3 different parts stores to find a simple o-ring for my dipstick tube. It's leaking a bit since I pulled the tube to plug the oil return line. Yeah, I should've replaced it when I did the rest of the CCV delete, but I got lazy. Anyway, I went to 3 stores, no one carried one individually at all and the multi-packs they sell only go to 14mm; not big enough.
So, I stopped at Advance Auto last. The guy working had no clue what I was talking about and had to get the supervisor on duty. I explained, again, what I need and he just looked at me with glazed eyes and said "I understand, but I don't have them in that size."
I looked at him and said if he understood, then why not carry them individually? He said he didn't order parts.
I don't like to be a pain in the ass. I really don't. However, I don't like cop-outs. You represent that store and that company. Shouldn't it be "we"????
"We don't carry those. Our apologies."
sorry, venting. long, bad day.
tomorrow isn't looking promising either.
See also:
> E39 (1997 - 2003) > Complete list of all o-rings (by size & by part number) to buy when ordering parts
Old 10-08-2014, 02:04 PM
netmgr netmgr is offline
Mein Auto: bmw e39 530i
Originally Posted by johnstern View Post
Here are a bunch of pictures of me drilling and filing the outisde and inside of the tube to eliminate the rough edges. I also used a pick to loosen filings between the layers of the tube and then a vacuum cleaner and compressed air to clean those filings from the tube. I figured that any filings left would be caught by the oil pump screen and would get flushed out in future oil changes. Please note that I drilled 3 sets of holes. I drilled the holes in the places where the double layer passages were the widest.
These holes really eliminate the double layer design of the tube.
I came across this thread when I had the same issue, however I opted for removing the outer tube about 2cm below the seal, which is about where your holes start.
I did this after cleaning it for hours and gave up on as i wasnt happy with the flow.
Once the outer tube was removed you could see the size of the gap that the oil had to flow, or in my case didnt flow, its tiny and the blockage went all the way to the junction. You could also see the sheer amount of muck that remained despite poking and cleaning fluids. So essentially, in my case, drilling where you did would have done nothing at all.
I opted to drill right through from the other side of the join then weld over the entry point.
Flows freely now - or buy the cold weather version which is the same idea.
Old 01-20-2015, 07:27 AM
Cn90 posted a nice M54 CCY redesign thread today ...
> E39 (1997 - 2003) > Another solution to M54 CCV...
I saw this in BMW X5 M54 engine forum, interesting cheap solution to the CCV.
For you guys who want to try this modified CCV system...
http://www.xoutpost.com/bmw-sav-foru...-problems.html
Very clever solution to BMW convoluted CCV design.
See also:
- How to test the crankcase ventilation (aka CCV, CVV, PCV, CPV, & OSV) pressure regulating valve system (1) & the canonical bimmerfest Fudman M54 CCV replacement DIY (1) & the bimmerforums Jason5Driver M54 CCV DIY (1) & the BavAuto M54 CCV DIY (1) & sorely needed clarification on how the M54 CCV vacuum port works on the M52 CCV valve connection to the fuel pressure regulator connection (1) & how to do a CCV delete (1) & how to test, clean, & redesign the original BMW dipstick guide tube to prevent CCV vent clogs (1)
Old 02-28-2015, 07:30 PM
For the record, this older dipstick guide tube thread was updated today ...
> E39 (1997 - 2003) > Oil dipstick tube
Old 05-03-2015, 09:43 PM
The E46 team has the same dipstick guide tube problems we have:
> E46 (1999 - 2006) > Major Oil consumption
Seafoam is no substitute for common sense. When you say "I replaced the CVV", did you actually do it, or did someone else ? Are you (or them) aware that you need to remove the dipstick tube from the block and give it a thorough cleaning ? If you missed that, you will continue to have problems.
Old 05-04-2015, 05:08 AM
MJB9 MJB9 is offline
Mein Auto: 2002 525i (E39)
As far as oil consumption, assuming no leaks like OFH or VCG, the thing that resolved it for me was to replace the CCV and install a PCV. My typical 1qt every 1000 miles went to zero qts in 5k miles (I'm sure it wasn't zero, but I couldn't not tell looking at the dipstick).
Old 06-22-2015, 08:55 AM
Another potential solution to the dipstick guide tube clogging was covered here today...
> E39 (1997 - 2003) > OEM Solution to getting rid of the CCV? Kind of ingenious!
Originally Posted by BavarianE31 View Post
http://e46fanatics.com/forum/showthread.php?t=1066308
Basically replacing the M54 valve cover with a M56 one... Anyone think this would work? I'm not familiar with the problems (if any) that the M56 has relating to CCV issues (losing oil, mayo build up, etc) and whether the integrated CCV system is serviceable or not.
Thoughts?
As my summer daily driver sat in the garage, I decided that it was time for a CCV replacement. Inspired by my other E46 (an M56 SULEV model), I decided to do this in an unconventional way; by replacing the plastic valve cover on the M54 with an aluminum one from an M56 engine, and retrofitting the dipstick tube from the M56 engine.
-The M56 valve cover has the CCV built in, as a serpentine chamber that can be opened and cleaned every time the valve cover gasket is changed.
-The M56 dipstick tube doesn't have a second channel to drain oil from the CCV back into the oil pan. It is otherwise the same.
-The valve cover gasket for the M56 is flat, metal-reinforced, and lays right onto the head, rather than being put onto the valve cover first.
Went on eBay and got all of these goodies for a total of $200.
A comparison of the M54 dipstick tube (left) and the M56 dipstick tube (right):
The M56 dipstick tube uses two O-rings. The bottom O-ring is the same as the M54 dipstick tube O-ring. The part # for the top O-ring is 11437519850.
ccv icv dipstick
